Old 12-02-2013, 11:07 PM   #645
Rombinhood@OpenFlash
Drives: FRS
Also, if you do use RomRaider, please be kind and donate HERE. The RomRaider team put a lot of work into it
Rombinhood@OpenFlash is offline   Reply With Quote
Old 12-03-2013, 01:17 AM   #646
Tromatic
Can you update and upload ROM's the tablet BEFORE your first connection to the car to save the stock ROM?
Tromatic is offline   Reply With Quote
Old 12-03-2013, 01:34 AM   #647
cnk
Drives: '13 DGM BRZ Limited
IIRC, you can update it, but you can't upload anything until you've read your stock ROM first. That ensures that you only upload a ROM that matches the type of ECU you have.
cnk is offline   Reply With Quote
The Following User Says Thank You to cnk For This Useful Post:
Tromatic (12-03-2013)
Old 12-03-2013, 06:32 AM   #648
PStaff716
PStaff716's Avatar
Drives: 2013 Raven FRS 6MT
ordered my OFT last night
header in the spring, toss some corn in the tank and let's see how close to 200whp we can get this baby
PStaff716 is offline   Reply With Quote
Old 12-03-2013, 07:27 AM   #649
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Rombinhood@OpenFlash - can I request that the link to the Romraider download point to the downloads page on the forum, rather than a static file i.e. here: http://www.romraider.com/RomRaider/Download
The versions are updated regularly, and are uploaded to this page.
Td-d is offline   Reply With Quote
The Following User Says Thank You to Td-d For This Useful Post:
Rombinhood@OpenFlash (12-03-2013)
Old 12-03-2013, 12:02 PM   #650
Tromatic
With the electric SC would be very interesting.
The Following User Says Thank You to Tromatic For This Useful Post:
PStaff716 (12-04-2013)
Old 12-03-2013, 12:12 PM   #651
Drives: FRS
Will do... I've forwarded the request to Vishnu. They should make that change within the hour. A video tutorial for OFT users should come later today too.
Edit: Done!
The Following User Says Thank You to Rombinhood@OpenFlash For This Useful Post:
Td-d (12-03-2013)
Old 12-03-2013, 10:26 PM   #652
ReThink
ReThink's Avatar
Drives: Sc10n FRS "DCLXIV"
I am having some problems with the tablet. Little bit of history: I read my ECU (i also used the options to rotate the display 180 degrees) and when I tried to download the .bin to my computer, the program (version 1.04) crashed stating that the OFT was not initialized. Meanwhile, the OFT went back to trying to calibrate the screen. At this time the screen was black with the serial number, HW rev, and FW rev on the OFT screen. I proceeded to calibrate the screen and started the OFT manager again, the OFT updated, and the software was able to read the "original.bin." I also uploaded the 1.34b to slot 1.
I went back to the car and plugged in the OFT into the ECU and I was greeted with the calibration screen again. I proceeded to calibrate the screen and the OFT interface came up. I tried to click on the tuning icon but the it looks like the information icon was being selected although I was pressing the opposite corner. I was greeted with the serial number of the OFT, HW version, FW version and could not click the back icon.
Several attempts to write to the ECU resulted in the same information screen that I could not back out of.
I disconnected from the OBD and reconnected to the laptop and I was again greeted with the calibration screen and the software crashing because the OFT was not initialized. I finished the calibration and decided to erase everything.
Now when I connect the OFT to the ECU for the initial read, I cannot press the tuning icon as before and only the information icon can be selected albeit from the opposite corner. I tried to click all over the screen and I get a sound that can only be describers as "denied!"
Is there anyway to reset the device back to factory setting because the screen is still 180 degrees rotated so I know that the device was not erased completely. Any help will be greatly appreciated.
Sc10n FRS #0664
ReThink is offline   Reply With Quote
Old 12-03-2013, 10:40 PM   #653
Drives: FRS
When you plug it back into the vehicle (after disconnecting from laptop), do you see the calibration boxes? Or does it go right to the main menu?
Old 12-03-2013, 10:41 PM   #654
ReThink
ReThink's Avatar
The red FRS background blinks on the screen and then the "calibration boxes" routine.
Sc10n FRS #0664
Old 12-03-2013, 10:43 PM   #655
Drives: FRS
Perfect. Just go through the calibration process. But make sure you do it with a stylus and not your finger. If you try to use your finger, the calibration process will not complete since it is too dull.
Old 12-03-2013, 10:44 PM   #656
ReThink
ReThink's Avatar
I was able to get through the calibration using a guitar pick but I cannot select the tuning icon. I will create a video right now so you can see what I mean.
Sc10n FRS #0664
Old 12-03-2013, 10:47 PM   #657
Drives: FRS
I don't think you actually got through the calibration process successfully. Which is why you can't select the tuning icon. Try it again with a ballpoint pen (press gently so you don't scratch the screen). Just make sure you touch inside the box. Just trust me on this
Old 12-03-2013, 10:51 PM   #658
ReThink
ReThink's Avatar
Ok. I only get through 4 calibration boxes before the OFT interface comes up. I will try a pen instead.
Sc10n FRS #0664
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
