Old 11-05-2017, 10:25 PM   #57
Ultramaroon
not playing cards
Ultramaroon's Avatar
I'm not going to make May. Plumbing parts are trickling in. One of them is a unicorn; a 90-degree -12AN x -8BSPP adapter for the Mocal plate. Found that one through Grainger.
@gtengr, it works beautifully. Daily driving it heats up quickly and maintains nicely between 180F and 190F
In mild ambient temps of maybe 70F-80F, with it hard over through the cooler, the engine on full boil for unlimited duty cycle can just keep up with the cooler. The oil temp remains thermostatically controlled to just above 180F but it rapidly cools as soon as I go back to cruising below 4000 RPM.
I still need to make a bracket for the valve but it sits nestled in some towels nicely for the time being. No chafing.
edit: Oh, and by 'rapidly cools," I mean it goes down to a reasonably, not shockingly 150F-160F from the thermostat bypass flow.
gtengr (11-05-2017), Jianlun (02-22-2023)
Old 11-19-2017, 06:42 AM   #58
scottman
scottman's Avatar
Drives: 13 mt fr-s
The Forrester cooler looks like an excellent option, but I read that the throttle body connection points and the oil cooler have different size fittings.
Did anyone have any problems with this or make up some step up/down adapters?
Thanks.
scottman is offline   Reply With Quote
The Following User Says Thank You to scottman For This Useful Post:
atomicalex (06-10-2019)
Old 06-01-2018, 01:41 PM   #59
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Originally Posted by 200hp/tonne View Post
With all the complex plumbing systems being made for cold/warm options, has anyone investigated a Laminova or Fluidyne coolant to Oil heat exchanger solution?
Fluidyne part I am considering:
https://www.summitracing.com/parts/f...0500/overview/
With the huge flows this unit is capable of, I was thinking to put this heat exchanger in series with the heater core and normal sandwich plate for oil flow
Anyone know if there is another laminova kit that is similar to the FA20Club one? I believe FA20Club closed down.
http://www.ft86club.com/forums/showp...40&postcount=1
PTuning kit is nice but they are not sure if it will fit with the stock intake in place.
http://www.ft86club.com/forums/showp...&postcount=123
Thanks!
botbs is offline   Reply With Quote
Old 06-03-2018, 11:57 AM   #60
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Thanks.
I plan on going this route and found the appropriate hose diameter adapters on Amazon but you can easily find these adapters in the plumbing section of any hardware store.
Joon525 is offline   Reply With Quote
Old 06-18-2018, 07:18 AM   #61
falcon_wizard
Drives: BRZ 2013
Good day,
I have read all threads on the topic, yet am puzzled as to what would be the best course of action in my situation, and would appreciate any feedback and recommendation...
I own a BRZ with a Turbo setup with an intercooler sitting in front of the stock radiator, and based on oil temps I have experienced on my car after an HPDE event recently would seem to indicate an oil cooling is strongly advisable. We had ten 20mins sessions over two days, and oil temp, using 5w40 logged with the stock PiD would reach 280F for for last 10-12 mins of each session. My water temp reached 212F, and occilated between 197 and 212F. I did not notice any reduction in car performance in any of the sessions.
I use my vehicule all year round as daily driver and experience cold canadian winters, and would appreciate attending other HPDEs in the future, maybe twice a year or so. As it is my daily car to go to work, long term and overall reliability is very high of the priority list.
In my situation, would I be better of with a dual radiator/oil cooler set-up, or have an external air to oil cooler, possibly also with an upgraded radiator ? What would offer enough cooling with maximum reliability?
any feedback would be appreciated.
falcon_wizard is offline   Reply With Quote
Old 06-19-2018, 01:22 PM   #62
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by falcon_wizard View Post
Good day,
The Jackson Racing dual radiator/ oil cooler is the best bang for you buck from what I've noticed. But if it's just a track car, and since you are turbocharged, I'd honestly go with a regular oil cooler. I believe the stock radiator is good enough unless you are seeing high water temps too.
MS, CSCS, TSAC-F, CPT
Old 06-22-2018, 09:19 PM   #63
falcon_wizard
Drives: BRZ 2013
Thanks, I'll give the Jackson dual cooler a shot, it appears to be most suited for my Situations. Cheers
Old 06-22-2018, 09:26 PM   #64
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Thanks.
If you guys are still going down the oem cooler route, NED tuning has a product I'm about to install on my car. All the tubing is included. It doesn't use fittings per say but it used hose clamps and its around $280
Old 06-26-2018, 08:51 AM   #65
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Yes I'm still going down this route and I've seen the NED offering but I pieced it together myself for under $200. Their offering still has a hose that's too big on one of the connections so it's not like it has any added benefit to me.
