#57 |
Just a dude
Drives: Scion FR-S 2013
Why justify it to anyone? If any item in general is worth it to "you" so be it. It's your money and you're happy that's all that counts. My two cents on topic.
#58 | |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
I love it when you see people shopping for stuff at shops or even when talking in conversation about 'stuff' that is high quality or commands a high price, and they make the comment, "It's way expensive and way overpriced" What some body should say to them is, "It's too expensive.. for you."
[CENTER]
Build thread |
#59 |
Just a dude
Way worse things out there to spend money on that's not good for you. Smiles are good for everyone. Have a good day everyone!
Hoping someone with hood dampers posts some of these cans mounted soon so I can decide whether to add to cart!!
#60 |
Drives: 13 BRZ
I don't have hood dampers on my car (or the catch can for that matter) but looking at pictures I don't see why it wouldn't work. It looks like the Grimmspeed (only ones I looked at) mount using the same bolt as the catch can but I don't think spacing the damper mount up 1/8" will matter. 95% sure it will work with little to no modifaction of either part.
#61 |
Grip>Slip
Got them all installed tonight. I ended up using the PCV on the drivers side and crankcase on the passenger side because of the way the innovate supercharger is plumbed. Because of this I didn't even have to use the coupler to extend to the inlet of the crankcase catch can, the hose connected to the stock intake was long enough.
sorry for the pics, it's late and the flash isn't the best. ![]() ![]() ![]() |
#62 | |
Drives: 2013 Subaru BRZ
But what my question is, what happens when you close the hood? By looking on the pictures it going to be very close fit between the dampers and the bracket for the catch cans. |
The Following User Says Thank You to Andreas83 For This Useful Post: | OICU812 (02-07-2014) |
#63 |
Drives: 13 BRZ
Ah I see what you mean. It does look like the damper lay outboard of the bracket as well though. I guess my assumptions would be more valid if I actually had hood dampers lol
#64 |
Dances with Cones
Drives: 2013 Scion FR-S Raven
I should know this weekend. Picking up my kit tomorrow morning.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD |
The Following User Says Thank You to that_guy For This Useful Post: | kask2_6.0 (02-07-2014) |
#65 | |
Do you have grimmspeed hoodstruts? I am just waiting on feedback if this will work together with hood struts. I will either order the bolt in kit or a universal dual kit depending on fitment. |
#66 | |
Dances with Cones
I'll try to get it installed on Saturday night or Sunday at some point.
#67 | |
Grip>Slip
The only advice i would give is to apply a little lube to the hose barb fittings before trying to fit the hose around it. It will make your job much easier. |
The Following User Says Thank You to xjohnx For This Useful Post: | that_guy (02-07-2014) |
#68 |
AutoX-10/10ths every run
Installed mine just now. No issues with the Grimmspeed hood struts as the mounting bolt provided by Grimmspeed was plenty long, lightweight battery was another matter. I improvised.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
#69 |
Dances with Cones
Interesting you chose to mount the Radium bracket above the Grimmspeed bracket. I was thinking the other way around for mine. Guess trial and error. I'll report back on mine when I complete the install. I'm only doing one side though, so I have a spacer for the other side I'll be using.
The Following User Says Thank You to that_guy For This Useful Post: | whataboutbob (02-07-2014) |
#70 |
I wanted to be sure that the keytab on the strut mount stayed fully engaged to the body so I wouldn't have any rotation issues. It might work the other way around but I didn't try it that way.
DIY | Radium Catch Can | Video | Full Technical Info | Dezoris | DIY (Do-It-Yourself) Guides | 233 | 01-07-2020 02:12 AM |
Catch cans: what are you running? | Apex Chase | Engine, Exhaust, Transmission | 144 | 08-14-2014 07:17 AM |
Rev Works Vented Catch Cans - Need Your Help on deciding color options!! | Rev Works | Engine, Exhaust, Transmission | 20 | 02-06-2014 12:53 PM |
cusco catch cans difference | Silverdub | Engine, Exhaust, Transmission | 15 | 04-23-2013 09:17 AM |
AVO Inlets, Injen Intakes, Cusco Catch Cans, All In Stock! | RallySport Direct | Engine, Exhaust, Bolt-Ons | 3 | 10-05-2012 12:39 AM |
