01-11-2013, 04:33 PM | #57 |
Drives: BMW E84
Anyone actually taken the car to the dealership to check things out?
01-12-2013, 01:53 AM | #58 |
Drives: Asphalt AT FR-S
I've gotten this problem a few times when it's cold - it always seems to happen after I take my car to the hills. Sometimes it won't fail to start up, but will start up really weakly instead and the car just feels sluggish for a while. During warmup the engine won't go over 1000 RPM either whereas normally it'll start up at 2000+ (I think) and then dip to ~1200-1500. Anyone else experience similar problems? Is it related to CA gas?
01-12-2013, 04:42 AM | #59 |
Used Car King
Drives: 13 White M/T BRZ
Exactly! Through some hills.... Totally the same thing..... Can anyone chime in on this issue?
Have you ever danced with the devil in the pale moon light?
02-05-2013, 03:02 AM | #60 |
Drives: scion fr-s
not sure if the issue is weather related, but i've had a slow start-up happen to me a handful of times since owning it (August 2012). it's always started on a single try but it just seems like a delayed 2-3 second start. it's really slow and almost seems like it's not going to make it, but in the end it starts.
02-05-2013, 06:46 PM | #61 |
Hey guys, Its been awhile since I posted back on this topic. I followed someones advice by letting the car prime first then starting the car...since then I never had the problem again.
ScionFrsFan
02-14-2013, 07:57 PM | #62 |
Drives: 2013 Scion FR-S - Asphalt
I have an automatic with less then 300 miles. It has happened to me twice so far. Going for diagnostics tomorrow. It's been cold here in New York but nothing that would hinder a car from starting properly. It takes around three tries each time. I prime the engine, I don't park on an incline.
Very strange. I'm hoping to have some answers tomorrow. |
02-14-2013, 10:52 PM | #63 |
Drives: BRZ DGM Limited
Its happened once to me where it started on the first push but took longer than usual. Was not even a cold start since I had just driven to the store and was only in the store 15 min. Odd.
MissNyxxie..let us know what the dealer tells you but bet my bottom dollar they say "its fine" or "can't reproduce it" |
02-17-2013, 10:40 PM | #64 |
Drives: 2013 Firestorm FR-S
I've had this issue as well, probably 4-5 times since owning with 8k on it. I haven't bothered with telling the dealer because they can't even handle the other issues and as BRZnut said, the dealer will say "Can't reproduce it."
02-17-2013, 10:45 PM | #65 |
Make love
Drives: H8R.. Not really
Same has happened to me.. It is far and few between incidents and I ignore it.
02-26-2013, 04:54 PM | #66 |
Drives: 2013 BRZ Limited - WRB, MT
happened a 2nd time for me today, 1900 miles on the car. It's an AT. The first time was as described but today, it just kept trying to turn over and as i let the key turn back to the "on" position, the engine randomly started. I turned the car off and it turned on no problem the second time.
02-26-2013, 05:31 PM | #67 |
Make love
Easter eggs left behind by Toyobaru engineers?
02-26-2013, 05:37 PM | #68 |
Drives: 2013 MT Asphalt FR-S
I am getting this as well. When I was in for service last Saturday, they replaced my battery but it seems the issue is still with me although not as bad yet.
02-26-2013, 05:43 PM | #69 |
Drives: WRB BRZ
I have 2500 miles on my Manual Push button BRZ. Three times in teh past i have pushed the start button and the car cranked for about 5-6 seconds then stumbled to start. It was like a strong crank..but reminded me of having to pump the gas on an old ford pickup. It happens randomnly in cool weather 50-65 degrees. May be the quality of gas (only 91 octaine around here) or something else im not sure. Either way when it does it my heart flutters as if the car is going to NOT start and just keep cranking.
02-26-2013, 07:59 PM | #70 |
Drives: 2013 FR-S whiteout
5k miles. Happened to me twice this week (both times leaving work)
Similar Threads | ||||
After Market Problem Signals Fuse Popped- Car Wont Go into Gear | ScionFR-S | Issues | Warranty | Recalls / TSB | 14 | 11-20-2012 02:34 PM |
Car Won't Start | schtebie | Issues | Warranty | Recalls / TSB | 25 | 10-15-2012 04:06 PM |
trunk wont unlatch | bakerr6 | Issues | Warranty | Recalls / TSB | 9 | 09-24-2012 01:32 AM |
GTS come with push start? | adam | AUSTRALIA | 13 | 06-04-2012 03:28 AM |
Car won't start, no spark? | #87 | Other Vehicles & General Automotive Discussions | 5 | 12-19-2011 12:29 PM |
