Old 09-23-2019, 08:10 PM   #603
coolguy1o1
coolguy1o1's Avatar
Drives: 2017 Toyota 86
FR-S / BRZ Wheel Directory, Gallery and Fitment Guide Chart
First set of aftermarket rims for the 86. There enkei rs7 17x7 et42.
coolguy1o1 is offline   Reply With Quote
The Following 3 Users Say Thank You to coolguy1o1 For This Useful Post:
p1l0t (10-10-2019), RToyo86 (05-23-2021), Stonehorsw (05-26-2021)
Old 09-24-2019, 01:42 AM   #604
jredders
Drives: 2017 Subaru BRZ Limited with PP
Originally Posted by COBlue View Post
Winter wheel/tire setup:
Vision Cross 17x7.5 +40 $93 each
I see that Discount Tire carries these for $99 in black, but they claim they don't fit a 2017 Subaru BRZ Limited with the Performance Package, but it sure looks like that's what you have in your picture right? Did you have to add spacers?
https://www.discounttire.com/buy-wheels/vision-cross
jredders is offline   Reply With Quote
Old 12-25-2019, 09:41 PM   #605
jRuN
BC DS Coilovers
Voodoo13 RLCA
Voodoo13 Toe arms
Michelin Pilot Sport 4 S
255/35/18
ESR SR05 18x9.5 +35
Sent from my Pixel XL using Tapatalk
jRuN is offline   Reply With Quote
The Following User Says Thank You to jRuN For This Useful Post:
Old 04-26-2020, 11:17 AM   #606
H_K
Drives: '13 Scion fr-s
I was originally looking at TSW Nurburgrings and Konig Dekagrams and were told these were reps... Is this true? I thought these companies had good reputations.
Which companies aren't considered to make reps but still have affordable options for daily use and occasional track use? Are Enkei RPF1's the only real option without spending $400+ per wheel?
H_K is offline   Reply With Quote
Old 07-25-2020, 09:35 AM   #607
mybrz_au
mybrz_au's Avatar
Drives: 2013 Subaru BRZ Premium WRB
Exclamation Newbie Fitment Question
Hi all,
I am new to the BRZ (FRS and 86) community and interested in buying rims for my (almost) stock '13 BRZ.
Please note I am on STOCK suspension and STOCK struts, I am not planning to change these to coilovers or add lowering springs and would like the fitment to be for fully stock brz suspension (WITHOUT SPACERS)
The size of these wheels and tyres are as follows -
FRONT:
Enkei RS05RR
18x8.5 42 INSET
225/40/18
REAR:
Enkei RS05RR
18x9.5 43 INSET
235/40/18
I have used the (wheel-it-fit) visualiser and it says it will hit the strut, however after reading posts and forums I am even more confused.
I am not wanting to roll fenders, trim or grind struts, not wanting to use spacers or any modifications of that nature.
I appreciate your consideration and keen to hear from you all.
CHEERS!!!
LINKS:
https://enkei.com/shop/wheels/racingrevolution/rs05rr/
mybrz_au is offline   Reply With Quote
Old 07-26-2020, 06:07 AM   #608
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Originally Posted by mybrz_au View Post
Hi all,
FRONT:
Enkei RS05RR
18x8.5 42 INSET
225/40/18
REAR:
Enkei RS05RR
18x9.5 43 INSET
235/40/18
CHEERS!!!
LINKS:
you will take a performance hit running 18's. It is so not worth it. Even though the wheels themselves are a decent weight, the tires will be heavier.
Also you do not want to stagger wheels on this car, especially if you do not want to modify anything else, unless it is a show car that you do not drive daily.
why? is offline   Reply With Quote
Old 08-25-2020, 06:57 PM   #609
sftateofmind
Evening Primrose
sftateofmind's Avatar
Hey folks, wanted to add these to the list as I was looking myself.
