Old 01-13-2020, 07:07 PM   #57
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Originally Posted by RevoG View Post
Yes, larger intercooler was installed. IAT is around 2-4C higher than ambient for normal driving. Also installed a water /meth kit to run on track to keep the temps down.
Did a boost leak down test and all good there.
This is why you are showing lower boost.
JDMChris is offline   Reply With Quote
The Following User Says Thank You to JDMChris For This Useful Post:
CSG Mike (01-13-2020)
Old 01-13-2020, 07:39 PM   #58
Bingo
jbailey8748 (03-09-2021)
Old 01-14-2020, 12:40 AM   #59
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
If this was a turbo then boost would just continue to build regardless of the IC until the wastegate opened at the predetermined boost dictated by the spring, right? But since the compressor rpm is limited by/ tied to the engine rpm, any reduction in resistance will decrease boost. In this case, the IC reduces the pressure by reducing temperature of the air and be acting as a larger reservoir, which reduces back pressure, right?
Old 01-14-2020, 09:09 AM   #60
ML
ML's Avatar
Drives: 13 White MT FR-S
"Science Bitch"!
The Following User Says Thank You to ML For This Useful Post:
Irace86.2.0 (01-14-2020)
Old 01-15-2020, 01:34 AM   #61
Irace86.2.0
So should he be making more power though? Even with lower compression and without E85, should he be making more power? Is his tuner not being aggressive enough on timing or something or is everything normal?
Old 03-10-2020, 09:41 AM   #62
86joe
Drives: 2013 Scion FRS
This entire conversation has gone way too far lol. You made 320whp with the RS pulley at 10.0:1 compression on 98 fuel. That is right where you are supposed to be. Your boost is less than 15psi because of the larger intercooler. There is a larger volume to fill now and you are experiencing a bit of a pressure drop. This happens a lot with centrifugal supercharger setups because we cannot turn our boost up anymore. Whereas with a turbo guy who gets a bigger intercooler can just use a boost controller to increase boost back to where its supposed to be or just let the wastegate maintain its spring pressure and keep its boost level. That is what is happening. With that said, your power level is normal. If you ran 12.5:1 compression and E85 you'd see more power. Its usually best to not lower compression with the Jackson Kit but I understand some people don't have access to higher octane fuels or e85.
This is a common problem I see constantly on the Gen 3 Dodge Vipers where people run the Paxton centrifugal supercharger kit which is rated at 6psi but then people get afraid of IATs and upgrade to intercooler to find out their boost gets reduced to around 2psi and then start going on an endless hunt for boost leaks and other issues.
86joe is offline   Reply With Quote
The Following User Says Thank You to 86joe For This Useful Post:
CSG Mike (03-10-2020)
Old 03-10-2020, 09:42 AM   #63
86joe
Whoops, Sorry did not see you already answered this. Working on a small computer monitor this morning and didn't see the reply lol.
c38, high boost, jrsc, pulley, supercharger
Anyone of JRSC or Edelbrock? tian105 Mid-Atlantic 11 10-02-2017 12:56 PM
JRSC &a Delicious Tuning VABeachBRZ Forced Induction 6 08-10-2017 05:44 PM
Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 17 03-31-2017 12:39 AM
JRSC oil use xsnapshot Forced Induction 3 03-27-2016 11:22 PM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 08:45 PM
