Old 11-27-2016, 03:39 PM   #659
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
dear @steve99 or @Shiv@Openflash, what about doing a UEL stage 1.5 maps for the large portion of the community with Catted UEL headers such as JDL ? where timing is halfway between stage 1 & 2 to be on the safe side ?
instead of loosing customers to ECUtek or other tunes?
neilvosko is offline   Reply With Quote
Old 11-27-2016, 04:07 PM   #660
neilvosko
neilvosko's Avatar
YES, for sure, i am waiting on COBB for BRZ... once COBB is avail, its on, their tune was super user friendly and self-tunable AS WELL .
Originally Posted by Yoshoobaroo View Post
This happened in the BMW N54/N55 world too. I ran a Vishnu Procede on my 335i back in the day (Shiv's piggyback). Then Rombinhood showed some work on the forum on open source flashing which through collaboration with Shiv lead to the OFT being developed. When the twins hit the market Vishnu dropped the BMW crowd and left us with unfinished beta maps. I hope this is not what's happening again. They produce good hardware and their tunes are by and large excellent, but their customer service leaves to be desired. As soon as Cobb cracked the BMW ecu, almost everyone jumped onto that ship.
Sent through a series of tubes
Old 11-27-2016, 05:33 PM   #661
phrosty
Lesson is don't buy something if you aren't happy with how it is right at the moment.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 11-27-2016, 07:35 PM   #662
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Ehh, it's been 4 years. I'm doubtful Cobb is interested in this platform,and I don't see much room for the AP between the OFT and Ecutek price wise. It'd be awesome if they did though.
-Josh
Old 11-27-2016, 07:37 PM   #663
neilvosko
neilvosko's Avatar
Oft is solid, great platform for 500 bucks, just requires more tuning for non off, not so "ofs"
Old 11-28-2016, 07:33 AM   #664
alxtheoreo
alxtheoreo's Avatar
Similar due to cat less or similar due to the shape
[sQUOTE=alxtheoreo;2804241]Why don't you start with stg2 EL tune. Considering your setup from previous post, your best bet is to get it tuned via ECUTEK or something more advanced/stand alone.
The OFT UEL tunes are suited for their header & any header that matches their layout (E.G. Tomei UEL or Gruppe-S). Anything else will be off.
Sent from my SM-G930V using Tapatalk
Mostly due to the design of the header. Take a look at the runner lengths, diameters & path.
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
Old 11-28-2016, 09:24 AM   #665
neilvosko
neilvosko's Avatar
quick question, is it more conservative to run 91 stage 2 tune on a catted UEL ? 91 is similar to 93 tune with lower timing ?
Old 11-28-2016, 12:55 PM   #666
alxtheoreo
alxtheoreo's Avatar
I believe so. Especially as the RPMs increase. PM Steve.
Old 11-28-2016, 01:01 PM   #667
phrosty
Stage 2 has AVCS tables designed for catless headers. I wouldn't run it with a catted header. 91/93 won't make a difference here.
Old 11-28-2016, 02:44 PM   #668
neilvosko
neilvosko's Avatar
how is such a big deal if HFC is almost like a straight pipe (maybe 3 HP difference) being treated like a 800 cell restrictive OEM CAT ?
is a HFC that much of a bid deal for Stage 2 with AVCS tables ? Really?
Old 11-29-2016, 12:57 AM   #669
Nah
Drives: 2013 Scion Frs 6mt
No... you won't see much of a power increase at wot unless you're avcs is really off. Daily driving however... you may find better throttle lips, cruising power etc
Nah is offline   Reply With Quote
Old 11-29-2016, 06:21 AM   #670
steve99
Without spending dyno time on each different header setup it wuld be difficult to get something optimum.
You can try the stage 2 catless uel maps on your jdl hi flow cat header, just check for knock, if your not getting significant knock say nothing over -1 occasionally and the IAM is solid at one then you will be fine.
the only difference between the 93 and 91 tunes is 1.5 degrees of ignition timing over about 5000 rpm so try the 91 version first then if ok and your running 93 or better give the 93 version a go.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Nah (11-29-2016), neilvosko (11-29-2016)
Old 04-07-2017, 10:06 AM   #671
timmydatooth
Drives: Scion Frs
how much more aggresive is the stage 2 OFH specific tune compared to the stage 2 off the shelf UEL tune? the reason Im asking is Im torn between getting a OFH3 or a tomei UEL header. Which tune is safer for daily driving and gives better gas mileage? also if anyone can comment on the build quality of the OFH3 compared to the tomei UEL headers that would be awesome. thanks.
timmydatooth is offline   Reply With Quote
Old 04-08-2017, 11:50 AM   #672
RedFRS4me
RedFRS4me's Avatar
Drives: Firestorm '13
I have the OFH2 and love the combo with OFT. I think if you're going for just an OTS tune for safety the OFH3 with OFT will be fine. MPG is mostly effected by your right foot lol. OFT tunes and OFH stage 2 tunes after all are tuned for their header. Tomei or JDL or any similar header will work as well. I just went with the header that best matched the tunes I will ever use which is OTS tunes.
'13 Firestorm
RedFRS4me is offline   Reply With Quote
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 11:56 AM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 01:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
