#617 | |
Drives: 2013 FRS
Got a few pounds of turkey to eat and digest first....
#618 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
#619 |
Drives: MR Spyder/GT86
Do you have any tunes on this tablet that work with 98ron european fuel?
#620 | |
| The Following User Says Thank You to jamesm For This Useful Post: | mad_sb (11-29-2013) |
#621 |
Drives: 2013 Asphalt FR-S
You can open un-encrypted roms now, but you cannot save them as un-encrypted.... Such a bummer that epifan is so far behind in adding new table defs... i love brzedit as an editor, logger, log analysis tool... but the defs are so far behind now and you cannot save to un-encrypted format so there is no way to continue using brzedit if you need access to tables the "open" deff tools allow access too.
~Namaste~ |
| The Following User Says Thank You to mad_sb For This Useful Post: | jamesm (11-29-2013) |
#622 | |
![]() Shiv, you need to add the new cranking pulse width tables from Rom Raider to the next xdf. They are in the Za1ja00c git hub deff's. Hit me up if you need them.
~Namaste~ |
#623 | |
Drives: Toyota 86
Code:
<table name="Overrun Fueling RPM Resume Threshold" storageaddress="10E308">
<table type="X Axis" storageaddress="10CEB4" />
</table>
<table name="Overrun Enrich RPM Delta Activation" storageaddress="10C47C" />
<table name="Overrun initial injector enrichment (pulsewidth)" storageaddress="10C480" />
<table name="Overrun Fueling Cut Counter RPM Threshold" storageaddress="10C504" />
#624 |
Maximum puntential
Drives: 2013 DGM BRZ 6MT LTD
@shiv@vishnu
I'm currently using the Stage 1 1.34B map on my otherwise stock car. Working great. However, I'm tempted to pick up a Perrin CAI (not the 3" Big MAF edition that just came out, just the regular one) with all these Black Friday sales going on. Unfortunately I don't have access to a dyno where I live and I assume the Stage 2 map would be too aggressive given I'm still on the stock headers. What would be the best route to take for now, just stick with the OTS Stage 1? |
#625 | |
She said member
Drives: fr-s firestorm
#626 |
Maximum puntential
And I'm sure I'll get the Vishnu headers down the road, but I was able to get the Perrin CAI plus the intake hose from RallySport Direct for $345, which is just a little over what JUST the CAI costs by itself normally. The sale was too good to pass up.
#627 |
Drives: 2015 WRX
Had massive issues getting started this morning on E85. Low of 29 last night and took over 20 attempts to get started. I did fill the tank up the second time the day before so I should have full E85 in there instead of a slight mix of 93 (1-2 gallons) and E85. Might either swap back to 93 until the winter is over or just drive the other car to work when its below 35 degrees outside since the car started just fine the other day when it was warmer.
#628 |
Drives: 85 corolla gts
Malt you need to adjust your cold start fueling for e85 to get it to start easily.
| The Following User Says Thank You to Ross For This Useful Post: | Malt (12-01-2013) |
#629 |
Drives: SWP BRZ
Wow just installed stg1 and what a differenc!!! Thanks shiv!!!
Sent from my SCH-I535 using Tapatalk |
| The Following User Says Thank You to zc06_kisstherain For This Useful Post: | Shiv@Openflash (11-30-2013) |
#630 | |
Drives: 2015 WRX
Our do you have any tips on where to start at? I just left the house an hour ago and had to attempt to crank three times before I got it started and it's only 45 degrees out atm. If I can't get this resolved I'm just going to put the BRZ in the garage and drive my other car on days I have to work because I can't risk not being able to start the car in the morning when it's time to goto work. |
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 02:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 01:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
