Old 06-24-2020, 09:52 AM   #15
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
Just to echo what everyone else is saying, my FRS does the same thing, with the AC on at idle. It almost feels like the engine will die sometimes the RPMs drop so low. I’ve gotten used to it. The twins have a ton of “character” that’s for sure.
JesseG is offline   Reply With Quote
The Following User Says Thank You to JesseG For This Useful Post:
Griever423 (06-28-2020)
Old 06-24-2020, 09:55 AM   #16
tomm.brz
Drives: brz 2017 hksv2
>my17 in europe are the worst
also ots v4 based on euro tune have quite a shitty idle
Old 06-24-2020, 10:06 AM   #17
Schweiz
Drives: 2017 BRZ PP
Originally Posted by WNDSRFR View Post
Yeah
Mine's been doing the idle dip thing since day one. But mine is definitely caused by the AC cycling. If I come to a stop just as the AC turns on the idle will dip every time.
Will the idle continue to dip after you come to a stop? Mine mostly isn't even when I'm coming to a stop, rather when I have been sitting still for a couple seconds.
Schweiz is offline   Reply With Quote
Old 06-24-2020, 10:07 AM   #18
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I raised my idle to 950rpm and the a/c doesn't bother the car anymore. Even a clutch in from 6000rpm letting it sink all the way down, it doesn't stumbled to catch. It hesitates a little when idling, but nothing like the stumble it had when the idle rpm were at 650-700
Old 06-24-2020, 10:08 AM   #19
WNDSRFR
Drives: FR-S,GTI
In 6 years my engine has stalled just once because of this. Stopped at a traffic light, the idle dipped really low and the engine stalled. Started the car right up and had a CEL. Oh shit! My car is broken!
Went home and cleared the code with OFT. I forget what the code was. I think it was something about the vacuum.
Turns out it was just a hiccup and hasn't happened again. (Hasn't stalled, that is, it still dips all the time.)
Old 06-24-2020, 10:08 AM   #20
Schweiz
Drives: 2017 BRZ PP
Sorry for the noob question, but what does this mean?
Old 06-24-2020, 10:11 AM   #21
WNDSRFR
Drives: FR-S,GTI
Turn off the radio and listen. When the car is idling and you hear a click, that click is the AC compressor turning on. The idle dip always coincides with that click.
Old 06-24-2020, 10:12 AM   #22
Schweiz
Drives: 2017 BRZ PP
Is the idle something that can be set using OFT?
Old 06-24-2020, 10:14 AM   #23
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Yea I raised mine to 850 and it helped a ton.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
DarkPira7e (06-24-2020)
Old 06-24-2020, 10:20 AM   #24
Schweiz
Drives: 2017 BRZ PP
Does the A/C compressor run even when the HVAC controls are turned all the way off by some chance? I remember reading somewhere that the compressor runs even when the A/C button is turned off, but I don't know how true that is.
In the video link I posted in the OP, I turned all the HVAC controls off to try an make sure the A/C was not causing the problem, plus I can't the click of the compressor kicking on. (maybe its extremely quiet?)
Old 06-24-2020, 10:21 AM   #25
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I agree, I am not a fan of the OTS v4 tunes at all. Mine tune is still based on the early stuff.
600 RPM idle is too low. I bumped mine to 950 as well since coming off the track, or driving the car on a sprited back road oil pressure was extremely low.
Old 06-24-2020, 10:28 AM   #26
WNDSRFR
Drives: FR-S,GTI
The compressor also turns on if you are in defrost mode.
Old 06-24-2020, 10:36 AM   #27
DarkPira7e
DarkPira7e's Avatar
In the tune, definitely
Old 06-24-2020, 11:00 AM   #28
tomm.brz
i successfully put 760rpm as hot idle in my tunes, but the real very rock steady is at 900rpm
Intermittent will not start 333Matt Issues | Warranty | Recalls / TSB 11 10-24-2019 08:03 PM
Flashing and Intermittent CEL - HELP MugsBRZ Issues | Warranty | Recalls / TSB 7 10-19-2016 11:56 AM
Intermittent Over Heating Deep Six Issues | Warranty | Recalls / TSB 6 12-16-2014 09:22 AM
Canadian Intermittent RPM dip? VirUzxZ CANADA 23 06-24-2014 02:16 PM
Acceleration Lag - Intermittent donnyk CANADA 6 07-17-2013 11:53 PM
