#57 | |
not playing cards
No, it will not happen again. Even with excessive lowering, the CV joints give out way before anything else.
#58 |
"DGM BRZ"
Drives: 2016 BRZ Limited
Lol that's a great response to use, thanks. I don't ever want to go to that dealer again, I'll try the one 30mi away in Fairfield before I ever deal with them again.
#59 | |
![]() Replaced mine at ~40k and suspect I'll have to do it again at 80k (currently 63k), the only abnormal driveline noise I have right now is the e-brake click, but that only happens when the e-brake is engaged and the car moves (like when I get in or out) if I want to fix it I lubricate inside the drum whatever it is that's dried out. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Ultramaroon (10-23-2017) |
#60 | |
not playing cards
This shouldn't need a do-over. The nut is supposed to be there to cinch up the two pieces axially. That's all. I don't get it. The drum brakes are just sloppy. They float around less if adjusted as closely as possible before binding.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | strat61caster (10-23-2017) |
| Clutch Fork Squeaks | fantah | Hawaii | 28 | 11-07-2018 02:22 PM |
| Clutch Squeaks at the end of travel... clutch fork? | treminaor | Issues | Warranty | Recalls / TSB | 54 | 12-02-2016 04:53 AM |
| stiffer clutch= broken Clutch fork | KAR | Engine, Exhaust, Transmission | 1 | 04-25-2016 06:31 AM |
| Clutch Fork Broken | rick s | Issues | Warranty | Recalls / TSB | 8 | 08-27-2015 02:49 PM |
| Clutch clicking/creaking | Bg8780 | Issues | Warranty | Recalls / TSB | 4 | 03-25-2015 12:27 AM |
