Old 11-01-2015, 02:34 PM   #6637
SprintexUSA
SprintexUSA's Avatar
Drives: 2014 FT86
Sorry to be so quiet. We will have some SEMA updates during the show. Come by and visit if you are around. Booth #21549.
The fuel mileage sounds pretty normal for those that have chimed in.
We should also have an array of oils to update on before too long.
In the meantime, here is a little custom eye candy to look forward to at the show. This is Mico Motorsport's twincharged '15 STI build. (I don't have a dyno sheet.)
SprintexUSA is offline   Reply With Quote
The Following 2 Users Say Thank You to SprintexUSA For This Useful Post:
Chad86 (11-07-2015), sato (11-03-2015)
Old 11-03-2015, 09:48 AM   #6638
xjohnx
Grip>Slip
xjohnx's Avatar
Nice, can't wait to hear what you've guys got to announce this week.
sato (11-03-2015)
Old 11-03-2015, 03:12 PM   #6639
jwvand02
Drives: 2013 SWP BRZ Limited
Originally Posted by cshearer View Post
[COLOR=black][FONT=Verdana]I had another smoke test done and the only leak they found was on the fastener that seems to hold 1 side of the actuator butterfly valve (see attached pic). Although it is a small leak I am wondering if it could be causing some of the below 3K RPM hesitation. Has anyone else encountered this leak? I am not sure how it can be sealed?
I had a smoke test done today, and they found a leak coming from the back of the BPV and they think it's coming out where the arm is fixed to the back casting. Anyone seen this and had success fixing leaks back here? I'm hoping maybe tightening the nut will do the trick, but I'm afraid I'm going to have to build a homemade smoke tester before I can really asses the fix. I don't want to spend another 70 bucks just for a maybe fix.
Gonna give @SprintexUSA a call today and see what they think.
jwvand02 is offline   Reply With Quote
Old 11-03-2015, 08:16 PM   #6640
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
That is really close to the fittings that are known leaks. Have you addressed the issues with the fittings yet? The plastic 90 degree one is usally the main culprit.
Old 11-04-2015, 09:54 AM   #6641
Dream20b
Y u do dis?
Going drag racing on Saturday, weather permitting, best previous pass was 12.8@109 on All seasons, Going to use slicks this time (hopefully borrowing a pair), I'll keep you all posted.
Mods- E85, 70mm pulley, 210 kit, tomei EL header and Perrin 2.5" resonated CBE exhaust
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 11-04-2015, 12:48 PM   #6642
jwvand02
Yes, they've all been replaced with brass fittings and teflon taped.
Old 11-04-2015, 12:50 PM   #6643
jwvand02
Anyone have a log handy that they can post? I want to just compare to one of mine and see if I can gather any more clues. I can't get rid of this damn P2096 code even after replacing all of the exhaust gaskets, re-sealing the blower and replacing the rear fittings.
I want to figure out once and for all if this is really extra intake air related or not. Short term fuel trims at idle are all out of whack but fine under power.
Old 11-05-2015, 09:31 AM   #6644
Chrisbrz14
Chrisbrz14's Avatar
Drives: Subaru Brz
12.8? Not bad at all man. What have you done to your transmission?
Chrisbrz14 is offline   Reply With Quote
Old 11-05-2015, 10:44 AM   #6645
bfrank1972
Drives: 2013 FR-S Argento
Holy crap 109 mph trap? Pretty impressive on a 210.
The Following User Says Thank You to bfrank1972 For This Useful Post:
Dream20b (11-09-2015)
Old 11-07-2015, 03:50 PM   #6646
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Originally Posted by Chrisbrz14 View Post
today i changed the oil in my car and checked the blower oil as i normally do. i noticed the oil level a little low. I know sprintex uses a redline gear oil but no local shops sell it in my area so id need to order it. Id really rather not, but could i use the equivalent royal purple oil to top it off? I want to try Jon bonds oil but was waiting for more input from @SprintexUSA does anyone use it yet?
I'm running the straight TriboDyn 75W90 until the warranty runs out and then might run the JB Performance afterwards for improved performance.
http://jonbondperformance.com/index....&products_id=6
Originally Posted by Iamwu View Post
With the JB oil, is there significantly less oil consumption?
Redline burns so quick in my blower...it's my only gripe with the setup..
That, and the fact that the dipstick is so damn difficult to read from, and requires the rear to be jacked a foot to level.
I read the Tribodyn burns much less.
Originally Posted by CarzCarzCarz View Post
I don't get to do much highway driving as my job is only 5 miles away and that's all street driving. So I get about 20-22 average. Using Delicious 9.0 currently. My fuelly records:
http://www.fuelly.com/car/subaru/brz...arzcarz/272093
How do you get stats for fuelly? Is this via your ODB2 port?
Chad86 is offline   Reply With Quote
Old 11-07-2015, 05:21 PM   #6647
SprintexUSA
Drives: 2014 FT86
ow...my feet...
Old 11-08-2015, 12:22 PM   #6648
smudge
Drives: Supercharged GT86
Originally Posted by SprintexUSA View Post
ow...my feet...
Quit whining! (no pun intended )
I wish I was there, maybe next year
smudge is offline   Reply With Quote
Old 11-08-2015, 02:18 PM   #6649
SprintexUSA
Drives: 2014 FT86
lol. That was a slam-bang trip for sure. This year had a lot more people moving more quickly. The crowd was a swarm that came in waves. We had 11 people in the booth and all were busy.
We have officially unveiled the plus blowers, too. Sub-assemblies and kits will be on sale shortly. The blowers themselves arrived right before SEMA. We will need to build the first few sub-assemblies in OKC.
Old 11-08-2015, 06:28 PM   #6650
Chad86
Chad86's Avatar
Drives: Toyota GT86
Question
What is the best oil cooler option? I read the Mishimoto will not fit with the intercooler. Currently looking at the Perrin oil cooler.
http://www.ft86club.com/forums/showthread.php?t=41615
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
