Old 11-08-2015, 07:30 PM   #6651
sam69
Drives: GT 86
Originally Posted by Chad86 View Post
What is the best oil cooler option? I read the Mishimoto will not fit with the intercooler. Currently looking at the Perrin oil cooler.
http://www.ft86club.com/forums/showthread.php?t=41615
I put one of these on about a year ago and are happy with it no real problems ..... http://www.ebay.com.au/itm/Thermosta...UAAOxyJX1S-zZt
Just let him know what car it's for so he can supply the right extension fitting for the sandwich plate.
The only other thing I did was to clean up the ports in the sandwich plate a bit to improve the flow.
sam69 is offline   Reply With Quote
Old 11-09-2015, 03:01 PM   #6652
Dream20b
Y u do dis?
Originally Posted by Chrisbrz14 View Post
12.8? Not bad at all man. What have you done to your transmission?
Nothing at the time of pass, upgraded clutch now.
Originally Posted by bfrank1972 View Post
Holy crap 109 mph trap? Pretty impressive on a 210.
thanks, I have a 110 pass but its .001 sec slower.
hoping for low 12s on a slick.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 11-09-2015, 08:55 PM   #6653
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Get the Perrin unit if you get one. Fits just fine, and thermostatic for those in the winter climates. Even with the smaller heat exchanger we have had no issues with oil temps even doubling up during a track day where we're essentially running the car 40/60 minutes then over again. With that and the Koyo radiator the car is rock solid with the SC on track.
Xero-Limit is offline   Reply With Quote
Old 11-11-2015, 10:12 AM   #6654
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by SprintexUSA View Post
We have officially unveiled the plus blowers, too. Sub-assemblies and kits will be on sale shortly. The blowers themselves arrived right before SEMA. We will need to build the first few sub-assemblies in OKC.
any links for more info? How will the sub assemblies work as far as swapping out? Pricing?
Old 11-11-2015, 04:47 PM   #6655
SprintexUSA
SprintexUSA's Avatar
Drives: 2014 FT86
I'll have sub-assembly prices after we build a few.
No trade-in options.
SprintexUSA is offline   Reply With Quote
Old 11-11-2015, 06:35 PM   #6656
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Interesting numbers for those considering the Ford GT350/R compared to our cars and boosted versions of our cars.
Ford GT350R
Stock built flatplate crank V8
Cost: $65k
Car Lbs: 3700
WHP: 448
WHP e85: 520
Crank hp 92oct: 526
lbs/hp 92oct: 7.03
hp/lbs 92oct: 0.14
Ford GT350
Cost: $50K
Car Lbs: 3800
WHP: 448
WHP e85: 520
Crank hp 92oct: 526
lbs/hp 92oct: 7.22
hp/lbs 92oct: 0.14
Stock BRZ/FR-S
Stock boxer 4
Cost: 25-28k
Car Lbs: 2750
WHP: 165
WHP e85: 190
Crank hp 92oct: 200
lbs/hp 92oct: 13.75
hp/lbs 92oct: 0.07
FI BRZ/FR-S
Sprintex 210 70mm
$25-$28k + $4.7k = $30-$33k
Car Lbs: 2750
WHP: 250
WHP e85: 285
Crank hp 92oct: 285
lbs/hp 92oct: 9.65
hp/lbs 92oct: 0.10
FI BRZ/FR-S
Sprintex 335 85mm w/ clutch
$25-$28k + $5.9k = $31-$34k
Car Lbs: 2750
WHP: 290
WHP e85: 330
Crank hp 92oct: 333
lbs/hp 92oct: 8.26
hp/lbs 92oct: 0.12
Built motor FI BRZ/FR-S
Sprintex 335+ 80mm w/ supporting mods
Car Lbs: 2750
WHP: 350
WHP e85: 400
Crank hp 92oct: 402
lbs/hp 92oct: 6.84
hp/lbs 92oct: 0.15
stockysnail is offline   Reply With Quote
Old 11-11-2015, 08:32 PM   #6657
Xero-Limit
Xero-Limit's Avatar
Another measure is the 60-100 time, which is fairly easy to obtain, and allows you to do it in 4th entirely and avoid the errors in measurement caused by shifting. Results on our 335 equipped car? Low 5's on e85. That's pretty damn quick, GTR territory, faster than CTS-V, which was our exact experience passing one on the straights at NJMP last week, and on the 85mm pulley!
This measurement is nice because your EcuTek log will measure it, and also because it summarizes the area under the curve (~4000-7500 in 4th) and gives a better representation of overall usable power. This is where the SC really shines, especially with a header/exhaust where you're not dropping off as much at the top.
Old 11-11-2015, 09:46 PM   #6658
dhsean
Drives: 2013 White FRS
I have the Mishimoto oil cooler with my 210 kit with intercooler. The shop machined some custom brackets to mount it next to the intercooler just in case you want to make the Mishimoto oil cooler work.
dhsean is offline   Reply With Quote
Old 11-11-2015, 10:48 PM   #6659
stockysnail
Just the tip
The more you talk the more I want to update my 210 to the 335. I better get a decent year end bonus and tax return to cover the clutch, 335 upgrade kit, and flex fuel package.
Old 11-11-2015, 11:04 PM   #6660
azynneo
quick question, in the manual it says there a glass where you can read your oil levels? All I see is a screw and no glass whatsoever?
azynneo is offline   Reply With Quote
Old 11-12-2015, 02:17 AM   #6661
stockysnail
Just the tip
The older models like mine don't have the sight glass in the front. New models like my friends do.
Old 11-12-2015, 03:52 AM   #6662
azynneo
so the only way to check it is to use the dipstick with the nearly invisible oil?
Old 11-12-2015, 05:54 AM   #6663
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Pretty much :/
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 11-12-2015, 11:02 AM   #6664
smudge
Drives: Supercharged GT86
Wait until next weekend and you'll see my 210 vs 335 comparison
smudge is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
