Old 09-05-2024, 09:47 AM   #57
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Tomyyyu View Post
I would avoid the rear bar. 949 is pretty adamant on that and he’s a knowledgeable poster.
Going from 15mm to 16mm rear bar (29% stiffer) isn't going to hurt anything and is just about the easiest/cheapest thing to do. Also not likely to help if the issue is really front bump travel and being on the outside bumpstop midcorner...
Old 09-05-2024, 02:06 PM   #58
Tomyyyu
Drives:
Got it aligned and corner balanced.
7 out of 12 gallons. On RPF1 17x9 A052 245/40/17.
Tomyyyu is offline   Reply With Quote
Old 09-05-2024, 03:41 PM   #59
ZDan
ZDan's Avatar
Drives: '23 BRZ
You went to the right place! Those guys are da best...
Are you in COMSCC? Come to NHMS next month!
Old 09-05-2024, 03:53 PM   #60
Tomyyyu
Drives:
I’m a CT person who drives two hours to and from Devens MA. Love that site too much.
Tried others, but Devens had the most competitive talent and lovely site.
Old 09-06-2024, 01:07 PM   #61
Tomyyyu
Drives:
@ Went ahead and measured my center of wheel to fender and ended up with these heights. Are these too tall? Leading to too little droop travel?
RF - 14 2/16”
RR - 14 6/16”
LF - 14”
LR - 14 8/16”
Old 09-06-2024, 02:37 PM   #62
Racecomp Engineering
RF - 14 2/16”
RR - 14 6/16”
LF - 14”
LR - 14 8/16”
That's almost stock height in the rear, which I would say yes is too tall!
- Andrew
Old 09-06-2024, 02:43 PM   #63
Tomyyyu
Drives:
- Andrew
Gotcha. So I got it corner balanced to follow my heights of 140mm front and around 145-155mm rear. That’s from floor to pinch weld.
Wondering if it makes sense to just leave it as is for now, what would you recommend? Corner balanced weights attached. Since the rear was raised to get my cross weights correct.
Old 09-06-2024, 03:24 PM   #64
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
RF - 14 2/16”
RR - 14 6/16”
LF - 14”
LR - 14 8/16”
You'll have the same issue I had earlier this year doing the same thing. it'll ride "ok" on the street, but at speed, like autocross or track, you'll be lifting the year tires up constantly. Your RPMs will be shooting up to redline putting any power down out of turns. The rear will also hop around a lot.
My height with issues (center hub to fender):
Front 13 1/4"
Rear 14 1/4"
My height after lowering and allowing more droop travel (drives great now):
Front 12 3/4" ("one finger gap")
Rear 13 1/4" ("two finger gap")
It sounds like you're literally 2" too high in the front and at least an 1" in the rear.
cmiovino is offline   Reply With Quote
Old 09-06-2024, 03:26 PM   #65
ZDan
ZDan's Avatar
Drives: '23 BRZ
RF - 14 2/16”
RR - 14 6/16”
LF - 14”
LR - 14 8/16”
A bit on the high side, I'm about 1" lower all around. That said, *if* you are bottoming the outside front you might need to run higher...
You might run it as it is and assess the handling situation, then lower all four corners about 12mm or 1/2" and see what that does to handling and balance, and go from there.
Old 09-06-2024, 03:27 PM   #66
Tomyyyu
Drives:
Yeah, my plan is probably to run it as is. Then make adjustments. Since technically I still haven’t ran it yet.
Old 09-06-2024, 03:27 PM   #67
Tomyyyu
Drives:
Front 13 1/4"
Rear 14 1/4"
What is your setup? That will help paint a better picture.
Old 09-06-2024, 05:22 PM   #68
cmiovino
cmiovino's Avatar
RCE SS-1's (6k springs, even), with their camber plates up front, OEM ones in the rear.
Vorshlag vs RCE/KW camber plates won't make a huge difference in height between the two, comparing the two setups in terms of height should be very much the same.
Old 09-06-2024, 05:40 PM   #69
Tomyyyu
Drives:
Yeah comparing two different things. So I’ll just have to see how it works out, lol.
Old 09-07-2024, 02:55 AM   #70
strat61caster
strat61caster's Avatar
949’s ride height suggestions have a lot to do with their damper design droop/bump lengths, it shouldn’t be gospel, but I think it’s a great starting point.
@Spuds do you have the big oem tapered bolt in the upper hole of your strut? You have to use some level of camber bolt, even just the smaller oe bottom bolt to get past -4 degrees of camber even when the struts are slotted.
ineedyourdiddly
Understeer on '22 BRZ Fletch Tracking / Autocross / HPDE / Drifting 29 12-20-2022 09:09 PM
oversteer and understeer orc BRZ Second-Gen (2022+) — General Topics 76 10-05-2021 03:08 PM
Why does car understeer when going downhill? hpde_addict Tracking / Autocross / HPDE / Drifting 20 01-15-2018 09:42 AM
Understeer after new wheels carsebuco Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 12-04-2017 05:49 PM
understeer on 17 brz alex.s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 09-11-2017 04:05 AM
