Old 08-22-2016, 06:21 PM   #631
renfield90
The Stig's German cousin
Originally Posted by smg1138 View Post
So, does the Stage 2 OFH (v1.01) tune play nice with the CATLESS JDL UEL header or not? I haven't seen a clear answer yet, but I'm sure I could have missed something. To be fair though, there are 45 pages to sort through now.
My butt dyno noticed a power increase especially at the top end; however I used the JDL exhaust VVT tables, not the OFH tables. Can't remember if the OFH tune modifies the intake VVT tables as well, but if it does I did not copy over that change either as the intake/exhaust tables should be treated as a pair.
You will want to monitor knock and AFRs carefully. This is not a "set it and forget it" tune like the Stage 2.
Old 08-22-2016, 07:19 PM   #632
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
There's a thread on this here you should read through instead: http://www.ft86club.com/forums/showthread.php?t=79059
I do believe there is a VVT edit you do in romraider that makes it run noticeably better with the jdl uels @steve99 would probably know about this.
Old 08-23-2016, 01:23 PM   #633
86socal
86socal's Avatar
Drives: White frs
I just read this whole thread and I just want to make sure that the new stage 2 ofh tune is ok to use with E85, thanks in advance
86socal is offline   Reply With Quote
Old 08-23-2016, 02:01 PM   #634
brz11b
Drives: United States
I really need to get an oft. I have tomei fuel header, tomei op, invidia catless resonated fp, invidia N1 exhaust and no tune. Honestly other then sound I noticed much difference in performance, I'm looking to get the most out of what i have.
brz11b is offline   Reply With Quote
Old 08-23-2016, 02:32 PM   #635
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
You need to prioritize a tune.
The header makes a big difference, and the frontpipe makes a medium difference. The rest of the parts will just help throw the tune off that much more.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 08-23-2016, 06:28 PM   #636
brz11b
It's next on my list foresure. If I can sell some of these stock part I have I'll grab it up soon. Luckily I don't drive it that much.
Old 08-24-2016, 10:25 AM   #637
JazzleSAURUS
Trade that noisemaker, (N1,) for an OFT, or find a local with a Tactrix cable that can flash the OFT tune on for you.
Old 08-24-2016, 09:43 PM   #638
ANTLAY
Drives: 2013 FR-S in Whiteout
Hate to be that guy,but it's been awhile.. what exactly do I need to do to get this update on to my oft tablet? Plugged in to pc and got a update done that and went to site and downloaded the new files,but now I'm lost,lol.
ANTLAY is offline   Reply With Quote
Old 08-24-2016, 09:44 PM   #639
alxtheoreo
alxtheoreo's Avatar
You'll need to remove some older maps on the tablet & upload the new maps.
Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
Old 08-24-2016, 09:50 PM   #640
ANTLAY
Ok, removed one of the El (since I'm uel) and went through and found the bin folder and used the stage 2 uel 93 on that slot, used the one that had same "a01c.bin" assuming that is right how do I save it to that slot
Old 08-24-2016, 09:54 PM   #641
alxtheoreo
alxtheoreo's Avatar
I believe you'll need to scroll down the big partition screen to select save, or whatever the icon(s) say. If there's nothing there try selecting the options to the left.
I'm at the gym right now, so I can't be that precise. Lol
Old 08-25-2016, 05:09 PM   #642
fibble
Drives: 2015 86 GTS
Go to the "Upload" section in OFM.
Allow population of curent tune files - should be around 30 secs.
Use "x" on right to delete unwanted tune file.
Use file browser icon to find and add new tune file.
Once new file is on list, scroll down to the section that says something like "Create tune file".
Hit the "Start" button and wait for completion prompt.
You're finished!
fibble is offline   Reply With Quote
Old 08-25-2016, 06:53 PM   #643
Teseo
Drives: frs
You're finished!
Thanks. I need more instruction like at this with screen shots will be perfect as a moron proof method
Old 08-26-2016, 07:27 PM   #644
RichardJ
RichardJ's Avatar
Drives: 15' FRS
Hey guys,
I'm doing the usual tweaks for every tune I'm going to load on my OFT, just came across the Stage 2 OFH specific tune.
I'm trying to implement the usual values for the quiet cold start, the exact same as seen in steve99's post.
According to his post, the tables that require editing are the following:
-Ignition Timing Post start
-MAF Correction After Start (In-Gear)
-MAF Correction After Start (Neutral)
-Idle Control
-and turning off the P050B Engine light..
It seems that both the MAF Correction tables are absent.
I triple checked that I am using the correct XML definition- ZA1JD00D.
Would I still achieve a quieter cold start with these tables alone?
Any help is appreciated
RichardJ is offline   Reply With Quote
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 11:56 AM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 01:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
