Old 12-30-2016, 04:44 PM   #57
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Originally Posted by Bramick View Post
Sharing my Velox AOS install with Jackson Racing Super Charger (Forced Induction) install.
If I'm leaving one hose to atmosphere do I need to install the 3/8" NPT to 1/2" hose adapter on the AOS? I'm thinking no. If not I'm all set.
Looks good. Correct, if you're venting to atmosphere, you don't need to install that adapter into the AOS.
VerusEric is offline   Reply With Quote
Old 01-01-2017, 11:11 AM   #58
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I really like what velox brought to the table. 1 question though, on my home brewed setup i have all 3 locations going to be catch can but my vent to atmostphere goes to a 1/2 hose thats routed under my car and dumps out past my transmission. Will this be a problem with the AOS? I hate... smelling gas with the AC. The hose under the car fixed it real quick.
Im also thinking of making a charcoal canister thats installed in between that vent to atmosphere port and earth. My jeep has 1 and it gave me ideas!
Velox products look way more polished than my setup so im considering highly.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 01-01-2017, 02:57 PM   #59
VerusEric
VerusEric's Avatar
Where is the 3rd location coming from? From factory, the engine has two vents, I'm not sure where you're grabbing the 3rd from.
Thanks,
Eric
Old 01-26-2017, 11:19 PM   #60
Dfyfzx
Drives: JRSC C38 HBP E85 FRS
Subscribed
Dfyfzx is offline   Reply With Quote
Old 01-27-2017, 12:22 PM   #61
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Added a hose the ran down by the front sway bar for my vent to atmosphere. Definitely cut down on the cabin smell.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 01-27-2017, 04:26 PM   #62
Shady195
Drives: '13 10 Series FRS #1203
Just ordered mine today. Will probably be a bit before I install it, but excited to support a small business and what looks to be a great product!
Shady195 is offline   Reply With Quote
The Following User Says Thank You to Shady195 For This Useful Post:
VerusEric (01-29-2017)
Old 01-28-2017, 03:20 PM   #63
CHMBRZ
Drives: 2016 Subaru BRZ Limited
Originally Posted by VeloxEric View Post
I have multiple units going out Monday! Thanks for the order guys.
Here are the install instructions for anyone interested: Install Manual
Any questions, feel free to ask here or e-mail us so that we can expand and improve on them. Some questions likely will be present until you actually start installing the unit(s) though, so keep that in mind as well.
Thanks,
Eric
Do you have more detailed pictures of where the 2 hoses route towards the driver side of the engine bay, i've looked at the install manual, but the pics are top shots only.
Glenn
CHMBRZ is offline   Reply With Quote
Old 01-28-2017, 05:27 PM   #64
Bramick
Bramick's Avatar
Adding some more pics because I was getting questions.
This is the VOS with a JRSC setup.
First one shows you entire view. Hose 2 (from left to right in this pic) is the one vented to atmosphere. It goes under the car by the transmission. Hose 3 connects to the intake after the air filter and before supercharger. Hose 4 is down by the yellow oil fill cap. The rest of the pics focus on hose 4.
https://goo.gl/photos/5TpkXkBpk4nt9CCG7
My pointer finger is touching hose 4
https://goo.gl/photos/SpSCtdVDaM8x3nvJ8
Hose 4 is the one that is rerouted from the passenger side of the car per the JRSC install instructions. Its the one farthest away to the right of the yellow can and below the hose in the foreground. It has a 90 connector on it, so it can ran back behind the AC.
https://goo.gl/photos/X8cZR5ZMciQQkVWN8
In this pic you'll see a hose almost in the middle with a metal hose clamp. The hose 4 is right below it. It connects to the motor and does a 90 and runs straight down (this is towards the outside of the car on the passenger side. It then L's around and has a 4" or so before the 90 I was referring to the previous pic.
https://goo.gl/photos/dg4JGwEQx7pen5Lo6
The Following User Says Thank You to Bramick For This Useful Post:
CHMBRZ (02-01-2017)
Old 01-29-2017, 05:28 PM   #65
CHMBRZ
Is it possible to just hook up the PCV side for the time being since I'm NA and run the other 2 lines later when I go boost? Or would I still have to hook up the side to the crankcase?
Old 01-29-2017, 07:00 PM   #66
VerusEric
VerusEric's Avatar
I'd recommend running it in NA configuration or capping the two other hoses then.
I'm not sure what everyone is attempting to do with each install which makes answering these questions difficult. Overall the install is quite simple if you follow along with the install manual and not overthink it. Most people that have issues are glossing over the install manual or trying something they shouldn't .
Thanks,
Eric
The Following User Says Thank You to VerusEric For This Useful Post:
CHMBRZ (02-01-2017)
Old 01-29-2017, 07:16 PM   #67
CHMBRZ
Alright thanks for the info.
Old 01-29-2017, 09:50 PM   #68
Ashikabi
Ashikabi's Avatar
I don't have the Velox AOS but hooking up the crank case is super easy. Really no reason not to
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
CHMBRZ (02-01-2017), VerusEric (01-31-2017)
Old 01-30-2017, 03:15 PM   #69
CHMBRZ
Is it better to use teflon tape or thread lock on the drain back kit from the cam plate to the stubby drain piece?
Old 01-31-2017, 09:43 PM   #70
VerusEric
VerusEric's Avatar
Install manual states/shows using just an O-ring (supplied with drain back kit) . The bung is a -6 ORB (O Ring Boss) and using Teflon or thread lock is not suggested.
Thanks,
Eric
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
CHMBRZ (02-01-2017), Tokay444 (02-17-2017)
Verus Engineering High Performance Radiator - Gauging Interest VerusEric Engine, Exhaust, Transmission 90 07-08-2023 07:43 AM
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 09:15 AM
Verus Engineering Billet Transmission Beta Tester Run VerusEric Engine, Exhaust, Transmission 62 04-26-2020 01:44 PM
Verus Engineering Carbon Thermoplastic Splitter Components VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 35 11-26-2017 05:23 AM
Raceseng | Revo Pulleys Information and Release Raceseng Engine, Exhaust, Transmission 3 10-09-2016 11:01 AM
