Old 04-20-2018, 03:29 PM   #57
Leonardo
Country Boy 4 Life
Leonardo's Avatar
via Imgflip Meme Generator
I LIKE TIRES!
Old 04-20-2018, 03:30 PM   #58
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by tomm.brz View Post
really?zero?
you think a boxer engine doesnt contribute to Lower center of gravity? wpuld you think our cars would have this chassis without a boxer?
You must mean the lower center of gravity for a motor that is significantly heavier than an I4 of similar displacement and output. Then start bolting all the accessories to the top of the boxer, and your CoG is back up to where an I4 would be with it's low mount accessories, plus it's still 100 pounds heavier. Explain to me what part of this chassis is due to the boxer layout (aside from the huge frame rail spacing needed to accommodate the incredibly wide motor), and then explain why Honda can make an S2000, or Mazda can have the Miata, both of which are the 86's handling equal or better, all with the 'disadvantage' of an I4. Subaru's boxer motor is a brand distinction tool at this point - nothing else. Zero to be gained.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 04-20-2018, 03:37 PM   #59
venturaII
venturaII's Avatar
It does not say Toyota supplied but predominantly Toyota parts.
Toyota at least has a parts division that actually makes them. The whole point of the matter was that the car is not 98% Subaru as people like to say.
I hear you about the 98% quip, but including components in that list which only appear in Subabru engines (or elsewhere only in Subaru models) doesn't make them Toyota parts, despite the parent company's ownership. At least, not to me.
Old 04-20-2018, 04:01 PM   #60
extrashaky
Drives: 2014 BRZ Limited
https://www.subaru.com/guides/brz/my...ll/engineering
Low — Our highest priority
From the start, the BRZ was engineered to accentuate the inherently low center of gravity of the SUBARU BOXER® engine. The engine was designed to be as compact as possible, allowing it to be mounted lower in the chassis. Then we moved everything around it lower as well—from the roofline to the seating position—yielding a supercar-like center of gravity height of 18.11 inches and planting the BRZ firmly to the ground for otherworldly response.
What car has a lower center of gravity than the BRZ?
Old 04-20-2018, 04:10 PM   #61
venturaII
venturaII's Avatar
And yet are plenty of cars out there with inline or vee motors which outhandle the BRZ. Marketing.
Old 04-20-2018, 04:18 PM   #62
Jordanwolf
Rice King
Jordanwolf's Avatar
For the price, you must admit, the CoG is nothing to scoff at. Of course there are cars with lower CoG though.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 04-20-2018, 04:19 PM   #63
bkharmony
bkharmony's Avatar
Drives: 2017 86GT
Originally Posted by yurikaze View Post
I was part of one of the original consumer research clinics for the 86 twins, back in 2009. What the market lacked and enthusiasts wanted was an inexpensive, fun to drive car that not only was easy to modify, but that enthusiasts would want to modify.
Something in the vein of S-chassis and original AE86's.
Therefore, there was room left for improvements in the car in pretty much every area.
I am an automotive designer in the aftermarket, and the 86 twins have one of the largest aftermarkets in the world, because they are one of the most modified cars out there.
Pretty much anything you want to do with the car is addressed in the aftermarket.
One of the big reasons you don't see a factory 86 twin with a higher power output is because if they did come out with one, the price would be increased to the point where you would see two major arguments against it;
1."For this much money, you could get a _______ instead."
2."For less money, you could just get a base model and install a supercharger on it."
If you don't believe me on the second one, look at how many people were saying similar things about the BRZ tS? "For less money than the tS, I could install coil-overs and better tires, and be at tS level with cash in my pocket."
The truth of the matter is that the 86 is an old design, and at this point it wouldn't make financial sense to do a major re-engineering this late into the model-cycle, only to try to sell a more expensive version to all the people on the internet that say they would buy an 86 if it had more power, when in reality 98% of them are all talk, and would still find a reason not to buy it.
It makes much more sense to address it in a new generation of the car.
Post of the Month.
bkharmony is offline   Reply With Quote
Old 04-20-2018, 04:38 PM   #64
extrashaky
Which ones have lower centers of gravity than the BRZ?
Old 04-20-2018, 04:43 PM   #65
funwheeldrive
The NA Miata if I recall correctly...
Old 04-20-2018, 04:47 PM   #66
extrashaky
That's one. No longer in production, of course.
Old 04-20-2018, 05:16 PM   #67
funwheeldrive
That's one.
Lexus LFA
Old 04-20-2018, 05:18 PM   #68
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
ND Miata with the top down(17.5"), but not up (18.5").
https://www.caranddriver.com/reviews...al-test-review
PDF warning (BRZ: 18.0"):
https://s3.amazonaws.com/amv-prod-ca...napoleon-1.pdf
JohnJuan is offline   Reply With Quote
The Following User Says Thank You to JohnJuan For This Useful Post:
fatoni (04-20-2018)
Old 04-20-2018, 05:19 PM   #69
fatoni
ND is probably within a tenth. Corvette is lower. The only reason you know the cog is marketing. Which ones have a higher one? How many cogs are you aware of?
Drive upgrades. Don't buy them.
The Following User Says Thank You to fatoni For This Useful Post:
venturaII (04-20-2018)
Old 04-20-2018, 05:22 PM   #70
JohnJuan
JohnJuan's Avatar
https://www.caranddriver.com/compari...ray-z51-page-3
Corvette is 17.5" - the same as an ND Miata with the top down - See my previous post.
CNET on 86: More power would ruin it Guru Woodman FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 52 03-04-2017 06:19 PM
I don't want to ruin my dream car. TruthfulDeception Engine, Exhaust, Transmission 28 03-23-2016 11:40 PM
Wheels that won't ruin the ride Rudiger Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-21-2012 04:40 AM
Will FI Ruin the Balance of FRS/BRZ? ZmZMWagon Other Vehicles & General Automotive Discussions 8 04-13-2012 12:19 AM
Why govt ruin everything 1660 Off-Topic Lounge [WARNING: NO POLITICS] 11 12-27-2009 04:52 PM
