Old 09-17-2015, 04:55 AM   #659
ravisraval
Drives: 2013 FRS
I've also driven a JRSC equipped car, the two are very different, while the JR is impressive, the power is more of a progressive build up vs the "knock your head back" low end torque you get from the E-force.
The exact reason I'm looking more at the Edelbrock.
Just waiting for first round feedback!
ravisraval is offline   Reply With Quote
The Following User Says Thank You to ravisraval For This Useful Post:
Dadhawk (09-17-2015)
Old 09-17-2015, 01:27 PM   #660
Titanmotorsports
Titanmotorsports's Avatar
Drives: Supra
Send a message via AIM to Titanmotorsports
Waiting on kit as well for our 2014 Monogram FRS
Will release info once its ready.
Titanmotorsports is offline   Reply With Quote
The Following 4 Users Say Thank You to Titanmotorsports For This Useful Post:
Dadhawk (09-17-2015), hmong337 (09-17-2015), ravisraval (09-17-2015), Summerwolf (09-17-2015)
Old 09-17-2015, 03:20 PM   #661
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
After the kit is out and running, I'd love an apples to apples comparison between the Sprintex 210 and the Edlebrock. Heck while we're at it add in the Cosworth and any other positive displacement charger. I'm thinking the Sprintex 335 is a step above the Edlebrock but if I'm wrong add that in the comparison. I need to be convinced with facts before I sell my Sprintex 210 for another unit or just upgrade to the 335.
stockysnail is offline   Reply With Quote
The Following User Says Thank You to stockysnail For This Useful Post:
CK_Bladesmith (09-17-2015)
Old 09-17-2015, 04:00 PM   #662
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Based on blower size you'd be wrong there. TVS 1320 is a 1.32l/rotation while 335 is 1.46l, however max RPMs for the Eaton is 20K while the sprintex is (I believe) 15k This gives a slight edge to the TVS blower assuming efficiency is comparable between the two setups.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
stockysnail (09-17-2015)
Old 09-17-2015, 04:23 PM   #663
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by Decay107 View Post
Based on blower size you'd be wrong there. TVS 1320 is a 1.32l/rotation while 335 is 1.46l/rev, however max RPMs for the Eaton is 20K while the sprintex is (I believe) 15k This gives a slight edge to the TVS blower assuming efficiency is comparable between the two setups.
Take a look at what the 'out of the box' TVS 1320 units are doing vs moto-mikes 335 dynos. That 335 is just a beast, but maybe those TVS units have a ton more potential in them.
bfrank1972 is offline   Reply With Quote
Old 09-17-2015, 04:32 PM   #664
Decay107
Decay107's Avatar
Yeah the 335 stuff has been impressive, but I don't think anyone has received an edelbrock yet for testing and the only dynos are CARB setups running on green pisswater. moto-mike has 93 and no such emissions restrictions.
bfrank1972 (09-17-2015)
Old 09-17-2015, 05:04 PM   #665
bfrank1972
Very good point, although I think all he's been trying to do is dumb the thing down so it won't bend the stock rods! I'm definitely interested in what the TVS 1320 can do - I'm a big fan of the TVS units and have been asking for one for two years now
Old 09-17-2015, 05:54 PM   #666
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I'm just getting up to speed on this, and it's really exciting to see such big players offering bolt on SC kits for these cars. I'll be saving my pennies.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 09-17-2015, 06:17 PM   #667
Cosworth/Edelbrock/335 is in a whole different league from the 210.
On paper, the TVS 1320 is supposed to be able to flow more, while simultaneously being more efficient; for now I'd give the (slim) edge to Cosworth/Edelbrock.
I don't forsee a Cosworth kit in California for me to test and log anytime soon... but if you guys can round up a volunteer, I'll put it through its paces and publish my findings.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Decay107 (09-17-2015), sato (09-17-2015), stockysnail (09-17-2015)
Old 09-17-2015, 06:35 PM   #668
sw20kosh
Drives: 2013 Black FR-S
My sprintex 210 on 91 octane only made 10-15 more whp than my current NA setup (ACE header + E85)...
Like @CSG Mike said, completely different leagues.
Old 09-17-2015, 09:24 PM   #669
stockysnail
Just the tip
Interesting. Mine made about 60hp ish more compared to catless UEL non-supercharged setup. I guess you are on E85 without the supercharger compared to supercharger without e85.
Old 09-17-2015, 09:28 PM   #670
stockysnail
Just the tip
I guess I was thinking the 210 may be closer because the CARB kit from Edlebrock is only making around 235whp compared to my 210 kit making over 250whp or so.
Old 09-17-2015, 09:49 PM   #671
sw20kosh
All forced induction kits will be limited on pump gas. They reach a knock threshold and then need higher octane to make more power if they have the flow capacity to do so.
The edlebrock is much bigger than a 210 and thus with more octane can safely make much more power. Carb tunes of JRSC and Edlebrock will be conservative and consistent vs. a (I assume) custom tuned setup like yours.
Even when I was turbocharged, I was limited to ~280 whp on 91 octane. E85 unlocked 400whp on that same kit. On the 210 I was limited to 222 whp on 91 octane. Never tried e85.
Add e85 into the mix and the 210 will reach its flow limit before any of the other mentioned kits.
The Following User Says Thank You to sw20kosh For This Useful Post:
CSG Mike (09-17-2015)
Old 09-18-2015, 02:29 AM   #672
stockysnail
Just the tip
So basically swap engines (no replacement for displacement) or run e85 if I want more power is the basic moral of the story.
CSG Mike (09-18-2015)
boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 06:09 PM
X-Force 3" Exhaust mwjcyber Engine, Exhaust, Transmission 19 03-13-2017 02:55 PM
The force is strong with this one (2015 STi) blackhawkdown FR-S / BRZ vs.... 39 08-01-2014 01:26 AM
X force or Invidia N1 JakeG AUSTRALIA 8 01-18-2014 05:16 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 02:24 PM
