Old 09-14-2019, 12:45 PM   #57
and just in case that's not enough, i save these links to remind myself.
http://www.brakeandfrontend.com/warped-rotors-myth/
https://www.apcautotech.com/getmedia...c-8-2018_1.pdf
I disagree with the statement that heat warping is "impossible". It is highly improbable yes but can happen. As I said above it takes some super extreme conditions to do it though. Normal performance driving just does not create those conditions and if you are street driving your passenger car to the point you manage to heat damage (probably a better word than "warp") your rotors you are a menace to society and shouldn't be driving anyway.
soundman98 (09-14-2019), wparsons (09-17-2019)
Old 09-14-2019, 02:28 PM   #58
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Tristor View Post
Also, I'm out.
Considering OP started a thread complaining about how the brakes on this car are the worst because of an inability to inspect them without removing the calipers, I’m surprised that you helped as much as you did.
I get that it’s inconvenient to do brake inspections if you have to remove stuff, but that’s the whole point of routine inspections at a dealer. You pay them to take stuff apart to inspect, same with decent mechanics.
Some people just think “DIY” = cutting as many corners as possible.
The Following 5 Users Say Thank You to mav1178 For This Useful Post:
strat61caster (09-14-2019), Tcoat (09-14-2019), Tristor (09-14-2019), weederr33 (09-14-2019), wparsons (09-17-2019)
Old 09-14-2019, 03:03 PM   #59
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
But he has more tools than anyone else.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following 4 Users Say Thank You to venturaII For This Useful Post:
finch1750 (09-14-2019), soundman98 (09-14-2019), Tcoat (09-14-2019), wparsons (09-17-2019)
Old 09-14-2019, 03:47 PM   #60
They are only for German cars though.
finch1750 (09-14-2019), soundman98 (09-14-2019), Ultramaroon (09-15-2019), wparsons (09-17-2019)
Old 09-14-2019, 04:39 PM   #61
GrantedTaken
1) Go to the first car you see in any parking lot.
2) Look inside the wheels
3) This is what you will see.
Shocking that this is news to some people.
Is the BRZ your first car ?
GrantedTaken is offline   Reply With Quote
Old 09-14-2019, 05:00 PM   #62
venturaII
venturaII's Avatar
You must need more tools.
The Following User Says Thank You to venturaII For This Useful Post:
Old 09-14-2019, 07:03 PM   #63
soundman98
ProCrastinationConsultant
soundman98's Avatar
here's my ranger, which has a similar design dual piston calipers as the brz.
you did say any vehicle.
i can take a picture of my dad's f-150, or my mom's suburban, but those are also dual piston designs, so expect the same thing
Old 09-15-2019, 06:21 PM   #64
GrantedTaken
Also, I'm out.
Last question.
Is it worth getting Centric PQ Pro?
They have some red abrasive layer?
They are like a few bucks more, so basically the same price.
CENTRIC 50011240 PQ PRO; w/Shims and Hardware Info
Rear; 292mm Front Disc; Vented Rear Disc
$31.89
CENTRIC 50015390 PQ PRO; w/Shims and Hardware Info
Front
$35.79
Old 09-15-2019, 07:26 PM   #65
soundman98
soundman98's Avatar
get a bmw.
Old 09-15-2019, 07:27 PM   #66
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
get a bmw.
With a service plan.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (09-15-2019), venturaII (09-16-2019), wparsons (09-17-2019)
Old 09-15-2019, 07:47 PM   #67
Ultramaroon
not playing cards
Ultramaroon's Avatar
Also, I'm out..
Last question.
#winning
soundman98 (09-15-2019), toast (09-16-2019)
Old 09-15-2019, 07:59 PM   #68
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I know checking your brakes are hard, but is Googling something hard too?
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Old 09-15-2019, 08:11 PM   #69
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Must not have the right tool for that
Old 09-15-2019, 08:59 PM   #70
GrantedTaken
LOL, have you ever tried Googling parts quality ?
It's like Googling about what oil to use.
@Tristor knows his stuff, so I will ask him directly.
Bad ball joint;possible to just replace balljoint or do I have to replace control arm kev0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-03-2019 03:07 PM
Have to replace entire assembly to replace fuel filter? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 08-04-2017 02:26 PM
Vinyl on driver's seat split open; dealer will replace babydriver Cosmetic Modification (Interior/Exterior/Lighting) 2 12-20-2014 08:55 PM
Why do my Stoptech brakes squeel so loudly? Fix or replace? eikond Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-20-2014 02:17 PM
Help me replace my rear brakes? PoWn3d_0704 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-28-2014 03:55 PM
