#57 |
Also one of the reasons I decided FI wasn't worth it for me.
#58 |
Drives: 14 Ultramarine FR-S
I almost pulled the trigger on FI multiple times, but with some new Japanese sports cars potentially on the horizon I'm holding off lol.
Namely... the new Supra, S-FR and possibly a new Z car. We'll see what happens at the Tokyo Autoshow :p hngggggggg
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
| The Following User Says Thank You to Phantobe For This Useful Post: | Tcoat (04-20-2017) |
#59 | |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
So the Edelbrock has a few quirks that bother me. When its cold. At low RPM from full stop. I find that the kit tends to be a bit jerky. I cant just ease off the clutch and onto the gas and it be a smooth acceleration. This particular issue is a lot less apparent if the weather is at 65 degrees or warmer and the car has warmed up. Which makes sense and i can understand. Another thing directly related to that issue is that i can feel the Parasitic Load on the engine. It means that if i dont necessarily have the best clutch or throttle control when starting from a full stop i can actually feel the engine lose RPMS and almost die because it cant generate enough power to start up the SC. This SC takes about 10-15 hp just to get going. And i can feel that. Technically yes the car has awesome throttle punch. And its definetly apparent if i get a good start or do a launch. The car is smooth all the way through the power band without any sort of jerkiness. However i cant always drive like that. I have to be pretty light on the throttle due to cops in my area. A lot of this i'm comparing to when i drove my friends OFT Stage 1 NA FRS, an SBD Kit FRS and a JRSC BRZ. I realize i much rather prefer a super super tame low end. The JRSC was nice because it supplied that. However i wasnt a fan of how it felt that way all the way through 6th gear if you were to drive it granny style. The SBD Turbo was nice because only first gear was tame (building boost) and then it all hit you in 2nd gear. Which is how i like my driving experience. My Ford Fiesta ST drives the same (duh, small turbo)and i really like that kind of experience. My perfect idea of throttle response was actually when i had UEL headers with a stage 2 OFT tune. That by far felt the best for me. I was hoping it would stay that way switching to the Edelbrock but i didnt quite comprehend "low end torque" properly. I had only had turbo experience and for some reason imagined it to be the same. Thats my fault for assuming. All in all i "think" how i want my car now. Is calm slow low end and first gear. Lots of mid range torque (starting at around 3200) and the power reaching its limit at around 7k RPM. I actually dont mind the fall off. I'm going to be doing more research into it but i hope i can find my ultimate drive build. Honestly though. No regrets. Sure i could have saved myself a lot of money. But this is my first time doing major mods to a car. I was fully prepared to make these kinds of mistakes. And i have the funds to support it.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
| The Following 3 Users Say Thank You to Xxyion For This Useful Post: |
#60 |
Drives: 2013 FR-S Argento
Honestly, this sounds like it could be mitigated with a revision to your tune & throttle mapping. But I might be wrong - other Edelbrock owners might want to chime in.
#61 |
Drives: Series.Blue BRZ
Heres my take on the whole FI situation, im budgiting around 10k for my build, but i only plan on spending around 5k.
JDL BB upgrade ~ $3500 oil cooler ~ $600 ecutek+cable+tune~ $1000 catch can ~ $200 the remaining 5k is for a replacement motor, and problem resolution. I know this cars limits and I understand that while yes you can squeeze more power out of this cars engine, 280-300hp is enough to put a smile on my face, any more than that and il be looking at other cars before I look at adding another 100hp on top of that. This car is a daily for me with the occasional hooning and drift event. this will probably be the last major thing i do to this platform before i go out and buy a beater/dedicated track car. id have to say the main take away is know your cars limits based on your driving style, and build the car to exceed those limits. you cant pay to replace stuff if you dont have a car to drive to work, so either set asside some money ahead of time, or have another DD |
#62 |
Big in Japan
Drives: turBRZ
Yeah, I got a very nice deal on a used custom kit. Otherwise I wouldn't have done FI ... for the amount it usually requires. To be honest, I'd rather spend $10k on a more capable car from the factory then dump it into a twin.
