Old 03-19-2016, 12:50 PM   #6945
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Originally Posted by Dream20b View Post
We're running exclusively e85 on this setup to help keep engine temps down.
my temps were on e85 lol
The Following User Says Thank You to continuecrushing For This Useful Post:
Dream20b (03-19-2016)
Old 03-19-2016, 09:58 PM   #6946
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
I have a question for you guys. This wasn't in the manual, but I can't remove the stock intake manifold because the driver side fuel rail is still hooked up. How do I release it? the manual says nothing about it.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 03-19-2016, 10:00 PM   #6947
riboyster
riboyster's Avatar
Old 03-20-2016, 10:18 AM   #6948
Dream20b
Y u do dis?
you don't have to unbolt the hoses- there's two bolts on each side that hold the fuel injectors in, take those off and you should be ok to get it out.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 03-20-2016, 03:09 PM   #6949
riboyster
riboyster's Avatar
Thanks man.
Old 03-21-2016, 12:38 AM   #6950
riboyster
riboyster's Avatar
Okay, it's in place, drove it around a bit today. So what's up with the hesitation? It's like it takes 2 seconds for some boost valve to decide to open up. Is this normal? I'll try to get a log up for you guys tonight.
The torque before boost is much worse than the 89 octane tune I made with OFT.
Disregard, just being stupid. Car probably just needed to learn the tune some more. Here's a log of a second gear pull, then 3rd gear.
http://www.datazap.me/u/riboyster/sp...ata=1-3-5-8-13
Old 03-27-2016, 04:17 PM   #6951
riboyster
riboyster's Avatar
How practical is it to intercool before getting a 70mm pulley? I live in the tropics.
Old 03-27-2016, 07:04 PM   #6952
Dream20b
Y u do dis?
intercooler is a good idea if average temps are 70+
Dat Hot Lava Doe
Old 03-27-2016, 07:28 PM   #6953
riboyster
riboyster's Avatar
Have any idea how much temp is generated per lb of psi? Daily temps in winter range from upper 50s to upper 80s and summer is lower 70s to upper 90s
Old 03-28-2016, 02:28 AM   #6954
sam69
Drives: GT 86
I have seen intake temp of 80 C working it really hard and that was at 32/33 C ambient and it's intercooled so if you live in the tropics an intercooler I think is a must.
I'm working very hard atm to try and bring intake temps down and looks like it might be working but early days yet .
sam69 is offline   Reply With Quote
The Following User Says Thank You to sam69 For This Useful Post:
riboyster (03-28-2016)
Old 03-28-2016, 03:23 AM   #6955
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Intercooler is better safe than sorry. Same with running a turbo or any forced induction. The more you compress the air, the hotter the air will get.
stockysnail is offline   Reply With Quote
The Following User Says Thank You to stockysnail For This Useful Post:
Old 03-28-2016, 05:10 AM   #6956
Kodename47
Kodename47's Avatar
Drives: UK GT86
What's your idea? Tried a bigger flow water pump for the IC system?
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-28-2016, 02:33 PM   #6957
continuecrushing
for those "F" folk, thats like high 80's, low 90's ambient and 176 intake?!!
What were you doing when this happened? I haven't had mine in super hot weather yet, but in 70's ambient (21c), with a canyon run, I got up to 85F intake (29c) and oil temp to 264F (128c yes, this is without an oil cooler-I've got one now though).
x2, whatcha trying out?
Old 03-28-2016, 02:57 PM   #6958
Kodename47
Kodename47's Avatar
Drives: UK GT86
Where are you taking your IATs from? One of the lads here maxed out just over 82C on track and I reckon ambient would have been ~10-15C. This is taken from the manifold though and not the MAF. Mine hikes more than 10C even on a single pull.
.: Stealth 86 :.
Kodename 47 DJ:
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
