Old 07-28-2014, 03:24 PM   #6847
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Originally Posted by WNDSRFR View Post
Where is Alberta anyway? On the other side of the earth?
Yes. In the winter you can almost see Santa Claus.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 07-28-2014, 04:06 PM   #6848
raven1231
Man 72 degrees out and humidity is 66. The car feels like a MONSTER. It's a whole different animal is decent weather
Old 07-28-2014, 04:06 PM   #6849
raven1231
Today is a sad day.
I just sent my ESC controller off on a Canadian summer vacation. It got a little tired of the Florida summer heat.
It's going to visit "THE CREATOR" (Rob).
I checked everything on the system that anyone could think of without any results. So Rob told me to send it back for evaluation. Part of his "constant quality improvement program".
He said he would either find out what the problem is and fix it or send me a new one with a new activation harness with the auto relay.
I got a feeling it will be awhile before I see it again. It has to go through customs twice. I was shocked to find out FedEx Ground is $40.00 and you have to fill out a commercial invoice. I wish Rob would move to somewhere more centrally located like Kansas.
I can't even imagine how much it would cost to send a whole system to Australia.
I feel your pain
Old 07-28-2014, 08:43 PM   #6850
Gums
Drives: SWP BRZ
Don't know the shipping cost to Aus as it was included in the kit cost, but delivery only took 4 days and 1 of those would have been due to my 'country' location.
Thank god Canada and Australia have better shipping
Gums is offline   Reply With Quote
Old 07-28-2014, 10:30 PM   #6851
gtfapollo
gtfapollo's Avatar
Drives: Velocity Orange
Wow that's quick, but then again it always seems reasonable whenever i purchase something online from a competent supplier using air freight. I suspect that your shipping was discounted as you were an earlier adopter and a test mule for the RHD version.
God I want one so bad! So bad I say!
gtfapollo is offline   Reply With Quote
Old 07-28-2014, 11:15 PM   #6852
DAEMANO
Time Traveller
Today is a sad day.
It'll be back before you know it. Hang tight bud.
Old 07-28-2014, 11:26 PM   #6853
TM
TM's Avatar
Drives: DGM BRZ 6MT
So my voltmeter display started flickering, flashing back and forth 28.x and 0.00. When I go WOT and activate the ESC, the voltmeter stops flickering and displays the volts as it is discharging perfectly normal. After a couple of pulls, the display stopped working altogether, even when engaged.
I turned off my engine and activated the ESC to see if I can hear it spool up, and it seems to still engaged. Just the voltmeter not displayed.
I didn't do anything to my car recently. Still on the 93 1.5 dump pack tune since 2 weeks ago. What seems to be the problem here?
TM is offline   Reply With Quote
Old 07-29-2014, 12:02 AM   #6854
raven1231
Sounds like just a faulty display. Sucks having these issues arise...
Old 07-29-2014, 02:54 AM   #6855
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
One possible answer is another case of melted or snagged cabling. Have you checked to make sure that all of your black cabling that runs through the firewall is intact and undamaged? The reason I ask is that the flickering between 0.0 and your actual voltage sounds like a shaky connection to the controller could be a culprit. Something to check out if you want to take a look yourself.
Other than that, PM Rob. He'll take care of you -- he has been great so far!
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 07-29-2014, 03:20 AM   #6856
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
These episodes of faulty product are discouraging just a week away from possibly purchasing a used phantom..... is their a warranty and will it transfer over to the new owner?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 07-29-2014, 04:07 AM   #6857
enwave
enwave's Avatar
Full throttle Electric Supercharger Build Thread
Originally Posted by Boofneenee View Post
These episodes of faulty product are discouraging just a week away from possibly purchasing a used phantom that will have no warranty....
I wouldn't be worried about it -- the vast majority of issues (including the couple I had) are due to not being careful enough with installation (battery pack connections not tightened enough leading to awkward dumps and fried controller FETs, wire routing too close to exhaust components or snagging on corner of batteries, etc). Rob is very very good at taking care of any additional issues -- and I feel like he'd probably be very good to work with even with you buying the kit used (though I suppose you may want to check with him first if you haven't yet).
Be ultra careful and have great attention to detail when you install and I suspect you'll have zero problems.
Old 07-29-2014, 04:51 AM   #6858
raven1231
This! Rob stands behind his product. With it being used things might be a little different but when bought new from him it comes with a 1 year warranty
Old 07-29-2014, 07:56 AM   #6859
Gary in NJ
Gary in NJ's Avatar
PLEASE KEEP IN MIND:
The Phantom ESC is in early LOW VOLUME production. For those of us that have worked in the electronics manufacturing industry (aircraft electronic components for me) we know that it is very difficult to obtain consistency and high quality when each unit is essentially hand built. The more humans touch a product, the more likely there will be problems. The only way to weed-out defects is to conduct timely and costly dynamic heat cycle testing (-40/70C). These chambers cost $50k for a small chamber, plus the custom equipment to run the test.
At this writing there have been only 50 units delivered. That's not a lot of build experience. As time goes on, build quality will become more consistent and installation knowledge will improve.
I can tell you from experience that while the sound-tube hole in the firewall is convenient, its not the best location for running wires. You must ensure that the harness does not sag at all at the engine side of the outlet. Best practice is to use silicone to fill the hole (to ensure fumes do not enter the cabin and that the harness is secure) and use zip-ties to make sure that the harness is away from the exhaust manifold.
I have had a failure of the switch harness due to heat damage to the harness. I have also been through a few controllers. Rob's customer service has been OUTSTANDING. I don't hesitate to recommend the product and the company.
But do keep in mind that this is a low volume product. Until production reaches "critical mass" there will be failures. That is the nature of low volume production and that is the nature of modifying cars for horsepower. Rob is committed to supporting his product and your only inconvenience should be living without boost until your parts make their way through customs.
Old 07-29-2014, 09:34 AM   #6860
TM
TM's Avatar
Drives: DGM BRZ 6MT
Holy cows, talk about customer service and support!
I didn't even contact @Robftss yet; posted on here last night seeing if there's a simple fix. Just a few minutes ago, I received an email from Rob saying he'll be sending me an updated activation harness, regardless of the cause.
I'm going to check my car right now to see if there are any obvious melts/snags, but I doubt it, since the ESC seems to still engage and activate, and then reply to Rob's email.
I must say, I am very impressed by the way Rob stands behind his product!
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
