Old 09-01-2015, 01:43 AM   #6511
Ultramaroon
not playing cards
Ultramaroon's Avatar
A scoop is not the same as a vent. The hole is facing the wrong direction. All show & no go.
Old 09-01-2015, 01:53 AM   #6512
Cross
It's the Mad Cow
Cross's Avatar
I went with the top secret hood, two vents and one small scoop right in front of the supercharger.
One vent right on top of the airbox so I could remove the top and have it draw air from there and the other to help with getting air out of the engine bay.
I have a picture but it's saying it's too big let me see what I can do
Sent from my SM-G920V using Tapatalk
Old 09-01-2015, 01:31 PM   #6513
Localghost
Drives: 2014 WRB BRZ
Does anyone know where to buy the Stage 1 kit with the CARB tune shipped from the US? I've looked all over, but I'm only seeing vendors selling the tuner version. Thanks
Localghost is offline   Reply With Quote
Old 09-02-2015, 12:16 AM   #6514
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Cool
After doing some more research I now understand this based on how the engine is set up. So obviously this would not be functional at all.
A better option for cooling/venting would be the Varis Arising II. Looks stellar!
I think this hood also comes with rain guards.
Chad86 is offline   Reply With Quote
Old 09-02-2015, 12:33 AM   #6515
s2d4
s2d4's Avatar
Attachment 119270
Don't you won't the vents further back?
It seems your setup draws the cool air out?
Old 09-02-2015, 01:04 AM   #6516
Ultramaroon
not playing cards
Rain guards are essential. I don't have first-hand experience but have been browsing a little as well. I hear the Vis unit is respected.
Old 09-02-2015, 01:05 AM   #6517
Chad86
Chad86's Avatar
Drives: Toyota GT86
Question
Any word back? I assume the JB Performance is a different weight and from the recommendation below it seems to keep your warranty valid you would want to go with the Tribodyn High Performance 75W90
Bump. Maybe @SprintexUSA can chime in on this.
Old 09-02-2015, 06:27 AM   #6518
smudge
Drives: Supercharged GT86
I'd love a bonnet (hood to you Yanks ) that has the central scoop right in front of the pulley so you can see it spinning round and then 2 vents towards the back of the hood on either side to allow the hot air to escape
Doesn't seem to be much on the market
smudge is offline   Reply With Quote
Old 09-02-2015, 12:03 PM   #6519
SprintexUSA
SprintexUSA's Avatar
Drives: 2014 FT86
75w90 is what is spec'd. 50w makes more power according to Jon, but we spec 75w90 during assembly.
SprintexUSA is offline   Reply With Quote
Old 09-02-2015, 08:23 PM   #6520
Chad86
Chad86's Avatar
Drives: Toyota GT86
If the JB Performance is 50w will this void the warranty?
Old 09-02-2015, 08:27 PM   #6521
Chad86
Chad86's Avatar
Drives: Toyota GT86
You have an excellent idea. I would love to see an option to highlight the supercharger!
Here's another option from GAZOO Racing:
http://www.ft86club.com/forums/showt...75#post2378275
Old 09-02-2015, 08:38 PM   #6522
Cross
It's the Mad Cow
Cross's Avatar
One is completely in the AiRaid Airbox so it really can't function as an air removal very well at all but it does provide a good spot to bring in further air, not quite as cool but probably not much worse than ambient. I also wrapped the box in heat tape as well as the tube hoping to negate as much as I could.
The second does get close to the charge pipe so it might have some effect but honestly the under hood temps to the touch and logging have dropped sometimes only as much as 5 degrees but when moving they drop considerably which is nice for that long highway drive home making sure things have cooled off.
I have not gotten the chance to test it on the road course yet, I almost had the chance last weekend but ended up busy working on and tuning a Land Cruise with an LS Swap.
Old 09-03-2015, 04:29 AM   #6523
smudge
Something like this would be ideal, but with the central scoop a bit further forward to allow for the charger to fit and the vents a bit further back
Old 09-03-2015, 10:32 AM   #6524
SprintexUSA
Drives: 2014 FT86
I wouldn't want to be the first one, look at it that way.
We'll have a list of approved oils here shortly. The subject deserves healthy study for customer's sake.
Some folks with custom arrangements hold up for tens of thousands of miles. Others using things like Royal Purple, Harley Davidson oil, or Amsoil have failures almost straight away. It's not fair to just throw them under the bus, though. We don't force you to run one oil or the other. Our blowers even hold up with active engine oiling, but not just engine oil or ATF sitting in the gearcase. GL-5 lubricants are the best options. JB's is great stuff, but not available internationally over the counter at the moment. We'll be fair about it.
Just don't be the guy who disassembles the blower and puts it back together with paper towels in the gearcase. Don't be the guy who fills up his gearcase to the brim and then cooks his unit. Don't be the guy who supercharges a known bad motor then throws us under the bus. Don't race the unit, kill it, and then blame us for your own poor maintenance. Acutal user error is the much bigger problem...
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
