Old 06-05-2017, 10:31 AM   #57
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
I have ordered some things now - and from a friend of mine who has this currently installed
Oil Temp sensor in top galley with a galley plug - seems to fit just fine
Pressure sensor with an extended line in stock location (Sounds like no negative effects)
Again - I'm not saying that I know for a fact that this works, but I will find out real quick.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 08-02-2017, 04:29 PM   #58
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
Originally Posted by Sportsguy83 View Post
Thanks to @Supermassive for the pics!
I believe this is a GREAT location for the Oil Temp gauge sensor.
Thoughts anyone? @PrimeMotoring @Rev Works @Dave-ROR @P&L Motorsports @Pure Automotive
how did you install your oil temp gauge? apparently i cant see it. i have the innovate oil temp and pressure gauge.
BRZ RN is offline   Reply With Quote
Old 08-02-2017, 04:41 PM   #59
Gopherboy6956
Yea, Photobucket took a shit on everyone and disabled 3rd party hosting on all accounts unless you pay - get this - $40 a month. Fuuuuuuuuuuck No.
The Following User Says Thank You to Gopherboy6956 For This Useful Post:
BRZ RN (08-02-2017)
Old 08-05-2017, 03:01 AM   #60
DaveB.inVa
Drives: 2016 BRZ Premium
Photobucket is sucking a lot!
I have my oil temp gauge in an oil filter sandwich plate. It's going to be very near the pan temp as it's pumped straight from there and doesn't go through a cooler. I've used this method on 3-4 different vehicles.
DaveB.inVa is offline   Reply With Quote
Old 08-09-2017, 02:39 PM   #61
wrh3
billswebspace.com
wrh3's Avatar
Drives: 2017 Alfa 4C, 2019 Fiat 124 Abarth
I tried a few different things but ended up using a sandwich plate re-tapped for the senders for my gauge, after some months I think this is the best solution. Some pics here: www.billswebspace.com/FRSRS2.html
Bill
BillsWebSpace.com
wrh3 is offline   Reply With Quote
Old 09-21-2022, 08:26 PM   #62
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Sorry to bump an old thread, but I wanted to add my info here as well. As Bill did, I used a TRD sandwich plate for the Defi pressure gauge and used a remote sender. Extremely easy, clean install.
I would recommend for anyone already using the gallery port as a turbo oil feed.
Just make sure to use teflon tape on the fittings being threaded into the ports on the adapter plate
Adding photos for future generations to see.
Remote sender comes from sandwich plate and goes under the intake manifold. I attached the pressure sensor to a tab on the back of the intake manifold, and have the wiring routed back to the driver's side, behind the brake booster, through the grommet in the firewall to the driver's side footwell.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 09-22-2022, 07:08 AM   #63
KillerBMotorsport
KillerBMotorsport's Avatar
Shameless plug here, but we carry a bunch of sender adapters for pressure and temp. The nice thing about using an adapter is that is adds the minimal amount of additional potential leak points vs remote or sandwich adapters.
Just a pic for reference, we make these in other sizes too...
KillerBMotorsport is offline   Reply With Quote
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
Ultramaroon (09-22-2022)
Old 09-22-2022, 07:39 AM   #64
Easy
https://www.ft86club.com/forums/showthread.php?t=70451
Old 09-22-2022, 02:47 PM   #65
TommyW
TommyW's Avatar
Drives: '13 Whiteout
does anyone make a Bluetooth obd2 compatible gauge for either oil temp or pressure?
Old 09-22-2022, 03:02 PM   #66
DarkPira7e
DarkPira7e's Avatar
You can view/log oil temp through any obd2 device that can read PIDs, but no pressure. I imagine bluetooth isn't really reliable enough yet to be piped through the firewall and be stable enough for popular companies to jump on board with it
The Following User Says Thank You to DarkPira7e For This Useful Post:
TommyW (09-22-2022)
Old 09-22-2022, 04:10 PM   #67
TommyW
TommyW's Avatar
yes Harry’s lap timer you can. It’s just a drag that you can’t see it unless you go out of the timer and into the Real-time Analysis mode.
Old 03-03-2023, 12:22 PM   #68
Koba
Drives: 2020 BRZ
Apologies for the bump...
I didn't see it on your website, but any chance you make/have:
1/8 PT Male to 1/8 NPT Female (for water temp sensor for an aftermarket filler neck);
I am not sure what the thread for the stock oil pressure port is (where the dummy switch is), but whatever that is Male to M10x1 Female.
If you have the above adapters (in stainless) please let me know, will buy tomorrow!
Koba is offline   Reply With Quote
Old 03-03-2023, 04:18 PM   #69
KillerBMotorsport
We used to make 1/8 PT to 1/8 NPT Adapters (and vice versa), but no one bought them. The one small batch we made took over 5 years to sell off
The OEM port is 1/8PT
M10 x 1.0 is a very odd sensor thread. What brand?
Old 03-04-2023, 05:46 PM   #70
Koba
Drives: 2020 BRZ
Stack gauges.
Oil temp is 1/8 NPT, I bought the M18x1.5 adapter from you.
Water neck (Greddy) is 1/8 PT, the Stack sensor is 1/8 NPT.
Oil Pressure sensor is M10x1.
From STACK website:
ST3501 - Oil Pressure 0-7 bar (M10x1)
ST3509 - Oil Temperature 40-140°C (1/8NPT)
ST3507 - Water Temperature 40-120°C (1/8NPT)
I think my only option is to contact a machine shop if I want them in stainless.
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
Aftermarket gauge placement CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 22 08-18-2012 01:01 AM
Self-diagnostic busses? Specifically oil pressure? Nezz Electronics | Audio | NAV | Infotainment 6 08-13-2012 08:34 AM
phantom tire pressure warning eikond Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-04-2012 09:04 AM
Gauge Sweep? himbo BRZ First-Gen (2012+) — General Topics 17 12-12-2011 11:39 AM
