#57 | |
Rust bucket enthusiast
If you do have sudden valve spring failure, then take it in and they'll perform the recall work all the same - there is no advantage to having it done early, other than you're controlling when it goes in. |
#58 | |
If a spring breaks, it won't be as simple as the recall. It'll likely need a whole new engine at that point. It'll drop the valve and mash it between the piston and head.
#59 | |
#60 | |
Drives: 13 FRS FireStorm
Did you have the recall done? |
#61 |
I recognize your user name from the failure thread. I’d be a bit jaded as well. I feel like either way I’ll never fully trust this engine again. Might have to upgrade to a 17MY. I can’t imagine driving any other car now.
#62 | |
My 2013 (with < 25,000 miles) has been recalled, but it's running good now, so, I'm in the mind set, iffen it ain't broke, don't let em break it. If I'm out on the road and a weak/broken spring leaves a valve in the combustion chamber and the piston smashes the hell out of it, I will have it toed to the nearest dealer and trade it in (give it away), for a new car on the lot and continue my vacation. Meanwhile, I ain't gonna worry about it. ![]() humfrz |
#63 | |
My hesitation aside, I really wouldn't think about it. If your car is still running great, I'm sure it will continue to |
#64 | |
I haven't, and I'm even more torn. Mine needs the drivers side valve cover gasket (or sealant, whatever it is) replaced for a slight oil leak and also needs the clutch/TOB replaced. Valve cover is free with the recall, and the clutch would be parts cost only. So I can let them do it and hope it's fine, or I can pay a shop I trust to pull the engine to do the gasket and clutch, and at that point it'll be getting a new engine since mine has ~176k kms and over 50 track days on it. I'm leaning towards chancing it since the absolute worst case is it spins a bearing after they "fix" it and I have to pay another shop to swap the engine anyway.
#65 | |
I had mine done early and fortunately there have been no issues. However, at this point, and with over 140,000 miles on the engine, I wouldn't have it done and take my chances. Works case, you get a new engine. Seems OK to me.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#66 | |
I just don’t trust it to keep it long term anymore. This was gonna be a project car eventually. |
| The Following User Says Thank You to J-Mac For This Useful Post: | humfrz (04-10-2019) |
#67 | |
#68 | |
#69 | |
I can’t imagine it being any harder than trying to prove the tech dropped sealant into the engine and clogging things up. I don’t know the first thing about any kind of engine failure though. Fingers crossed it stays that way. |
#70 | |
| valve spring issue? | nikitopo | Issues | Warranty | Recalls / TSB | 1037 | 05-01-2019 10:55 PM |
| VALVE SPRING WORLD - PRESS RECALL | Trap63 | Issues | Warranty | Recalls / TSB | 85 | 03-12-2019 11:38 PM |
| Broken Valve Spring | sybrite | Engine, Exhaust, Transmission | 45 | 11-02-2018 04:20 AM |
| Valve spring swap | rcmf5525 | Engine, Exhaust, Transmission | 6 | 05-19-2018 03:12 PM |
| GSC FA20 Valve Spring Kits | MAPerformance | Engine, Exhaust, Transmission | 41 | 07-20-2015 10:22 AM |
