Old 08-17-2019, 12:27 PM   #57
jflogerzi
jflogerzi's Avatar
Where is the boost pictures...
2013 Series 10 FRS #553
Old 08-17-2019, 12:29 PM   #58
ett808
Drives: 86 & CX-5
Install and tune set for mid September.
ett808 is offline   Reply With Quote
The Following User Says Thank You to ett808 For This Useful Post:
jflogerzi (08-17-2019)
Old 08-22-2019, 11:10 PM   #59
ett808
Drives: 86 & CX-5
OEM vs Cusco Engine Mounts
So in less than a week I installed and removed the CUSCO engine mounts. While they felt good, they just transferred way too much noise and vibrations to the chassis for my liking. So....Now I am back to the OEM mounts, with the Torque Solutions transmission insert.
I would only recommend the CUSCO mounts if you race/drift/like loud vibrating cars. I should have gotten the STI ones...
Thanks,
ET
Old 08-22-2019, 11:24 PM   #60
ett808
Drives: 86 & CX-5
Used Sway Bars
Couldn't pass up this setup of used Whiteline sway bars.
Front: 22mm
Rear: 18mm
I am very curious to see how my car feels after putting these on. Could this be the "perfect" setup for what I want??? Time will tell! After putting these on, I should know if it's time to go back to coilovers or not...
Current Setup:
Wheels: 17x9 Konig Hypergrams
Tires: 255/40R-17 FALKEN AZENIS RT615K+
Springs: Swift Spec R
Shocks: 2017 OEM
Front Camber Bolts
Rear Toe Arms
Old 08-22-2019, 11:25 PM   #61
StraightOuttaCanadaEh
Wes
Thanks,
ET
I did some research on the mounts and apparently the Perrin ones are like a happy medium. Firmer than STI, not as firm as Cusco
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
ett808 (08-23-2019)
Old 09-23-2019, 11:23 AM   #62
ett808
Drives: 86 & CX-5
HKS GT2 Supercharger
Picking her up tomorrow!! Expect full review with more photos and video.
weederr33 (09-24-2019)
Old 09-24-2019, 08:29 PM   #63
ett808
Drives: 86 & CX-5
HKS GT2 Supercharger Kit Results
HKS Oil Cooler
Tuner's Notes:
Dyno Results: (95-100 temp and humid, near Houston, Texas, Stock Fuel System, Tomei UEL and Tomei over pipe and rest of exhaust is stock, K&N air filter) Max on the dyno was 260hp but backed it off for safety's sake.
The Following 2 Users Say Thank You to ett808 For This Useful Post:
jflogerzi (09-24-2019), weederr33 (09-24-2019)
Old 09-24-2019, 10:55 PM   #64
86TOYO2k17
Drives: 2017 toyota 86
Current Setup:
Shocks: 2017 OEM
Front Camber Bolts
Rear Toe Arms
How is the rear fitment with the 17x9 +40 Offset? And the 255/40 tire? Im about to run the same but on a +41 offset in rear with rce yellows.
Old 09-25-2019, 02:17 AM   #65
ett808
Drives: 86 & CX-5
The rear has room. The front has like 1-2mm clearance but ran without spacers until a week or two ago. Now have 3mm up front.
Kai's 2017 Toyota 86 86Kai Member's Car Journals 68 08-23-2018 09:08 PM
Toyota 86 Mud Guards on 2017 BRZ JSube Cosmetic Modification (Interior/Exterior/Lighting) 4 05-01-2017 10:57 AM
2017 Toyota 86 QUESTIONS Clee Scion FR-S / Toyota 86 GT86 General Forum 38 02-08-2017 02:15 PM
2017 toyota 86 AT BrokenSouls Scion FR-S / Toyota 86 GT86 General Forum 22 10-18-2016 09:22 AM
2017 Toyota 86 Driftz Southwest 3 06-04-2016 02:52 PM