| The Following 5 Users Say Thank You to GTHachiRoku For This Useful Post: | D_Thissen (05-06-2017), Phantobe (04-28-2017), StraightOuttaCanadaEh (04-21-2017), strat61caster (04-21-2017), Teseo (04-28-2017) |
#63 | |
Lowly Cartuber
I thought so too but my friend who also has the Edelbrock has the same issues last I heard from him. But he is also in an automatic Sent from my iPhone using Tapatalk
#64 | |
Drives: GT86 Harrop S/C
What you are saying about the parasitic loss makes sense, but why would it only happen when cold? I think this did pop up a while ago on edelbrock thread and people were talking MAF scaling/retunes or some stuff I didn't really understand. I was going to speak to my tuner about it when it's time for a re-tune - I.e when I get round to getting the headers done. Edit: I'm in a manual. Also, with the vibration issue you mentioned in a previous post, I fixed (pretty much) by getting the intec high level brake light. (If we are talking the same vibration issue) |
#65 | |
Lowly Cartuber
Honestly the vibration issue is a very objective complaint. I'm a super picky person but always for the things that noone else ever notices.
#66 |
Drives: rocketship
Read through the whole thread.
Am at a similar crossroads and am seriously considering going FI. This is my second FR_S. returned the first one, a 2015 FR-S with 25,500 miles most of that run NA with full bolt on and tune. Loved the car. Returned it after a 2 year lease this past december. Took all the mods off of the car before I returned it and kept them around (but solfd off the Skunk2 header and intake). Got a second FR-S about a month ago, also a 2015 but in the color I originally wanted (Ashpalt Gray) with 20k miles on it. came with a TRD exhuast on it already. Now, I have been considering going either full bolt on and putting all my previous mods on the car but with a drop in -filter (so i can add an oil cooler) and a Tomei UEL header. However, even when putting down almost 190WHP with the previous car, I always felt I could use just a wee bit more. The dollar to HP says FI is the sensible way to go. Not withstanding any of the maintenance costs. Coming to FI, debating between a SC and a turbo rig, cost wise the turbo initially sounds more attractice since you don't have the added cost of the header. The options I see before me are: 1> NA, full bolt ons and drop in filter + oil cooler. : about 180WHP Out of pocket - 1700$ (header+tune+oil cooler) 2> Supercharger, Harrop with Tomei UEL - about 300WHP 92 pump gas - 6800-6900$ (harrop kit+tomei UEl+install+tune+ oil cooler +catch can) 3> Turbo with GTX2687R: about 250-280WHP. Stock fuel system - 6600 (kit+oil cooler+install and tune) I know the tune is most important regardless of which config I decide to run in but I have no fear in that regard as, well VitViper is fucking awesome. I plan on keeping the car atleast 5 years. I have another DD. This is purely my play car. All in I expect to be in for about 25k if I went the FI route, which is about the price of a new GT86. I realize the added weight is going to change the charecteristics of the car. As to how worse it will be, I have no idea. Already have the wheels and tires to handle the extra power. If needed, i will plan to add a brake kit for the front and some suspension. Mostly, this will be a DD with the occasional track day. Space to work on the car is not a problem, the skill required however is what I lack. Very confused after reading all the posts above and part of me wonders if I should just stick to option 1, especially if the characteristics of the car changes noticeably to the worse. For instance, I could detect instantly the addition of a strut tower brace and even more so the installation of a 5lb shorai battery instead of the factory one. The loss of 20lbs made a big difference to how the car turned in. edit: I will add, I also drive kinda aggressive. So there is the added issue of getting into trouble with the po-po with a faster car. I've been pulled over about 4 times in the two years I had the silver FR-S including once alledgely for clocking 110 on the radar which I of course denied ever doing....cause I didn't.
#67 | |
Drives: 2014 BRZ
#68 | |
Drives: frs
#69 |
Drives: rocketship
well.. i put in an order for a turbo kit.
![]() Probably install late august. Have other stuff going on till then plus the tuner is booked right now 2 months out anyhow.
| The Following User Says Thank You to sachu For This Useful Post: | ShadowReaper (10-23-2017) |
#70 |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
| Cost of Supercharger or Turbo and installation. | Wishbone32 | Forced Induction | 11 | 04-15-2015 08:21 AM |
| FA20CLUB TURBO KIT GREAT POWER AFFORDABLE COST $3500 | FA20Club.com | Forced Induction | 92 | 02-13-2014 10:50 PM |
| What does it cost you to race? (Cost of racing) | rice_classic | Tracking / Autocross / HPDE / Drifting | 63 | 12-27-2013 09:54 AM |
| cl cost of frs | Dragonist | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-22-2012 04:45 PM |
| Would you buy ft-86 if it cost $28k? | ryude | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 12-28-2010 04:26 PM |
