Old 06-27-2020, 02:20 AM   #57
tomm.brz
Drives: brz 2017 hksv2
should I care how what you said? was i being offensive?
your post is non-sense to me, also your tyre example is useless because i m only here in this forum to discuss about tunes mostly
since in this forum maybe less than 5 regular posting people know something about how the ecu works, and all the rest have no clue at all and have head filled with wrong concepts about how this car runs
i wasn t a douche
and you re just another one I will ignore
i still have lots of people writing me for help and i ll offer them for free and they are happy so your opinion doesn t touch me
Old 06-27-2020, 11:57 AM   #58
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
But I have to say, you run your mouth a whole lot for someone who's been less than helpful. Let's go over things thus far.
Originally Posted by tomm.brz View Post
normal
stock tune sucks
Yes thank you for your input, Five Star contribution.
i don t believe it [That a car can idle smootly with AC on]
do a video of idling with ac on hot coolant and i ll do believe it
>my17 in europe are the worst
also ots v4 based on euro tune have quite a shitty idle
Unrelated to OP
i successfully put 760rpm as hot idle in my tunes, but the real very rock steady is at 900rpm
Congratulations, you know how to mask an issue with a 500$ band-aid and an "I know better than everyone" mindset. SFI engine have been idling around 700 for 40 years, you're not breaking new ground idling at 900.
Originally Posted by WNDSRFR View Post
That doesn't prove anything.
It's the cycling of the compressor that causes the dip. If the compressor is engaged when the engine idles, the engine already is compensating for the extra load and runs smoothly. It's when the engine is idling and the compressor suddenly engages and loads down the engine is when you get the idle dip.
Make another video. This time have the AC off and not in defrost with the engine idling. Now turn on the AC. You will hear the compressor engage and at the exact same time the idle will dip.
I'll betcha.
LITTLE DID YOU KNOW! It wasn't AC that was causing OP's problem!
it s the PI inietting at idle intermittently
steve99 explainef how to fix
Oh so now you're confidently stating it's something else completely unrelated to what you were confidently stating just prior? kk cool.
because probably you didn t even open them then
steve wrote everything very good and all indexed so you ll find where he talks about idle issue
If you want spoonfeeding again... you ll find in "oft tips n tricks"
Again, your 500$ band-aid solution is unrelated to OP, yet you keep peddling it, this time with an attitude
first, Schweiz, i just answered in general to the thread why the stock map has the problem
you answered interested, and it s your problem if you doin t have a flashing device, i do not care at all
it s not going to magically change if you keep it stock... at least you found what I was referring to, it took you 2 days but it s ok
i just answered again to better remember your name and avoid answering to you totally from now on
Yes, try more attitude, see if that'll fix it!
i wasn t a douche
If all esle fails, try still more attitude, and self-aggrandizement!
It would have cost you nothing to NOT bring your lack of contribution and attitude, but you did, and now, as if 2020 wasn't bad enough, you did.
Schweiz, I know I said I was bowing out, but one last thing... It's hard to troubleshoot over text on the internet, it's best to try and learn a lot on your end, there are a lot of small things to check, and a lot of it you can check yourself with basic tools. Going over the symptom troubleshooting section of the shop manual is a great start.
Check here https://demos.starbase7.net/t3Portal/ and navigate to 2017 repair manual, then Engine/Hybrid system > FA20 Engine Control > SFI System > Problem Symptom Table > Hunting (Poor Idling)
Some things you can check with a simple multimeter, some things you can check with a helper and something to put your ear too. I won't expect you to have a scan tool, but you may enquire at auto parts stores around your area, some may have elementary scan tools for lending/renting, just make sure it's datastream compatible for checks that require data viewing (like the MAF).
The Following 4 Users Say Thank You to RZNT4R For This Useful Post:
humfrz (06-27-2020), Lonewolf (07-03-2020), Schweiz (06-28-2020), spike021 (06-27-2020)
Old 06-27-2020, 12:54 PM   #59
WNDSRFR
Drives: FR-S,GTI
RZNT4R
It says your join date is Apr 2010. What does that mean? What did you join in Apr 2010?
Wasn't the first 86 built in 2012?
Old 06-27-2020, 01:50 PM   #60
RZNT4R
My name, rznt4r, is what I drove at the time, an rzn 4runner. I joined when this car was yet to be unveiled in the hopes I'd have one one day. At the time it was just talking about rumors.
