Old 04-06-2020, 08:02 PM   #57
devtec
Drives: 2015 Subaru BRZ Limited
Some of you may think this is ghetto, but I had it done and it works perfectly to resolve interference with the subframe.
Cut a slot in a large washer, and slip it between engine mount and frame. This raises whole engine a few millimeters, creating clearance for the overpipe.
Takes 10 minutes and any muffler shop can do it.
devtec is offline   Reply With Quote
The Following 2 Users Say Thank You to devtec For This Useful Post:
Infinity (04-06-2020), mrjj (04-07-2020)
Old 04-08-2020, 04:38 PM   #58
Originally Posted by JIM THEO View Post
Overpipe to subframe...at least, I have to check also the connection overpipe to frontpipe as the rubbing comes somewhere there, I did hammer the skid plate too!
Make sure the rest of your exhaust system is not introducing a stress onto your ace header, causing it to be torqued.
Old 04-08-2020, 04:39 PM   #59
Originally Posted by mistople View Post
Sorry to hijack, but I have a follow up question on the Ace header:
Has anyone found a better solution for the 3 bolts holding the 4-2 manifold to overpipe flange together? I've probably lost a half dozen of those nuts/bolts in under a year and no matter what I do, they seem to come undone under track conditions.
Grabbed an image from the install instructions for reference:
Safety wire can prevent backing out. Alternatively, you can just use a long bolt rather than the stud + nut.
Old 04-08-2020, 04:42 PM   #60
Originally Posted by B T View Post
I figure the welding fixture and jigs must've been moved around a bit and warped during production. Even on the stock motor mounts, the header was hitting the underbody panel, coming too close to the passenger side sway bar bushing(melted it several times) and the bolt holes at the engine don't line up properly. I always end up having to push apart the header flanges to get it over the head studs. Luckily it hasn't ruined the head stud threads.
Every header will touch the underbody on every car; the underbody panel must be hammered flat in a few places for clearance. This is by design to get the proper runner lengths and keep the bend radii as large as possible.
Old 04-16-2020, 03:00 PM   #61
devtec
I think the overpipe contacting the subframe is the biggest issue. It clears by about 3-4mm, but makes contact on hard left turns when exiting with throttle.
Washer trick under engine mount solves this issue by raising the overpipe another few mms.
Old 04-29-2020, 12:48 PM   #62
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
So im in the middle of changing out my FLywheel, CLutch ect and have my head up behind the engine. Noticed the exhaust manifold stud is touching overpipe. Anyone else notice this? could be another source of rattle
SuperTom is offline   Reply With Quote
Old 05-01-2020, 03:01 PM   #63
juanlien
Drives: M5
Originally Posted by SuperTom View Post
I have just installed Perrin mounts with Ace headers. Havent driven yet as I still have car on jackstands for other projects. But I will say I didn't have to remove the headers to install on my car, just jacked up the motor from the oil pan. I did remove the bolt holding the front pipe to the trans mount. Stock ones right side came out the front, left side came out the rear. Im going to say fairly easy and can be done in your driveway
Plus 2lbs lighter off the front of the car!
great share
juanlien is offline   Reply With Quote
Old 05-01-2020, 03:52 PM   #64
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
You can put a shim on the motor mount or maybe its just old and saggy, like my neighbors ahem*. Probably easier just to cut a little nub off that stud.
Intent > Content
Old 05-01-2020, 03:55 PM   #65
B T
I just pulled my engine, my A350 isn't anywhere near that close
B T is offline   Reply With Quote
Old 05-01-2020, 04:54 PM   #66
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Well at least they are consistent then /s
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Tokay444 (05-02-2020)
Old 05-01-2020, 05:43 PM   #67
SuperTom
SuperTom's Avatar
You missed the post above I have Perrin mounts. Yeah will just cut off that knub when I swap to stock headers for upcoming inspection. Just something for others to check since you cant really see it from looking from the front of the motor.
Old 05-01-2020, 06:49 PM   #68
mrjj
Drives: GT86 2013
Same here. I have ~10mm space between the header stud and the overpipe.
mrjj is offline   Reply With Quote
Old 05-01-2020, 11:19 PM   #69
solidONE
solidONE's Avatar
I dont know how many things can cause the cylinder head to shift relative to your overpipe/frontpipe junction. Was it always like this? I cannot imagine the perrins being different dimensions as stock, shorter?
Intent > Content
Old 05-02-2020, 09:28 AM   #70
SuperTom
SuperTom's Avatar
The perrins should be the same. PLus the cylinder to header to overpipe should remain constant even if the height was slightly different. Front pipe was unattached as well. I really don't have any rattle its just something I noticed with the Tranny out of the way I was able to stick my head up behind the engine.
Automatic Transmission issue- dealer is not recognizing the issue, please help! Arrex Issues | Warranty | Recalls / TSB 36 06-03-2019 05:15 AM
Paid $800+ for wheel speed sensor issue, but the issue came back. What should I do? darkbluemn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-05-2018 09:49 PM
Injen SES Headers/ Agency Power headers Choong86 Engine, Exhaust, Transmission 10 12-27-2013 10:51 PM
Headers: Has the CEL "issue" been solved? boredom.is.me Engine, Exhaust, Transmission 9 10-20-2013 10:35 PM
Do all headers for the BRZ cause the CEL issue? Oburn Engine, Exhaust, Transmission 19 05-16-2013 03:18 PM
