BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
04-24-2023, 12:19 PM | #57 | |
Drives: Crapcan
04-24-2023, 02:22 PM | #58 | |
Drives: '23 BRZ Limited
Could also be that I had plenty of track experience on 2 wheels before I ever did a track day in a car. Big difference hitting the braking zone at 130 vs 91-92.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
04-24-2023, 04:36 PM | #59 |
Drives: 17 Asphalt 86
I noticed more of a difference playing with front toe than making camber adjustments in terms of everyday street driving.
04-25-2023, 07:59 AM | #60 |
Drives: Mini Cooper S
Any recommendations on what my alignment should be for a dual-duty car with OEM parts? I'm gonna install the top crash bolts this weekend and want to get it to an alignment shop after.
04-25-2023, 10:47 AM | #61 |
Drives: 2023 BRZ
As much camber as you can get and zero toe. Simple.
Director of Rocky Mountain 86CUP
04-25-2023, 11:17 AM | #63 |
Anti stance.
Less camber in the rear. It still gains negative camber under compression.
The Following User Says Thank You to Tokay444 For This Useful Post: | BioRebel (04-25-2023) |
04-25-2023, 12:31 PM | #64 |
Drives: '04 STi, '12 Mazda 3 Hatch
I think crash bolts only get you .9° camber max. Do dealers usually check allignment when prepping a new car? I was gonna ask mine to install the crash bolts and max the camber.
04-25-2023, 12:42 PM | #65 |
Buy an SPC lower bolt and use the lower bolt up top as the crash bolt. Net roughly -2°
The Following User Says Thank You to RToyo86 For This Useful Post: | DarkSunrise (04-25-2023) |
04-25-2023, 01:30 PM | #66 |
Around half a degree or less camber. 1/8"-1/16" total toe in out back.
04-25-2023, 02:43 PM | #67 |
ugh, I bought the SPC ones but chickened out of putting them in. Now that I'm doing my research again, I'm feeling a bit better about it. I'm going to get it aligned after the install, so I'll ask for 2* up front to start.
04-25-2023, 05:06 PM | #68 |
Drives: '22 BRZ
I bought the bolts from dealer but they said they wouldn't change the alignment to anything besides stock. So I took it to another shop and with just smaller OEM bolts up top I got like 1.5 degrees
06-09-2023, 10:11 AM | #69 |
Finally got it aligned and took it to the track with -2* up front and WOW that made a big difference. Mid-corner understeer is a thing of the past.
The Following User Says Thank You to BioRebel For This Useful Post: | vindiesel (06-09-2023) |
06-10-2023, 03:49 PM | #70 |
Drives: BRZ 2023
On original topic, I think if car comes with 0 or -1.5 degree camber isn't big issue. I wish they would have camber adjustment from factory, even if it's +-0.5 degree.
I installed top and bottom camber bolts. Both are basically SPC bolts, top one just came in whiteline bag. I was able to get -2.4 degree camber in front. I found a local shop that does a great alignment job. |
Similar Threads | ||||
SOLD: Raceseng caster + camber - adjustable front camber plates | higrip | Brakes, Suspension, Chassis | 4 | 09-17-2019 01:43 PM |
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
