Old 09-20-2021, 12:37 PM   #617
willievee
Drives: 2019 BRZ
Originally Posted by Dzmitry View Post
You didn't specify the ET on the wheels, that has just about everything to do with whether it fits. Seems like your wheels come out past the fender quite a bit, hence why there is clearance at the suspension side.
EDIT: Looked it up, looks like ET35, so yeah that makes sense. My 18x8.5 ET38's cleared with a good bit of space left over.
Sorry, they are actually ET42, not the ET35 version. I thought I would need 3 or 5 mm spacers for the front, but they fit as-is.
willievee is offline   Reply With Quote
Old 09-20-2021, 01:07 PM   #618
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
I see. Yeah I would have expected ET42 to be super close to take the risk. But glad they fit for you!
Dzmitry is offline   Reply With Quote
Old 11-03-2021, 04:28 PM   #619
Veypor
Drives: 2015 FRS
Motegi MR139 15x7 +15
Pirelli Winter Ice Zero (Studded) 195/65 R15
Veypor is offline   Reply With Quote
Old 11-04-2021, 06:56 PM   #620
CockpitCruiser
Custom Title
CockpitCruiser's Avatar
Drives: GT86
Originally Posted by DarrenDriven View Post
THE WHEEL DIRECTORY
Eat, Sleep, Drive, Work, Drive, Ride, Eat, Sleep. Repeat
CockpitCruiser is offline   Reply With Quote
Old 12-07-2021, 10:14 PM   #621
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Fun fact: setup clears AP-Racing and RR-Racing BBKs without any modification.
Are there any other suspension mods you had to do?
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 12-13-2021, 12:56 PM   #622
Veypor
Drives: 2015 FRS
No, All stock.
Old 02-01-2022, 08:55 AM   #623
Rich196
Drives: GT86
Can anyone link me to the 86 specific wheel fitment tool that used to be on here? I can't find it anywhere!
Rich196 is offline   Reply With Quote
Old 02-01-2022, 09:38 AM   #624
Jonboy73
Jonboy73's Avatar
Drives: Toyota GT86 GTS
https://www.willtheyfit.com/index.ph...h=8&offset2=35
This should work.
Jonboy73 is offline   Reply With Quote
Old 03-30-2022, 06:26 AM   #625
SCFD
Black Rhino Rumble 15x7 +15 will clear.
https://www.instagram.com/p/CbtevIUsBLR/
SCFD is offline   Reply With Quote
Old 04-09-2022, 10:35 AM   #626
saltywetman
Drives: 2020 Toyota 86 GT 6M
I recall stumbling upon a site or document that had various tire sizes and the % change to speedometer for the twins. Does anyone have the link to the site or document handy? i tried going through the sticky link and a lot of them are down
saltywetman is offline   Reply With Quote
Old 04-06-2023, 09:29 AM   #627
alphasaur
friendly
Drives: 17' 86
Superspeed rf06rr bronze 17x9 38 mm offset 56.1 hub bore
Falken fk510 245-40-17
Touch of negative camber with camber bolts and rear lca
Needed 5mm spacers up front otherwise it'd hit struts (koni yellow and eibach prokit)
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 04-12-2023, 12:08 PM   #628
kraftyone
kraftyone's Avatar
Drives: 2020 Subaru BRZ Limited PP
949 6UL and 245 40 17 yokohama a052 needed 6mm spacer up front to clear pp sachs
Sent from my SM-G986U using Tapatalk
kraftyone is offline   Reply With Quote
Old 04-13-2023, 07:59 PM   #629
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
Ride height and new wheels transforms the 86! Can't go back to stock.
mike_ekim1024 is offline   Reply With Quote
Old 06-16-2023, 06:29 AM   #630
Taurim
Taurim's Avatar
Drives: Subaru BRZ 2016
I wanted to keep suspensions stock and the standard 215/45r17 tyre size.
I spent a lot of time browsing various solution and I finally found one that I really like
ProTrack One 17x7.5 ET 35 :
The wheels are strong and light enough (7.6 Kg / 15.4 lbs)
https://protrackwheels.com/en/wheels/one
Used a lot on race BRZ/GT86 and various other cars (including race M3/M4) at the Nürburgring :
Also used on APEX rental BRZ at the Nürburgring (17x9) :
Taurim is offline   Reply With Quote
brz aftermarket wheels, brz wheels, fr-s aftermarket wheels, frs aftermarket wheels, scion fr-s wheels, scion frs wheels, subaru brz wheels
BRZ/FR-S Wheel Fitment Photo Topic DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-12-2012 04:16 AM
BRZ/FR-S/86 Wheel Fitment Simulators JDMSushi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-05-2012 10:49 PM
Stock Suspension and Wheel Fitment bneale Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 06-29-2012 07:42 PM
Wheel size and fitment bsclywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 03-27-2012 12:34 PM
Wheel fitment sfwg BRZ First-Gen (2012+) — General Topics 6 10-28-2011 06:33 PM
