Old 08-26-2016, 08:59 PM   #645
steve99
Originally Posted by 86socal View Post
I just read this whole thread and I just want to make sure that the new stage 2 ofh tune is ok to use with E85, thanks in advance
If their is an E85 tune for your rom calid then your good to go.
Old 08-26-2016, 09:02 PM   #646
steve99
Originally Posted by RichardJ View Post
Hey guys,
I'm doing the usual tweaks for every tune I'm going to load on my OFT, just came across the Stage 2 OFH specific tune.
I'm trying to implement the usual values for the quiet cold start, the exact same as seen in steve99's post.
According to his post, the tables that require editing are the following:
-Ignition Timing Post start
-MAF Correction After Start (In-Gear)
-MAF Correction After Start (Neutral)
-Idle Control
-and turning off the P050B Engine light..
It seems that both the MAF Correction tables are absent.
I triple checked that I am using the correct XML definition- ZA1JD00D.
Would I still achieve a quieter cold start with these tables alone?
Any help is appreciated
Yep the MAF correction after start tables and load limit tables are not in the standard oft defs.
Thet are probably in wayno's defs attached to his post.
if you don't do the maf offset tables the car will still idle very high even if you change the idle target tables.
however the oft guys do different calid changes to roms so check a few tables in your tune if your using wayno's defs and make sure everything looks ok, if theirs any weird values don't edit your tune. see the romraider tips link below
Old 08-30-2016, 10:02 PM   #647
phantasticity
Ricer
Is this like flex fuel? What happens when you changes gas? Since there is only 1 file.
phantasticity is offline   Reply With Quote
Old 08-30-2016, 11:02 PM   #648
everythingsablur
everythingsablur's Avatar
Drives: 2016 Scion FR-S RS 2.0
If you change fuels, you have to drive a bit until you see fuel trims drop, pull over, them flash the appropriate tune for your fuel.
Sent from my ONE A2005 using Tapatalk
2016 Scion FR-S Release Series 2.0 #170/1000
everythingsablur is offline   Reply With Quote
Old 08-30-2016, 11:04 PM   #649
phantasticity
Ricer
There is only 1 file for the new Stage 2OFH files.
No specific files such as 91, 93 or E85. Just 1 file.
Old 08-30-2016, 11:18 PM   #650
everythingsablur
Ah right right. If you read the readme file included with it, it states that it is for 91 or (better yet) 93 octane gas. So they do not include an E85 specific tune. Maybe contact Shiv if your looking for one, or just use the standard Stage 2 E85 EL/UEL tune.
Old 08-31-2016, 02:36 AM   #651
steve99
yes the new ofh specific tune were for good 93 fuel only
their was no update to the e85 tunes just use the ver 2 e85 tunes if you want to run e85
oft guys are currently testing flex fuel tunes theirs thread on it here so untill flex is released you need to reflash to change fuels
Old 11-15-2016, 01:53 AM   #652
KHANrad_SIN
Drives: Whiteout
So according to some posts in this thread the new Stage 2 OFH tune has to be run on 93 oct fuel, but in the release notes in the Stage 2 OFH tune (downloaded from the openflash website) it says to use either 91 or 93 oct fuel. Which is correct?
KHANrad_SIN is offline   Reply With Quote
Old 11-15-2016, 02:33 AM   #653
Nah
Drives: 2013 Scion Frs 6mt
Those maps are more aggressive so 93 is preferred however, i'm sure ourecu would adjust and pull timing to protect your motor. I'd probably use 93 just to be safe...
Nah is offline   Reply With Quote
Old 11-15-2016, 06:12 PM   #654
KHANrad_SIN
Drives: Whiteout
Yeah I was on the Stage 2 OFH tune but it just didn't feel right so I just flashed the Stage 2 UEL 91 oct tune instead just to be safe.
Old 11-26-2016, 10:49 PM   #655
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
Issue with stage 1 is based on the info provided the map is for EL and most of the aftermarket headers are uel
Originally Posted by G-awesome View Post
The OFH tune is aggressive for a catted UEL header. I have the JDL one and I've done a bunch of testing on it as well as the stage 2 oft. The stage 2 oft will work but it'll knock a bit around mid to high rpm. You will have to datalog and test to remove timing at the high knock areas. Best to stick with the stage 1 if you don't want to do some additional tweaking to the oft stg 2 tune.
neilvosko is offline   Reply With Quote
Old 11-26-2016, 11:29 PM   #656
alxtheoreo
alxtheoreo's Avatar
Why don't you start with stg2 EL tune. Considering your setup from previous post, your best bet is to get it tuned via ECUTEK or something more advanced/stand alone.
The OFT UEL tunes are suited for their header & any header that matches their layout (E.G. Tomei UEL or Gruppe-S). Anything else will be off.
Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
Old 11-27-2016, 07:52 AM   #657
neilvosko
neilvosko's Avatar
Is it safe to pull like 1 or 2 degrees from 5000 rpm onward as a precautionary strategy? Curious on how much timing you pulled and where?
QUOTE=DarkSunrise;2674084]I was curious today and compared the OFH tune vs. UEL v2.076 in RomRaider, trying to see why it was running leaner. I didn't see any changes in MAF scaling, but the base timing, IAT timing compensation, timing advance, intake/exhaust cam advance and AFR targets had all been tweaked. I'm not an expert but the OFH tune appears to be designed to run leaner and with more ignition timing, but also with additional dialing back of timing to compensate for heat/IATs.
I ended up taking out a little base timing at medium loads in the midrange and at high loads near redline. Drove for an hour afterwards in 90 F weather. No FLKC and minimal KC (random) so things looked pretty good in the logs. Won't know for sure though until I do some repeated pulls later this week.[/QUOTE]
Old 11-27-2016, 12:29 PM   #658
neilvosko
neilvosko's Avatar
Similar due to cat less or similar due to the shape
[sQUOTE=alxtheoreo;2804241]Why don't you start with stg2 EL tune. Considering your setup from previous post, your best bet is to get it tuned via ECUTEK or something more advanced/stand alone.
Sent from my SM-G930V using Tapatalk[/QUOTE]
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 11:56 AM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 01:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
