07-30-2014, 03:54 PM | #6875 | |
That headunit though...
Drives: 2013 Subaru BRZ Limited SSM
Cant speak to butt dyno results as I haven't driven the E85 tune for the ESC yet. But it is advised to run a tank of 91/93oct through occasionally when running E85 as E85 can have fewer additives (depending on where you get your fuel) to protect things like your injectors. E85 being an alcohol based fuel is more prone to being corrosive and evaporative. In the past I usually have run a tank of 91oct every 10-15 tanks of E85. I hear there are also aftermarket additives you can use in place of running a tank of traditional fuel that work just as well. Some people claim none of that is necessary, but I like to be safe.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300 Eibach Pro-Kit + Michelin PSS (stock size) |
The Following User Says Thank You to enwave For This Useful Post: | Winjr (07-30-2014) |
07-30-2014, 03:57 PM | #6876 | |
Time Traveller
Same experience here. Run Shiv's e85 tune, no flex fuel kit needed. If for some reason you really want to run a flex fuel kit, you'll also need another tuning platform. My fill-ups generally look something like this. run to fuel light comes on = est 2 gallons remaining add = e85 est 9 gallons add = CA91 est 1 gallon (for improved cold starts and added lubricity). Starts smooth on cold mornings Runs like a champ. AFRs rock solid, and of course the power, omg... the power. |
07-30-2014, 04:18 PM | #6877 |
Drives: WRBrz
EBSC - dt.FF - MXP CompRS
The Following User Says Thank You to WRB5titch For This Useful Post: | DAEMANO (07-30-2014) |
07-30-2014, 05:38 PM | #6878 |
Drives: car
You guys should do a hillclimb test on these things. The long hill climb on that highway out of Denver, CO. would really test the efficiency of this device I think, or even make a run on Pikes Peak with it!
07-30-2014, 05:46 PM | #6879 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Sounds like fun anyone willing to try?
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
07-30-2014, 05:50 PM | #6880 |
I am going to Denver Colorado next week ha ah but unfortunately my method of transportation is a jet
07-30-2014, 06:15 PM | #6881 |
Drives: car
I just know on my stock tune, stock car the hill climb out of Denver was difficult to get speeds above 45-55 mph uphill without the engine gasping.
07-30-2014, 06:20 PM | #6882 | ||
Time Traveller
WOT - MAX power: -The STOCK power numbers are roughly 170 WHP / 135WTQ -The ESC 1.5x + OFT + Header numbers are roughly 200 WHP / 175 WTQ (+30WHP + 40WTQ) -The ESC 1.5x +OFT + Header + e85 numbers are roughly 225 WHP / 200WTQ (+55WHP / 65WTQ) Both HP and TQ differences at WOT are terrific with just the ESC + Header. Add e85 and that difference goes to phenomenal. HP per dollar, the Innovative Stg1 SC kit cant even remotely come close for nearly double the cost. But it goes deeper than that... Remember when driving around town, you're not always WOT. Most of the time it's something under (usually between 3000 to 5000 RPM). I'll call this "area under ESC". This is where e85 is sort of a buried treasure (header helps too). Here, the added mid-range torque is quite impressive and noticeable. In the "torque dip" at 4000RPM: -The STOCK power numbers are roughly 90 WHP / 115WTQ @4000RPM -The ESC 1.5x + Header + OFT numbers are roughly 140 WHP / 175 WTQ (+50WHP + 60 WTQ) @4000RPM -The ESC 1.5x + Header + OFT +e85 numbers are roughly 150 WHP / 200WTQ (+65WHP / +85WTQ) @4000RPM! E85 amplifies the beauty of the Phantom ESC like slapping stilettos on the end of Stacy Kiebler's already ridiculous legs. But it goes even deeper than that... How about non-WOT?: Let's compare Stock vs e85 without activating the ESC at 4000RPM and with the stock header. http://www.ft86club.com/forums/showthread.php?t=55450 -The STOCK power numbers are roughly 100 WHP / 120WTQ @4000RPM -The e85 power numbers are roughly 120 WHP / 150 WTQ (+20WHP +30WTQ) @4000RPM. This is also +15WTQ above the STOCK cars max WTQ number. The transition from non-WOT to WOT driving is smoothed out because the car is producing more torque without boost. Driving around town is a lot more comfortable. At WOT, the fun is just plain silly as the torque ramps up. About gunk in your D.I.s. I have not read about this issue yet on the board. I'd love to hear more about it though. Finally about durability/safety. There's a thread (can't find it at the moment) where there are owners reporting that they are over a year and 30k+ miles on e85 with no issues. It's looking more and more like this cars fuel system was designed to handle the extra corrosiveness and fuel injection needs of e85. Both @WRB5titch & I have ran it with no issues other than cold-start (which is easily resolved with a gallon of pump-gas) and crickets. We are both currently testing Lucasoil Ethanol Treatment as a possible remedy. I'm going to quote another user from IWISTI because he puts it so succinctly. Quote:
07-30-2014, 06:25 PM | #6883 |
Full throttle Electric Supercharger Build Thread
Intriguing to hear that modern E85 isn't extra corrosive. I wonder if regulations in the past few years have required certain additives in E85. That isn't what I've always been taught, but I'm certainly happy to hear it might be better now! Also, most (see: all) engines after 1985 have protection against ethanol damage since standard octane fuels have some mixed in.
EDIT: also, I know my local station runs ~E75 blend in the winter for better cold starts since we have some brutal winters. I've never had to mix in when running it around here, which is extra convenient!
The Following User Says Thank You to enwave For This Useful Post: | DAEMANO (07-30-2014) |
07-30-2014, 06:41 PM | #6884 | |
07-30-2014, 07:06 PM | #6885 |
Drives: 93'Camry, 82'Corolla, 76' Celica
Just a note back to the issue of some problems. I had an early issue in my testing, and Rob was also fantastically good about straightening it out! Now I have had an issue with the parts I developed for my prototype installation.
With multiple days of running around in temperatures, in the 31C (mid 90's F) range, one of my intake system hoses has split open. (a big beafy piece made by Mazda originally) After 7 months of reliable operation, I have to replace this piece, and re-assess how it can be made more durable! This is one simple, rubber hose... not a whole system. I totally get the challenge! |
The Following User Says Thank You to silent runner For This Useful Post: | raven1231 (07-30-2014) |
07-30-2014, 07:19 PM | #6886 | |
Funny. I'll be in Denver tomorrow night. But it's a jet for me too.
The Following User Says Thank You to enwave For This Useful Post: | raven1231 (07-30-2014) |
07-30-2014, 07:23 PM | #6887 |
ha ha yeah I'm not leaving until Saturday. My girlfriends dad and step mom live there and were going to visit them on vacation.
07-30-2014, 07:44 PM | #6888 | |
Drives: 2013 Asphalt 6spd
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
