#6315 |
Drives: 86
Some have mentioned that a larger throttle body can get more from the SC
so I was searching for a larger throttle body in the past few days Found this 70 mm http://revo-tune.jp/catalogue/detail.php?id=294 And the TODA Racing http://www.rhdjapan.com/toda-big-thr...6-brz-zc6.html Will these fit the SC? Will they increase the HP or TQ ?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
#6316 | |
Drives: 2014 WRB BRZ
I have a ScanGaugeII that gives me some info on the engine. I also picked up a OBDII bluetooth adapter, but haven't given it a test yet. I'll try running Toque |
#6317 |
Drives: 2014 BRZ (SOLD)
FYI: Just installed Seibon TS Style and no clearance issue.
Supercharged 2014 DGM Limited
#6318 | |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
http://www.ft86club.com/forums/showthread.php?t=28374
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#6319 | |
On your build thread (impressive amount of work, nice), I saw you put the Radium Catch can in. I recently got some, and haven't installed them yet as I didn't know how to run the hoses with the supercharger. Do you know how to run the hoses? |
#6320 | |
Just the tip
Too bad you don't live close as I'd just help you install it. I never saw anything come into the intake side when I had the dual cans so I sold the intake side can. The other can does pick up a decent amount however.And knowing is half the battle, GO JOE!
#6321 | |
Ah another child of the 80's |
#6322 |
Drives: 2013 SWP BRZ
If you have one radium can, run the inlet line of the can (top port) to the PCV on the block. The outlet (side port) will go to the back middle port of the supercharger.
If you have two cans, the same applies as above, but the other can you will hook up the outlet to the intake pipe on the supercharger, and the inlet will go to the line that was previously plugged into the intake pipe. As stockysnail said, page 148 has the photos and layout. http://www.ft86club.com/forums/showt...40066&page=148 |
#6323 |
Drives: 13 Subaru BRZ
#6324 |
Drives: 2013 SWP BRZ Limited
Not sure who to ask this of, figured this might be appropriate.
About two months after installing the SC, I've had a few codes pop up in the last couple of weeks. First, I had P0201 (Injector circuit malfunction, cylinder 1). I noticed some hesitation, the car then wouldn't idle, then after sitting for about two minutes the problem disappeared. A few weeks later, I got P0301 (misfire cylinder 1), but noticed no strange behavior at all, and it stayed gone for about a week once I cleared it. Yesterday, I got P0201 and P0101 (MAF malfunction) together, with the only strange behavior being a bit of a wandering idle. I cleared the codes but they came back in a couple dozen miles. The only thing I can think of is that during install, I didn't realize that the body of the ICU is a ground, and when I went to re-attach it to the crash shield, it arced. I'm going to double check the injector connection at cylinder 1, because the codes popping up continually doesn't seem like it should be a coincidence, but now that there's a random MAF code as well, I'm starting to think something else is up. Any advice? ( @moto-mike , if you'd weigh in I'd appreciate it) |
#6325 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
What injectors? Are you using any aftermarket injector covers on the passenger side? (what the injector controller bolts and grounds to...)
#6326 |
Stock injectors and covers. I'm somewhat tempted to buy a new ICU, but that seems like a pretty strong chance of being a waste of $300. I'm just sort of at a loss as to what else it could possibly be.
#6327 | |
Drives: ft86
for dual can setup you need to connect it different from the instructions? |
#6328 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
