#57 | |
chicken tonight
#58 | |
TRACKBREAD
Am I blinded by infatuation?
Don't worry, max performance summers (PSS, Ventus V12, Extreme contact sport, etc.) Will significantly increase your grip, but the car is still very playful. You can still break the tires loose and get it sideways on command. The increased grip makes the behavior at the limit more predictable too. Losing the silly handling at the limit was my biggest fear putting serious tires on, but it was very much unfounded. |
The Following User Says Thank You to Yoshoobaroo For This Useful Post: | Ultramaroon (04-14-2019) |
#59 | |
The Following User Says Thank You to gravitylover For This Useful Post: | imprezive (04-14-2019) |
#60 | |
I had a 95 GS-R with Komi Yellows ground control coil overs, 550lbs springs front and rear and a Type-R rear bar. That car was a blast and with any mid corner lift it would oversteer but just a little throttle and it would settle back down. I still enjoy the FRS way more. Especially with real tires. With real tires the FRS isn’t as tail happy but can still be tail happy if you want it to be. |
The Following 4 Users Say Thank You to ermax For This Useful Post: |
#61 |
Only happy when it rains.
Drives: series.blue
I think sticking like glue is boring. I love freaking people out by sliding around.
#62 | |
Drives: 17 Asphalt 86
I bought my 86 on a bit of a whim. I was tired of my SX4 and didn't need the practicality. I saw a facelift 86 on a lot. Window shopped for a month, went in, test drove one and bought it the same day after working out the numbers. |
#63 | |
Drives: 2016 BRZ Limited
#64 | |
Drives: 2014 BRZ Limited
The looks you get are not saying, "Oh no! I'm so freaked out by that guy sliding around!" Those looks are saying, "Jeez. What a douche." |
The Following 3 Users Say Thank You to extrashaky For This Useful Post: |
#65 | |
Sensible tyre size for NA <200hp Lots of grip at 35psi (spirited fun drive) Easy to slide at 38psi (daily travel/fuel economy/being a ****) Brilliant in the dry Average in the wet Holds up well at the track IRT heat Cheap Wears well Opinions may vary
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
The Following User Says Thank You to 86MLR For This Useful Post: | Ultramaroon (04-15-2019) |
#66 | |
I don’t know I tend to think the guy in the 991 GT3 driving like grandma is the douche not the guy that’s actually enjoying his car. Assuming they aren’t putting people at risk of course. |
The Following User Says Thank You to ermax For This Useful Post: | Ultramaroon (04-15-2019) |
#67 |
chicken tonight
That's just the thing about sticky tires, speed versus grip limits. I don't want to have to exceed the former to flirt with the latter.
The Following User Says Thank You to Ultramaroon For This Useful Post: | ermax (04-15-2019) |
#68 | |
In the 86 all it takes is tyre pressure and a little "flick or kick" and you have your arse out at 40kph, drop the psi by 1 and it's out at 45kph, rinse and repeat for faster skids. I actually have a mate at work who sold his set of "big" tyres/rims. He has dropped down from 255 to 215, the reasoning was to be able to play with the car more at lower speeds, and not need to be at the limit to break the tyres away. Different story if you are hitting the track, where alot of corner grip is required, but for a street car, give me the playfulness any day.
The Following 4 Users Say Thank You to 86MLR For This Useful Post: |
#69 | |
Weight Weenie
Drives: 15 FR-S
Nice. I use 205's on a short track. Tons of fun and I've never seen anyone at the finish line handing out trophies ![]() |
The Following User Says Thank You to new2subaru For This Useful Post: | Ultramaroon (04-16-2019) |
#70 | |
chicken tonight
It'll be a while before I'm in the market for fresh tires. @humfrz just gave me his stock ones to use up. ![]()
The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (04-16-2019) |