I'm sure it still works fine if you tighten the hose clamps enough though. (The attachment is a screen grab of the instructions on NED's site.)
The Following 2 Users Say Thank You to Joon525 For This Useful Post:
FRSBRZGT86FAN (06-26-2018), venturaII (06-26-2018)
Old 06-26-2018, 10:53 AM   #66
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I bought the FXT kit from NED, and IMO, you did the smart thing by putting it together yourself, avoiding having to deal with NED's terrible customer service. That said, even though the bulk hose they supply to attach to the TB fitting is a tad large, all it takes is an extra couple of turns on the included hose clamp, making it a non-issue.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following 2 Users Say Thank You to venturaII For This Useful Post:
jflogerzi (09-06-2018), weederr33 (06-26-2018)
Old 09-06-2018, 08:10 AM   #67
falcon_wizard
Drives: BRZ 2013
Just Following up, I have installed the Jackson dual cooler and logged the results, and they appear very promising. My temps stay below 240F, whereas they would previously reach 280F in comparable conditions. The oil warms up to op temp almost twice as fast too, so it' exactly what I was looking for.
See detailed graph on this post:
https://www.ft86club.com/forums/show...104943&page=24
Cheers and thanks for the help.
The Following 3 Users Say Thank You to falcon_wizard For This Useful Post:
atomicalex (06-10-2019), bhmax (11-09-2019), CSG Mike (09-06-2018)
Old 09-25-2018, 10:52 AM   #68
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
Good day gents,
I have a quick question but first a little about my driving habits.
1 - I don't drive crazy on the streets, I've seen my oil temp go tp 103c going up a hill...
2 - Since 2015 I do autox & HPDE, about 5 to 6 times a yr for both. I would put
myself in the mid pack range, so, not slow but not fast either.
I just did a HPDE & it was a cool night, about 12c/50f & I got temps to 125c/256f.
Engine is stock. I'm waiting for the NED oil cooler & what should I expect as temps now?
Ballpark figure, will it drop by 10f on the track, will i see 230f or more?
For those who installed this type of cooler & would be in same group as me, what was your findings? My season is finished but I'll post my numbers next yr.
I see no benefit for autox as a minute run does not increase my oil temp, it's really the
20 min sessions at wot which are important.
I'll be putting a UEL & tune next yr, but I don't think it makes a big difference, not going FI. Using 0W20 oil, so far just dealer oil changes at required maintenance window.
So, what should I expect as oil temps with an NED oil cooler?
Tks,
CB750F is offline   Reply With Quote
Old 10-03-2018, 02:15 AM   #69
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Originally Posted by MurderousPandas View Post
I have a well modified FRS, but i plan to keep it NA for a while. Would an O2W cooler be beneficial in a NA setup? These cars heat up a lot, even stock, so i want to get one, but i'm worried about overcooling or incorrect cooling setup. I don't have numbers right now, but i do notice performance drop after driving the car for sometime.
"Chasing speed with patience"
I know it's more so a Subaru engine (with a tad bit of Toyota mixed it direct/port injection) , but Toyota tends to engineer their engines to dissipate heat very well during operation and after shut down . I also notice my engine running fairly hot (high compression), seems hotter then my other small 4cyl Toyota car. The engine cooling rig / set up sounds like it could be beneficial , yet the potential for leaks (and older oil still caught in the system) is a turn off. If you track frequently and/or run boost, this could be a good way to go. I think I'm leaving well enough alone (probably change oil every 4-5k miles, not beyond 5k , and use quality synthetic 0w-20
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 10-03-2018, 03:48 AM   #70
steve99
Originally Posted by CB750F View Post
Good day gents,
Tks,
the forester/wrx cooler will usually take 10-15C off your peak oil temps for about 15 minutes hard running, then they start to run out of capacity especially in warmer ambient temps.
Id probably switch to a 5w30 full synthetic oil in preference to the 0w20.
pretty well anyone who drives hard and doesnt live in a below freezing climate would be better on a 5w30 oil.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Ultramaroon (10-03-2018), venturaII (10-03-2018)
Head unit depth bluenoserforever Electronics | Audio | NAV | Infotainment 0 07-25-2013 10:50 PM
Depth Behind Radio Opening? kmbkk Electronics | Audio | NAV | Infotainment 0 10-08-2012 12:21 AM
Detailed In-Depth Tour of the BRZ Subaruwrxfan BRZ Photos, Videos, Wallpapers, Gallery Forum 49 06-22-2012 06:38 PM
Depth of speed DIG1992 Other Vehicles & General Automotive Discussions 6 05-22-2012 02:13 PM
AE86: An In-Depth Look at A Legend Axel Scion FR-S / Toyota 86 GT86 General Forum 25 01-26-2010 11:44 PM
