| Member's Car Journals Car journals by our members. |
#57 |
Where is the boost pictures...
![]() Sent from my GM1915 using Tapatalk
2013 Series 10 FRS #553
#59 |
Drives: 86 & CX-5
OEM vs Cusco Engine Mounts
![]() So in less than a week I installed and removed the CUSCO engine mounts. While they felt good, they just transferred way too much noise and vibrations to the chassis for my liking. So....Now I am back to the OEM mounts, with the Torque Solutions transmission insert. I would only recommend the CUSCO mounts if you race/drift/like loud vibrating cars. I should have gotten the STI ones... Thanks, ET |
#60 |
Drives: 86 & CX-5
Used Sway Bars
Couldn't pass up this setup of used Whiteline sway bars.
![]() Front: 22mm Rear: 18mm I am very curious to see how my car feels after putting these on. Could this be the "perfect" setup for what I want??? Time will tell! After putting these on, I should know if it's time to go back to coilovers or not... Current Setup: Wheels: 17x9 Konig Hypergrams Tires: 255/40R-17 FALKEN AZENIS RT615K+ Springs: Swift Spec R Shocks: 2017 OEM Front Camber Bolts Rear Toe Arms |
#61 | |
Wes
Instagram: @gt86ws
| The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | ett808 (08-24-2019) |
#62 |
Drives: 86 & CX-5
HKS GT2 Supercharger
![]() Picking her up tomorrow!! Expect full review with more photos and video. |
| The Following User Says Thank You to ett808 For This Useful Post: | weederr33 (09-24-2019) |
#63 |
Drives: 86 & CX-5
HKS GT2 Supercharger Kit Results
HKS Oil Cooler
![]() Tuner's Notes: ![]() Dyno Results: (95-100 temp and humid, near Houston, Texas, Stock Fuel System, Tomei UEL and Tomei over pipe and rest of exhaust is stock, K&N air filter) Max on the dyno was 260hp but backed it off for safety's sake.
#64 |
Drives: 2017 toyota 86
How is the rear fitment with the 17x9 +40 Offset? And the 255/40 tire? Im about to run the same but on a +41 offset in rear with rce yellows.
#65 |
Drives: 86 & CX-5
The rear has room. The front has like 1-2mm clearance but ran without spacers until a week or two ago. Now have 3mm up front.
| Kai's 2017 Toyota 86 | 86Kai | Member's Car Journals | 68 | 08-23-2018 10:08 PM |
| Toyota 86 Mud Guards on 2017 BRZ | JSube | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 05-01-2017 11:57 AM |
| 2017 Toyota 86 QUESTIONS | Clee | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 02-08-2017 03:15 PM |
| 2017 toyota 86 AT | BrokenSouls | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 10-18-2016 10:22 AM |
| 2017 Toyota 86 | Driftz | Southwest | 3 | 06-04-2016 03:52 PM |
