#57 |
Drives: BRZ, STI, GT350R, Supra, 987.2
Looks good. Correct, if you're venting to atmosphere, you don't need to install that adapter into the AOS.
#58 |
Drives: Late 2014 Subaru BRZ
I really like what velox brought to the table. 1 question though, on my home brewed setup i have all 3 locations going to be catch can but my vent to atmostphere goes to a 1/2 hose thats routed under my car and dumps out past my transmission. Will this be a problem with the AOS? I hate... smelling gas with the AC. The hose under the car fixed it real quick.
Im also thinking of making a charcoal canister thats installed in between that vent to atmosphere port and earth. My jeep has 1 and it gave me ideas! Velox products look way more polished than my setup so im considering highly.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#59 | |
Thanks, Eric |
#60 |
Drives: JRSC C38 HBP E85 FRS
Subscribed
#61 |
Drives: 2013 BRZ Limited M/T
Added a hose the ran down by the front sway bar for my vent to atmosphere. Definitely cut down on the cabin smell.
#62 |
Drives: '13 10 Series FRS #1203
Just ordered mine today. Will probably be a bit before I install it, but excited to support a small business and what looks to be a great product!
| The Following User Says Thank You to Shady195 For This Useful Post: | VerusEric (01-29-2017) |
#63 | |
Drives: 2016 Subaru BRZ Limited
Glenn |
#64 |
Adding some more pics because I was getting questions.
This is the VOS with a JRSC setup. First one shows you entire view. Hose 2 (from left to right in this pic) is the one vented to atmosphere. It goes under the car by the transmission. Hose 3 connects to the intake after the air filter and before supercharger. Hose 4 is down by the yellow oil fill cap. The rest of the pics focus on hose 4. https://goo.gl/photos/5TpkXkBpk4nt9CCG7 My pointer finger is touching hose 4 https://goo.gl/photos/SpSCtdVDaM8x3nvJ8 Hose 4 is the one that is rerouted from the passenger side of the car per the JRSC install instructions. Its the one farthest away to the right of the yellow can and below the hose in the foreground. It has a 90 connector on it, so it can ran back behind the AC. https://goo.gl/photos/X8cZR5ZMciQQkVWN8 In this pic you'll see a hose almost in the middle with a metal hose clamp. The hose 4 is right below it. It connects to the motor and does a 90 and runs straight down (this is towards the outside of the car on the passenger side. It then L's around and has a 4" or so before the 90 I was referring to the previous pic. https://goo.gl/photos/dg4JGwEQx7pen5Lo6 |
| The Following User Says Thank You to Bramick For This Useful Post: | CHMBRZ (02-01-2017) |
#65 |
Is it possible to just hook up the PCV side for the time being since I'm NA and run the other 2 lines later when I go boost? Or would I still have to hook up the side to the crankcase?
#66 | |
I'm not sure what everyone is attempting to do with each install which makes answering these questions difficult. Overall the install is quite simple if you follow along with the install manual and not overthink it. Most people that have issues are glossing over the install manual or trying something they shouldn't .Thanks, Eric |
| The Following User Says Thank You to VerusEric For This Useful Post: | CHMBRZ (02-01-2017) |
#67 |
Alright thanks for the info.
#68 |
#69 |
Is it better to use teflon tape or thread lock on the drain back kit from the cam plate to the stubby drain piece?
#70 | |
. The bung is a -6 ORB (O Ring Boss) and using Teflon or thread lock is not suggested.Thanks, Eric |
| Verus Engineering High Performance Radiator - Gauging Interest | VerusEric | Engine, Exhaust, Transmission | 90 | 07-08-2023 07:43 AM |
| Verus Engineering Rear Wing Development | VerusEric | Tracking / Autocross / HPDE / Drifting | 203 | 07-05-2021 09:15 AM |
| Verus Engineering Billet Transmission Beta Tester Run | VerusEric | Engine, Exhaust, Transmission | 62 | 04-26-2020 01:44 PM |
| Verus Engineering Carbon Thermoplastic Splitter Components | VerusEric | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 11-26-2017 05:23 AM |
| Raceseng | Revo Pulleys Information and Release | Raceseng | Engine, Exhaust, Transmission | 3 | 10-09-2016 11:01 AM |