Kansei KNPs
18x9 +35 bronze
Continental Extreme Contacts
235/40/18
Silvers Neomax coilovers
1inch drop
No rubbing at all.
sftateofmind is offline   Reply With Quote
The Following User Says Thank You to sftateofmind For This Useful Post:
SP86 (08-31-2020)
Old 08-25-2020, 09:42 PM   #610
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
Ray's Gram Lights 57CR Wheel - 17x9 / 5x100 / Offset +38
Michelin Pilot Sport 4 S 245/40/17
Stock Suspension
SkyeHack is offline   Reply With Quote
The Following User Says Thank You to SkyeHack For This Useful Post:
Stonehorsw (01-19-2021)
Old 01-16-2021, 11:22 PM   #611
CrosshairVictim
Drives: Toyota 86 Gts 2013
2013 Toyota 86 Gts Asphalt
18x8.75 Hussla 030's (basically an Aussie version of xxr 530's)
Offset +40Front +35Rear
235/40/18 PS4's
(Stock suspension ...for now. Soon Eibach Pro or Sport)
CrosshairVictim is offline   Reply With Quote
The Following 2 Users Say Thank You to CrosshairVictim For This Useful Post:
p1l0t (01-24-2021), Stonehorsw (01-19-2021)
Old 05-23-2021, 03:19 AM   #612
Locotoy
Drives: 2014 Scion FR-S
16" Work Equip 05
Work Equip 05
16x8
Fronts are +29mm offset
Rears are +17mm offset
Those are my own measurements, there are no markings in them other than 16x8, as they are 3 piece wheels.
I guess these are one of those few old school wheels that have a 5x100 pcd?
Stock ride height taken last year...
Mildly lowered on TEIN Flex A taken recently...
Locotoy is offline   Reply With Quote
The Following 3 Users Say Thank You to Locotoy For This Useful Post:
Busybee (09-16-2021), RToyo86 (05-23-2021), Stonehorsw (05-26-2021)
Old 05-31-2021, 06:51 PM   #613
CBRZY
CBRZY's Avatar
Drives: 2017 BRZ PP (White)
I have Konig Hypergrams and I love them on the track. Konigs are reps but they are still good wheels, still good reputation. I don't get the problem with people wanting rep wheels. As long as they're not cast wheels, I'm fine with not spending $3000 on something to impress people I don't even know.
CBRZY is offline   Reply With Quote
Old 07-30-2021, 03:45 PM   #614
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Method MR502 (non VT-Spec) 16x7 +30
Method MR502 Rally (non VT-Spec)
5x100
16x7 +30
215/55/R16
Stock suspension
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 09-15-2021, 05:48 PM   #615
willievee
Drives: 2019 BRZ
Apex Racing EC-7R 17x9 ET42 with Continental Control Contact Sport SRS+ 245/40 tires. No spacers. Just barely fits. I read that they wouldn't fit with a stock suspension, but no issues. Maybe because it's a 2020? Should be a non-issue soon once I install coil overs and lower it a touch.
willievee is offline   Reply With Quote
Old 09-17-2021, 11:10 AM   #616
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by willievee View Post
Apex Racing EC-7R 17x9 with Continental Control Contact Sport SRS+ 245/40 tires. No spacers. Just barely fits. I read that they wouldn't fit with a stock suspension, but no issues. Maybe because it's a 2020? Should be a non-issue soon once I install coil overs and lower it a touch.
You didn't specify the ET on the wheels, that has just about everything to do with whether it fits. Seems like your wheels come out past the fender quite a bit, hence why there is clearance at the suspension side.
EDIT: Looked it up, looks like ET35, so yeah that makes sense. My 18x8.5 ET38's cleared with a good bit of space left over.
Dzmitry is offline   Reply With Quote
brz aftermarket wheels, brz wheels, fr-s aftermarket wheels, frs aftermarket wheels, scion fr-s wheels, scion frs wheels, subaru brz wheels
BRZ/FR-S Wheel Fitment Photo Topic DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-12-2012 04:16 AM
BRZ/FR-S/86 Wheel Fitment Simulators JDMSushi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-05-2012 10:49 PM
Stock Suspension and Wheel Fitment bneale Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 06-29-2012 07:42 PM
Wheel size and fitment bsclywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 03-27-2012 12:34 PM
Wheel fitment sfwg BRZ First-Gen (2012+) — General Topics 6 10-28-2011 06:33 PM
