Old 09-09-2016, 08:18 PM   #659
steve99
Originally Posted by Tor View Post
As I mentioned it was just for a test, because I am trying to write a simple guide in German.
By the way, how comes that OTS or Wayno's ROMs are not based on A02G?
What are the differences between A01G and A02G anyway? I tried searching for that but didn't find anything.
A02G and A02I were only released in australia i think, they were another attempted idle stablilty fix with air conditioner switching. not much in it rearly.
looks like just changes to undefined tables.
the tables in A01G and A02G are same so you can just copy across all the tuned tables to an A02G it you want to.
OFT guys get a bit "lazy" and its less work for them to just alter the calid than make up a whole new series of roms.
I run an A02G rom but i dont think theirs any real advantage.
We have now found that you can put A01G roms even in the latest 2016 cars with F20P or F10G roms and they run fine. The reason people did this was for logging with Tactrix.
Tor (09-10-2016)
Old 09-09-2016, 08:40 PM   #660
steve99
Added RomCalidCheck windows utility to first post
Old 09-09-2016, 08:43 PM   #661
lizbrayan
Drives: '15 Scion Frs Steel
Yes you can flash B01C roms to A01C cars, B01C is latest factory base map for those cars
So just load up the B01C rom and flash it even tho he still has his stock A01C rom?
Sent from my SGH-T999N using Tapatalk
lizbrayan is offline   Reply With Quote
Old 09-09-2016, 08:46 PM   #662
steve99
Yes the A01C rom is outdated their is a toyota/subaru TSB out to update all cars earlier than B01C to the B01C rom.
ie 700C,900C,A00C,A01C,B00C should all be updated to a base B01C rom.
Old 09-09-2016, 09:06 PM   #663
lizbrayan
If when i read his ecu the a01c came up that means that toyota or subaru didnt update his car right? So his ecu is okay to take the b01c rom even tho it was never updated?
Old 09-09-2016, 09:17 PM   #664
Ralle109
Ralle109's Avatar
Drives: Toyota GT86
Maybe stupid but where is a official Tread/source of waynos Tunes?
And is it possible to get LC and FFS with Waynos Tunes?
Ralle109 is offline   Reply With Quote
Old 09-09-2016, 10:30 PM   #665
steve99
try here
http://www.ft86club.com/forums/showthread.php?t=83945
luckly your in germany and use same rom calid as australia so you can use those thunes attached to post.
if the original oft tune had lc\ffs patch then so will wayneo,s tunes they started off as oft tunes
only roms up to A01G have lc\ffs patch after that no lc\ffs patches on roms like D00G
those patches only for manuals.
guys have flashed A01G to newer cars with D00G or F20P rom and all seems fine but do so at own risk
dont try to put newer roms like D00G in older cars you will get problems
Ralle109 (09-09-2016)
Old 09-09-2016, 10:32 PM   #666
steve99
Yes A01C should be updated, dealers dont do it inless you winge bleat and complain about idle problems or get the cam issues, but best to update older roms to B01C
Old 09-09-2016, 11:26 PM   #667
Ralle109
Ralle109's Avatar
Drives: Toyota GT86
try here
thanks I found those tread, but i simply overseen the tunes
The Following 2 Users Say Thank You to Ralle109 For This Useful Post:
AP756 (09-16-2016), steve99 (09-10-2016)
Old 09-16-2016, 11:14 AM   #668
Ralle109
Ralle109's Avatar
Drives: Toyota GT86
Finaly flashed waynos tune successfully
Also done a 4.gear wot but ecu not fully learned.
I have some issues with the logging trigger,
I Can't get the defogger trigger working.
Maybe problem with the customer Klima options?
Also I noticed some "noises" around 3000-4000rpm?
I thought I read about it but can't find the tread anymore
Old 09-16-2016, 04:20 PM   #669
steve99
Triggers are unreliable.
Best to remove all trigger lines from logcfg.txt file.
logging will auto start when ignition on and stop when off
If your running EL header cam timing you will get intake rasp noise arround 4000 due aggressive cam timing
Ralle109 (09-16-2016)
Old 09-16-2016, 04:40 PM   #670
Ralle109
Ralle109's Avatar
Drives: Toyota GT86
Yes, im running Stock El without Cat.
I choose the stage 2 98 map from wayno.
Afr Looks good without any Modifikation.
Something other to observe besides the maf scaling and knock?
Old 09-16-2016, 04:46 PM   #671
steve99
not rearly if knock free (less than -1 corrections occasionally) and AFR follows commanded afr and low ltft. Then pretty sorted
Cam timing adjustments you rearly need dyno time.
Old 09-16-2016, 04:58 PM   #672
Tor
Tor's Avatar
Drives: Toyota GT86
It's easier just to post the log-link instead of a picture:
http://datazap.me/u/ralle109/log-147...zoom=4526-4800
Your LTFT are 0 above 5000 rpm. I would guess you made this log immediately after flashing.
As long as the ECU didn't have time to learn the LTFT you can't really say anything about AFR, as it will change (might be a significant change) once it starts learning the trims. Let it learn for at least 200 km (better 3-400) then make a new log.
Tor is offline   Reply With Quote
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