I took a detour, after my 4runner I got a few motorcycles, a RAV4, but in March 17, I finally got into the 86 party
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
Lonewolf (07-03-2020), spike021 (06-27-2020)
Old 06-27-2020, 02:50 PM   #61
tomm.brz
whatever you think go to fix idle with a multimeter and some general instructions that correlates nothing with the fact that the idle dips and jerks because of PI going over the minimum activation limit and because you seems to trust Subaru so much, you should know that the 2 injections are not scaled to each other, because yes stock tune sucks
AC just can exacerbate the irregular idle but it surely happens also without AC
Whatever, stay in your ignorance, i couldn t care much, I still tune around 6-7 guys every month and nobody complained and guess what.. all with rock solid idle without even checking your lovely throttle plate
Old 06-27-2020, 04:11 PM   #62
spike021
spike021's Avatar
Get off your high horse. You keep bringing up tunes when the OP's original point had nothing to do with tunes. He was simply inquiring about an *OEM* issue that he wanted to learn about to make sure it wasn't an issue with his newly bought car.
If you only really come onto the forum for "tuning" then why the hell are you commenting in the subforum that has nothing to do with tuning, on a thread that is 100% about an OEM issue?
If I was looking for an e-tune and saw how you handle a completely new member of the community with a new car, you'd be the absolute last person I'd go to for anything.
You should pick up some better communication skills and learn how to respect people.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
humfrz (06-27-2020)
Old 06-27-2020, 04:44 PM   #63
tomm.brz
I commented because it is a tune problem, a stock tune problem that everybody has
enjoy your random trims and afr and good luck with your temporary fixes
Tell me where i disrepected someone, the one called douche is me
dont worry i'll be gone from now on here, you said that "issues" have nothing to do with tuning and tunes, you must be right
Old 06-27-2020, 04:50 PM   #64
RZNT4R
I don't have it.
I drove a BRZ tS that didn't have it.
The amount of posts about a hunting idle in this forum suggests that few people have it.
The Following User Says Thank You to RZNT4R For This Useful Post:
tomm.brz (06-27-2020)
Old 06-27-2020, 04:54 PM   #65
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by RZNT4R View Post
I don't have it.
There’s a big difference between a hunting idle and a small dip when an accessory loads up.
Old 06-27-2020, 04:58 PM   #66
tomm.brz
I don't have it.
good for you, enjoy it
my thinking is most people don t care for it being low and a bit intermittent, stock tune also is quite "weak" when you blip the throttle from idle so the overall slow reaction of everything around idle make people thinking all is good
also, who gets really problematic idle haunting swing usually cleans the maf sensor and throttle valve and resolve it
Old 06-27-2020, 05:43 PM   #67
humfrz
I commented because it is a tune problem, a stock tune problem that everybody has ..........
OP, my 2013 FR-S with a stock tune does not have an unstable idle.
Just sayen -
I know, tomm.brz, you're happy fer me -
spike021 (06-27-2020), tomm.brz (06-27-2020)
Old 06-27-2020, 07:45 PM   #68
tomm.brz
The Following User Says Thank You to tomm.brz For This Useful Post:
humfrz (06-27-2020)
Old 06-29-2020, 08:31 PM   #69
steve99
That idle dip could be one of dozens of issues
If its on stock tune its unlikely to be tune the 2017 should ide fine it was onlt early cars like 2012-2013 then 2015 auto that had idle issues but if its a used car you dont know if its stock tune
Check manifold pressure at idle is abour 0.4 bar (atmospheic is 1 bar)
Check long term fuel trims at idle is less than 10% when warm
Check AFR is steady at arround 14.7 AFR at idle
If those are not correct might give you a clue as to where to look
check intake and exhaust systems for leaks, clean maf sensor, clean air filter
Unfortunately intermittent faults like this are hard to diagnose is a fully equipped workshop and virtually impossible on the internet.
Many cars are modified then put back to stock, but tune left in car for mods
Intermittent will not start 333Matt Issues | Warranty | Recalls / TSB 11 10-24-2019 09:03 PM
Flashing and Intermittent CEL - HELP MugsBRZ Issues | Warranty | Recalls / TSB 7 10-19-2016 12:56 PM
Intermittent Over Heating Deep Six Issues | Warranty | Recalls / TSB 6 12-16-2014 10:22 AM
Canadian Intermittent RPM dip? VirUzxZ CANADA 23 06-24-2014 03:16 PM
Acceleration Lag - Intermittent donnyk CANADA 6 07-18-2013 12:53 AM
