#673 | |
Drives: 2015 Scion Frs
#674 |
Drives: 2014 GT86
I'd say, that if you don't have tanks content of E85 you can trust/rely on and it starts to worry you .. just evaluate getting some flex-fuel kit. That should free you from E85 ethanol content, mix ratio in tank, optimum tune for that worries.
#675 | |
Inless you have installed a flex fuel kit and flex fuel tune the ecu has no indication of ethanol % The fuel trims work purely on the ecu adjisting fuel delivery to try to match commajded afr and measired afr. If you dont have fill flex fuel setup then you need to run petrol on petrol tune and e85 on e85 tune but the tune can only adapt over a certian range of ethanol percent as it has no reference to ethanol percent. If you want that you need to add flex fuel sensor and tune http://www.ft86club.com/forums/showthread.php?t=120397 See here |
#676 | |
#677 | |
Without the addition of flex fuel ethanol sensor the ecu doesnt have any indication of ethanol percent. All it does is compare the measured afr with the commanded afr if its leaner it adds fuel if its richer it removes fuel using the learned fuel trims. When you add ethanol it makes car run leaner as you need 30% more ethanol to achieve the same stoicometric burn as petrol. You get extra power from ethanol in NA car by advancing the ignition timing as ethanol jas a higher octane rating and jence more knock resistant. When you running a dedicated e85 tune the fueling is increased about 30% and the timing is increased up to 10 degrees in places. If you reduce the ethanol % outside the 60-90 range then it doent work well and its possible to damage engine. Eg if you run 50% ethanol you will run way rich as your going to be oitside what the trims can compensate, this can cause issues with lubrication and you will be running way too much timing and you will get consideravle knock, the ecu will attempt to compensate but its getting outside the limits of compensation. |
#678 |
WRBLUE BRZ
Drives: 2016 Subaru BRZ
Seem like avcs affect MBT of E85 as I have tried.
![]() Red,Blue are Wayne's Rom with pulled 1-2Deg above 6800+rpm to reduce knock Yellow,Green are using Tor's avcs with original wayne's timing. Above 5000 rpm torque and hp are significantly different. |
#679 |
Drives: TRD R.S. 1.0 FRS
what other mods have you done to your car? the 190s hps are sexy to see.
#680 |
WRBLUE BRZ
#681 | |
#682 | |
Drives: Toyota GT86
You need to do a few pulls on each tune as well, and discard the ones that have a strange progress.
#683 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
Could anyone help me to understand why cruising and WOT stft and ltft are pretty close to nill, but at idle stft stays low but ltft jumps to 14-16%? Is that typical?
#684 | |
large variations in intake air temps at idle and very low air flows at idle make it difficult to scale that section of maf scale. If you want to reduce that just note the maf volts at idle. then if your seeing +14% in that area add say 8% to maf flow number in those voltage cels or if its -14% remove 8% from maf flow numbers. maybe smooth the adjacent cels by 5% |
#685 | |
Shibby!
#686 |
Hey Steve I read back through our posts and may have missed it, but how or is there a way I could check the commanded afr and the measured afr. Can I check with the OFT? Im assuming the commanded on the e70-75 tune would be somewhere between 10.6 - 10.41 based on my calculations. Going back to your example of e50 in a car which made sense to me except for the rich part. If the commanded afr on the tune is 10.6 - 10.41 then shouldn't the e50 in the tank make the car have a lean exhaust since it has an afr of 11.8? The ecu would have to compensate and add fuel to achieve the e70-75 afr ("go rich command") which would in turn show positive fuel trims.
| Stock FR-S Tune Just Done | Zach3794 | Engine, Exhaust, Transmission | 67 | 11-05-2017 02:01 PM |
| stock BR-Z, much detonation during shifts: tune? | elefunkd | Engine, Exhaust, Transmission | 69 | 07-26-2013 04:20 PM |
| Anyone have a stock tune from Visconti? | Bleevin | CANADA | 3 | 07-03-2013 01:01 AM |
| My Initial (all stock) BRZedit tune | mad_sb | Engine, Exhaust, Transmission | 6 | 02-16-2013 12:20 PM |
| Save stock tune with ecutek? | gdrider77 | Engine, Exhaust, Transmission | 7 | 01-06-2013 12:50 AM |
