Old 03-24-2021, 10:33 PM   #57
ClevelandFRS
ClevelandFRS's Avatar
Drives: Scion FRS 2013
Originally Posted by PetrolioBenzina View Post
I can get almost straight ethanol, no crickets.
Question. How can you get no chirps with more ethanol when it seems that the less ethanol content, the less likely to chirp?
I'm confused by what you are saying. Can you explain? I only ask because my 2013 is chirping enough to get a noise complaint >.>
ClevelandFRS is offline   Reply With Quote
Old 03-25-2021, 03:21 AM   #58
Jordanwolf
Rice King
Jordanwolf's Avatar
I think it depends more on additives than the ethanol. I had succes with 10% ethanol after a few cycles, 0 crickets.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 03-25-2021, 10:08 AM   #59
I sound like a broken record saying this but there has been zero correlation between crickets and ethanol content. Some don't get them and some do regardless of what fuel they are running.
Way back there was a group in Norcal (I think) where 5 of them got the same fuel from the same place at the same time. Three had crickets and two did not.
There have been reams and reams of conversations and data on this topic and the only thing we have learned is that there is not one single common point that applies to everybody. Individuals seem to think they have solved the mystery with their one off anecdotal assessments but overall it has never been solved. Ethanol content may be a factor but is not the factor in if you get them.
Old 03-25-2021, 01:20 PM   #60
spike021
spike021's Avatar
I just learned to shut it out. I never notice the crickets anymore, except if I'm letting the car idle and I'm standing specifically outside of it waiting around.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 03-25-2021, 01:41 PM   #61
I haven't heard them for exactly one year now!
spike021 (03-25-2021)
Old 03-25-2021, 01:49 PM   #62
spike021
spike021's Avatar
I think the kouki cars definitely have some more insulation that also mutes it more from the inside.
Old 03-25-2021, 02:03 PM   #63
And a rather changed fuel pump system.
Just realized that today is the 1st anniversary!
bcj (03-25-2021), BrahmaBull1990 (03-29-2021), Dake (03-26-2021), joro2 (03-27-2021), spike021 (03-25-2021), Wally86 (03-29-2021)
Old 03-25-2021, 06:08 PM   #64
PLX92
PLX92's Avatar
Drives: 2017 BRZ Premium
My '17 chirps with the best of them
PLX92 is offline   Reply With Quote
Old 03-25-2021, 06:15 PM   #65
ClevelandFRS
I'm with you on this. I emptied the tank and engine of all gas at a shop, total drain, then ran total nonethanol gas (uber expensive) and it still chirped. I ran with that for a week, never stopped chirping.
My results were thusly:
BP Ultimate - extremely loud chirps, but in frequent, not constant
Shell Vpower Nitro - Constant low hum of chirping that doesn't stop, like crickets on red bull
Sunoco 93 - Constant loud chirp that doesn't stop
E85 variants from different locations - extremely loud chirps, infrequent, sounded just like BP Ultimate
Circle K 93 - Loud chirps, infrequent, random spouts of zero noise, then suddenly a streak of them
Valero 93 - Quiet chirps, moderate frequency
Marathon 93 - same as circle k
I've also tested 91 variants at each location after total emptying of the tank. This is not ethanol caused, but I think the ethanol content does indeed play a factor.
New engine + Nonethanol = no real difference in chirps
OLD engine 100,000K + nonethanol = good results
IMO, this is the texturing of the internal component that is thought to cause the sound that gets worn down over time. Once it is worn, it no longer makes noise and gas type wont matter.
Thats IMO and due to a year of experimenting with this. I've yet to try any additives into the gas itself on a consumer end. I'll be giving that a try.
At this point, I just go with the cheapest premium in the area, my ethanol content testing is over and I wont be investing more into it. Its a bust. I simply don't believe it has a lick to do with ethanol content, but rather the physical component itself being new and causing this sound, but over time it will wear and cease to make that sound.
I am sadly a very long time from that happening haha. My engine is basically brand new.
The Following 2 Users Say Thank You to ClevelandFRS For This Useful Post:
Kittykate (03-29-2021), Tcoat (03-25-2021)
Old 03-26-2021, 04:27 PM   #66
Dake
Dake's Avatar
It is interesting. Way back I did a road trip and planned my stops around 0 Ethanol gas stations and the crickets went away and stayed away until probably the second tank of "normal" gas once I was back home.
Then I went to the OFT E85 tune a couple years ago now, and the crickets went away as well - to the point that I completely forgot about them. I've just switched back to normal gas for an upcoming road trip where I didn't feel like worrying about finding E85 the whole way. It will be interesting to see if/how long until they return.
Dake is offline   Reply With Quote
Old 03-29-2021, 04:43 AM   #67
Kittykate
Drives: 2015 FR-S
Can corroborate Circle K gas being loud as a motherfucker on a low mileage twin.
It's too damn convenient and cheap a gas station for me to not go though so fuck it. The sound is a bit irksome though, and I get to hear it all the time at work.
I think I just need to get a loud exhaust to compete with it.
Kittykate is offline   Reply With Quote
Old 03-29-2021, 05:42 AM   #68
ClevelandFRS
I have had good results with Lucas brand Ethanol oil additive. Its like 9 bucks for a bottle and it drastically reduced the chirp to levels I can hardly hear most of the time. Huge help, not a cure, but did help me
2020, fuel, gt86, noise, tinder
Fuel Pump and clutch issues on 2017 fixed? sfdai0 Issues | Warranty | Recalls / TSB 8 05-05-2017 09:24 PM
OEM: CHIRP-free high pressure fuel pump, camshaft assembly, stock injectors, ecu ndreim Engine, Exhaust, Bolt-Ons 5 11-24-2016 12:36 AM
Driver Seat Bolster Worn/ Fuel Pump Chirp QuagmireBRZ Issues | Warranty | Recalls / TSB 11 04-21-2016 12:18 AM
two years now, is there a fuel pump doesn't chirp yet? chenshuo CANADA 41 07-18-2014 12:07 PM
Fuel Pump high pitch chirp noise lucius AFRICA 9 10-24-2013 03:40 PM
