Koji_Online
Old 08-15-2015, 08:19 PM   #617
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by fridayfrs View Post
By hand it doesn't seem to stick. That is what puzzles me. I have been upside down half the afternoon looking at this and I think I'm overthinking it at this point.
That's a little disconcerting. If it only happens while it's running, I'm leaning more towards binding under the bell housing.
Old 08-15-2015, 08:40 PM   #618
Ultramaroon
not playing cards
Any idea what would yield trouble there following this guide verbatim? And why it's not a constant?
The two events might not be connected.
Or, possibly, because travel of the throwout bearing is decreased, it may be hanging up on an already damaged transmission front cover.
There have also been reports of friction plates binding on the input shaft.
It's all conjecture unless the problem can be reproduced at will.
Old 08-15-2015, 09:05 PM   #619
Ultramaroon
not playing cards
Hmm. Well the car has about 1100 miles on it so I'm hoping none of the above applies but who knows with my luck.. I guess I'll undo what I did and see if it still happens tomorrow. I will drive it a little tonight and see if I can pinpoint any specific areas when I go get gas.
When it locks up, do you think you would be able to preserve it in that state long enough to pull over and pop the hood? Sounds whacky, I know. But if you can, it would be worthwhile to check the clutch fork for necessary free play. With the clutch pedal all the way up, you should be able to pull the end of the clutch fork forward to compress the slave cylinder. If you can't, then it's binding down there.
Old 09-02-2015, 07:38 PM   #620
yaguphire
Drives: white-out FR-S
Which way do u turn the rod to have higher engage point. My engagement point is low near the end of peddle travel.
yaguphire is offline   Reply With Quote
Old 09-02-2015, 08:22 PM   #621
Joyride86
Joyride86's Avatar
Drives: 15 FR-S Firestorm MT
I don't quite remember, but you can lay a flat ruler on the brake pedal as a reference point. You'll be able to see the clutch pedal rise/lower better that way.
Diode Dynamics Tail as Turn, LEDs, HIDs | Yospeed Custom Plaque and Frame | Suntek Carbon Tint | Spyder Smoked Side Markers | GrimmSpeed License Plate Relocator and Hood Struts | Five:AD Spoiler | JDM Armrest | Beat-Sonic Backup Cam | Moddiction Anvil 2 | Invidia N2 |
Joyride86 is offline   Reply With Quote
Old 09-02-2015, 08:42 PM   #622
yaguphire
Pedal rising high = higher engagement point?
Old 09-02-2015, 08:45 PM   #623
Joyride86
Joyride86's Avatar
Yup, you got it.
Old 09-03-2015, 12:24 AM   #624
Ultramaroon
not playing cards
I can give it a shot but usually only hear it thunk since my eyes are on the road. In this area we have a lot of sow vehicles/critters. If I'm successful catching it I'll report back.
ETA:
I reversed the modification and the symptom resolved. I ended up just adjusting a little and no binding. I'm assuming I just tightened things a bit too much. Never had burning clutch smell or anything but as they say better safe than pregnant.
I just stumbled across this. Didn't catch your edit. I quoted myself below because I think it speaks to your issue after adjustment. I am guessing that the way you had it adjusted, the piston was not able to fully extend. This keeps the reservoir check valve from opening and causes the clutch to "pump up." Sounds like you were right on the edge so sometimes it opened up and released the pressure with a thud.
For all reading this: The piston in the master cylinder MUST be allowed to fully extend when the pedal is released.
Never mind the arrow in this picture. I took it from earlier in the thread.
As long as the spherical part I painted green is butted up against the clip on the inside edge of the yellow, you're ok.
If the play is irritating, you can take up some with the cruise cancel switch. Just make sure you don't push in the green part.
Old 09-04-2015, 08:01 PM   #625
yaguphire
Strangely I don't have this yellow thing u speak of...
Old 09-04-2015, 08:07 PM   #626
yaguphire
http://postimg.org/image/4umtvyp6p/
Old 09-04-2015, 09:45 PM   #627
Ultramaroon
not playing cards
Old 09-05-2015, 03:01 AM   #628
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Anyone had an issue with adjusting it too far? I did mine so it was flush with the brake pedal. The clutch engagement is almost instant however it is nearly impossible to spin the tires in 1st gear with a 3.5k drop. If I drop the clutch at 3k it grabs and then it takes a few seconds to bring the rpms up. It isn't stalling just seems like a long delay.
I'm thinking I adjusted too far? However the clutch isn't slipping nor is it dragging. I also have no slippage WOT and under power which is why I don't think it is the clutch slipping, and more the engagement point be incorrect. Just wanted some thoughts before I mess with it tomorrow.
Old 09-05-2015, 02:33 PM   #629
yaguphire
Thanks!!
Old 09-05-2015, 03:43 PM   #630
Ultramaroon
not playing cards
Thanks!!
yaguphire (09-05-2015)
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
