Old 07-11-2020, 12:23 AM   #57
HSC
Drives: Whiteout FR-S
I used an actual sewing needle for de-pinning. I just pushed it as far into the hole as I could and pulled (with a decent amount of force) on the wire in question and it slowly comes out. Don’t recall how far it goes in...maybe 1/4 or 1/3rd of an inch? No clicking sound or anything.
HSC is offline   Reply With Quote
The Following 2 Users Say Thank You to HSC For This Useful Post:
norcalpb (07-11-2020), Yoshoobaroo (07-11-2020)
Old 07-11-2020, 12:43 AM   #58
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
DIY: Track Mode on 2013-2016 cars
Try pushing a sewing needle in the release hole as far as it’ll reasonably go. Then pull on the wire on the backside. It’s tricky, but you shouldn’t need much force.
Image shows where the release is for a given pin.
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
HSC (07-11-2020), MJones_RB (07-23-2020), norcalpb (07-11-2020)
Old 07-11-2020, 01:21 AM   #59
norcalpb
norcalpb's Avatar
Thank you so much for this picture. Although I see holes 27-38 have push tabs instead of holes to put something into. I assume I pry on this somehow?
The Following User Says Thank You to norcalpb For This Useful Post:
Old 07-11-2020, 01:38 AM   #60
Yoshoobaroo
TRACKBREAD
Yea the tab is the same for all those pins, you should be able to press them down by poking a needle in there.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Old 07-11-2020, 01:41 AM   #61
norcalpb
norcalpb's Avatar
That was it thank you!!
Old 07-11-2020, 01:43 AM   #62
Yoshoobaroo
TRACKBREAD
WOOOOOOHOOOOOOO!
Can you take some pics of the pin itself?
I’ll be updating the DIY with more clear repin instructions.
I’m so glad you got it. The repin is pretty stressful if the pins are fighting you. I can go to bed now, I’ve been refreshing the thread in bed for an hour lol!
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
norcalpb (07-11-2020), smackrel (06-24-2025)
Old 07-11-2020, 10:42 AM   #63
Yoshoobaroo
TRACKBREAD
Repin instructions updated, should be much more clear now.
Thank you @norcalpb and @HSC
Anyone trying this on a 16?
Old 07-11-2020, 01:33 PM   #64
norcalpb
norcalpb's Avatar
WOOOOOOHOOOOOOO!
Yeah dude you rock. I am so appreciative of last night's help.
It was amazing how easily the wires slid out once I had successfully pried on the correct tab. Probably half a pound of pressure to pull it out once it is free.
Scarily I went to test out the features this morning and my VSC button didn't work lol. I knew this was because of possible "accidental modification" I had made to the connectors with my pick tool. I instantly saw I made pin 27's female rectangle connector into a square, and the male connector inside the module just couldn't make contact.
I just finished "rectangle-ing" the female connector and everything works perfectly now.
Old 07-11-2020, 02:16 PM   #65
Yoshoobaroo
TRACKBREAD
Glad it all worked out!
Old 07-14-2020, 05:36 PM   #66
reh8388
Drives: 2016 Scion FR-S Release Series 2.0
Confirmed this works on a 2016 RS2.0 without repinning. Plug and play. I now have hill start assist and the 3 second hold to activate track mode.
Thanks for the great writeup!
reh8388 is offline   Reply With Quote
The Following 2 Users Say Thank You to reh8388 For This Useful Post:
solidONE (07-22-2020), Yoshoobaroo (07-14-2020)
Old 07-14-2020, 05:54 PM   #67
Yoshoobaroo
TRACKBREAD
Thanks, updating the DIY.
YES ALL YEARS CONFIRMED WORKING
Old 07-16-2020, 03:20 PM   #68
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Arrow
Easy job, it takes about 3 kms to exit from frozen state and after a MIL clear all works fine! great stuff!.
Special thanks to all guys of 541 Motorsport of Oregon and FT86 of course!!
Trap63 is offline   Reply With Quote
The Following 3 Users Say Thank You to Trap63 For This Useful Post:
MJones_RB (07-23-2020), NoHaveMSG (07-16-2020), Yoshoobaroo (07-16-2020)
Old 07-16-2020, 03:34 PM   #69
Yoshoobaroo
TRACKBREAD
Excellent!
Those are fantastic pictures of the connector pinning, do you mind if I use them in the DIY?
NoHaveMSG (07-16-2020), Trap63 (07-16-2020)
Old 07-16-2020, 04:30 PM   #70
Trap63
Trap63's Avatar
Excellent!
that's so good! go!! go !
if you need I send you the pics w/out ita directions. Let me 'now
The Following User Says Thank You to Trap63 For This Useful Post:
Review of "Track Mode" on the MY17+ cars trippinbillies40 Tracking / Autocross / HPDE / Drifting 85 02-22-2021 10:27 PM
FS: Nameless muffled track pipe 2013-2016 Dave-ROR Engine, Exhaust, Bolt-Ons 4 05-21-2020 12:27 AM
Track mode vs. VSC sport alex87f Scion FR-S / Toyota 86 GT86 General Forum 9 10-30-2018 11:47 PM
2017 Track mode on older model Bobster Engine, Exhaust, Transmission 17 12-03-2017 11:34 PM
