11-09-2016, 06:51 PM | #57 |
I finished a semester of grade 11 and agree with your evaluation.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | gramicci101 (11-09-2016), strat61caster (11-09-2016) |
11-09-2016, 07:06 PM | #58 | |
Drives: Full race 4cyl boxer
I'll just leave this here: "SURFACE VEHICLE STANDARD SAE J1349 7.5 Power and Torque Determination 7.5.1 TEST PROCEDURE This section defines the actual dynamometer test procedure used in obtaining Rated Net Power and Torque. The test shall consist of a run at full throttle for spark-ignited engines and at a fixed full-load fuel injection pump setting for CI engines. The following test controls and operating conditions must be adhered to meet the requirements of this standard: 7.5.2 TEST POINTS Measurements shall be taken at increments of no more than 500 RPM in sequence from the lowest to the highest engine speeds recommended by the manufacturer. The operating speeds shall include those for peak power and peak torque. Data at 100 RPM increments around peak torque and peak power are recommended to accurately distinguish their respective rated speeds. Engine speed shall not deviate from the nominal set speed by more than ±1% or 5 RPM, whichever is greater. 7.5.3 LOGGING OF MEASUREMENTS No data shall be taken until torque and speed measurements have remained stable within 1% and controlled temperatures have remained stable within ± 2 C for at least 1 minute. The recorded measurements shall be the average of readings over a span of 1 minute. Alternatively, data can be taken by stabilizing the torque and speed for 5 seconds and then acquiring data at a minimum 10 Hz rate for at least ten seconds. If this alternative procedure is used, the entire speed sweep shall be repeated at least three times. The results are considered valid if the repeatability of at least three measurements is within 1% of the mean." That says that (according to the definitive authority on automotive testing) that torque measurements are to be done at constant RPM. So someone please tell me how rotational inertia can affect to torque produced at constant RPM? (hint I already told you above) If it is such simple physics, it should be a simple answer right?
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
The Following User Says Thank You to justatroll For This Useful Post: | Cole (11-09-2016) |
11-09-2016, 07:08 PM | #59 |
Drives: 13 frs red
I had perrin pulley in 2013. Made the car feel livelier in lower gears. Coupled with a raised rev limit ate a crank bearing. For me, a good header and tune makes the car everything I could hope for.
11-09-2016, 07:13 PM | #60 | |
I said it cannot make more hp Or do you believe HP and acceleration are the same thing?
The Following User Says Thank You to justatroll For This Useful Post: | Tcoat (11-09-2016) |
11-09-2016, 07:25 PM | #61 |
11-09-2016, 07:27 PM | #62 |
Off Topic
The Following User Says Thank You to gramicci101 For This Useful Post: | Tcoat (11-09-2016) |
11-09-2016, 07:36 PM | #63 |
No then I climbed on the short bus and joined the Army!
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Cole (11-09-2016), gramicci101 (11-09-2016) |
11-09-2016, 07:41 PM | #64 |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | Tcoat (11-09-2016), Ultramaroon (11-09-2016) |
11-09-2016, 07:45 PM | #65 |
With a fiberglass liner yes!
11-09-2016, 07:58 PM | #66 |
11-09-2016, 08:00 PM | #67 |
No it was OK the officers showed us how. They had years of experience at it. The Captains seemed to be very proficient.
The Following User Says Thank You to Tcoat For This Useful Post: | Cole (11-09-2016) |
11-09-2016, 08:29 PM | #68 |
The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (11-09-2016) |
11-09-2016, 08:56 PM | #69 | |
chicken tonight
I'll even do you a solid. You may neglect internal frictional losses, rolling resistance and drag.
The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
11-09-2016, 09:05 PM | #70 |
Not a troll
All these pulley debates remind me of the great physics question:
If you put an airplane on a treadmill that matches the wheel speed of the airplane perfectly so that no forward motion of the plane is achieved, will it take off? Last edited by Cole; 11-09-2016 at 10:36 PM. |
The Following 3 Users Say Thank You to Cole For This Useful Post: |
Similar Threads | ||||
Recommended cheaper power gains mods | emishor86 | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 03-27-2016 08:49 PM |
POWER Mods for NA setup | NYCsubaruBRZ | Engine, Exhaust, Transmission | 61 | 02-17-2016 09:19 AM |
Mods to reduce drivetrain power loss? | FRSW12 | Engine, Exhaust, Transmission | 31 | 12-28-2015 05:10 PM |
Easy mods for power and sound. | LWAA | BRZ First-Gen (2012+) -- General Topics | 40 | 09-13-2015 09:20 PM |
More Power VS. other Performance Mods | Darryljr11 | Mid-Atlantic | 38 | 08-11-2013 08:53 PM |
