Old 04-17-2015, 08:46 PM   #659
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Always depends on where your driving no? I mean up here in WA we would hardly need some of the cooling mods since our weather isnt nearly as warm as SoCal or AZ or FL
Old 04-17-2015, 09:02 PM   #660
I will, once again, reiterate that the melting fan incidents all happened in COLD weather, not hot weather.
In hot weather, when engine output is reduced, heat management was not an issue.
Old 04-17-2015, 09:06 PM   #661
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Originally Posted by sw20kosh View Post
You guys must like spending money...
Max temps: 210 F coolant, 218 F oil after 25 mins of hot laps at multiple tracks in winter and in summer. 60+ psi oil pressure to redline. 5w30. 2 cars with this setup have been running this for a year with 15+ track days.
Your running (IIRC) the ptuning kit which on it's own has great heat managment with the tubo placement being similar location as the AVO's. Alot of us are simply trying to avoid heatsoaking with the front mount style...
Originally Posted by yomny View Post
the only one that I know of that has rain guards as it does rain a lot here in Miami
Both Varis goods have rain guards
Old 04-17-2015, 09:23 PM   #662
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
ah, did not know that lol
The Following User Says Thank You to cdrazic93 For This Useful Post:
CSG Mike (04-17-2015)
Old 04-17-2015, 09:30 PM   #663
What if I told you @sw20kosh went back to NA, and is running faster times than ever at the track....
Sleepless (05-01-2015)
Old 04-17-2015, 09:31 PM   #664
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
what if I told you, he LS swapped it without telling anyone...
Old 04-17-2015, 09:35 PM   #665
It's possible... but I know the LSx swap to not have happened. Yet.
cdrazic93 (04-17-2015)
Old 04-17-2015, 09:41 PM   #666
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
last OT post...
what if I told you it wasn't just 1 LS engine...
http://www.lsxtv.com/news/the-ls12-t...v12-ls-engine/
Old 04-17-2015, 11:00 PM   #667
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Then the temps and info he posted would have been less impressive.
Old 04-18-2015, 01:32 AM   #668
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Getting faster is much more about the driver than the car. I think we have all learned that. 500hp helps a lot, though.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Ultramaroon (04-18-2015)
Old 04-18-2015, 05:24 AM   #669
sw20kosh
Drives: 2013 Black FR-S
The temps posted are while FI.
Old 04-18-2015, 09:40 PM   #670
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
I have actually had the same result!
The Racers Line is offline   Reply With Quote
Old 04-19-2015, 12:20 AM   #671
Old 04-26-2015, 03:09 PM   #672
AJPG
Drives: 22RE, FA20, 4G63
WAAAAT???
AJPG is offline   Reply With Quote
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 04:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 11:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 10:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 07:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 02:18 AM
