Old 02-15-2023, 12:22 AM   #57
latebloom
Drives: Scion FR-S
Hey what did you end up having to replace? I just had this happen and I’m curious if I need to replace the crankshaft or just the lil sprocket, I got the timing cover off I’m going to investigate further tomorrow
latebloom is offline   Reply With Quote
Old 02-15-2023, 12:24 AM   #58
latebloom
Drives: Scion FR-S
Any update on the repair for this?
Old 02-15-2023, 07:09 PM   #59
Ultramaroon
not playing cards
Ultramaroon's Avatar
There's a slim chance that you could get away with cold forging, basically peening some of the tweaked keyway back into place before deburring. The sprocket needs to come off either way. That's toast.
Old 02-16-2023, 05:21 PM   #60
latebloom
Drives: Scion FR-S
That’s what I was thinking, regardless yes going to replace the sprocket but just hoping the camshaft is good still and it’s as simple as swapping out the sprocket and getting the key way to a salvageable point, Thank u I appreciate the reply
Old 02-16-2023, 05:26 PM   #61
Ultramaroon
not playing cards
If you bust out the hammer and drift punch, make sure the crank is supported by something way heavier on the opposite side. Keep from whacking the internals.
...or it's possible that the crank is fine except for deburring the end of the keyway.
Old 02-20-2023, 09:08 PM   #62
jrhudson
Drives: 2016 scion frs
Whoa didnt think my mistake, could happen to anyone else
Could i ask how this happened? How long did you run the motor, if you ran it at all. I ask because i ran mine for like a total of 1 minute i think and that ruined my timing so the motor came out regardless.
I went with a built block but i did rebuild the oem block with the old crank. i sanded down the nose part of the crank where the half moon sits and replaced the crank sprocket. The OEM block runs fine and good.
jrhudson is offline   Reply With Quote
Rebuild with OEM short block finch1750 Engine, Exhaust, Transmission 7 11-25-2020 05:25 PM
FS: FA20 Fully Built Short Block MicheleAbbate Engine, Exhaust, Bolt-Ons 24 08-28-2019 09:57 PM
Crawford Built Short Block texasbound972 Engine, Exhaust, Transmission 26 05-15-2015 03:39 PM
Built B18B Short Block C130NAV Miscellaneous 0 01-04-2014 12:15 PM
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 06:26 AM
