Old 11-28-2013, 05:43 PM   #617
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Td-d View Post
For everyone's edification, this is what the idle stability tables look like (the table is a MAP related modification to the targeted idle airflow):
I aim to please
I'll PM Shiv the relevant addresses so he can pass on to the programmers.
Thanks for the info! I'll add it to the XDF for the next release Got a few pounds of turkey to eat and digest first....
Shiv@Openflash is offline   Reply With Quote
Old 11-29-2013, 01:06 AM   #618
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Chuckle, I forgot - happy Thanksgiving to all those on the other side of the pond!
Td-d is offline   Reply With Quote
Old 11-29-2013, 01:04 PM   #619
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
Do you have any tunes on this tablet that work with 98ron european fuel?
GT86meMR2 is offline   Reply With Quote
Old 11-29-2013, 01:57 PM   #620
jamesm
Originally Posted by vgi View Post
so brzedit doesn't allow saving tune in bin format?
maybe you could do your tuning in RR and then load the tune in BRZEdit (diff and copy if needed from your current one whatever you missed)? I remember they posted that they made this feature (loading OFT tunes which is just a bin format) available for personal version?
brzedit is drm hell. i'm pretty sure you can't open just any old rom with it. has to be pulled by their software i think. i've never actually tried, though. i haven't been able to find an option to save an unencrypted bin.
Old 11-29-2013, 02:14 PM   #621
mad_sb
Drives: 2013 Asphalt FR-S
You can open un-encrypted roms now, but you cannot save them as un-encrypted.... Such a bummer that epifan is so far behind in adding new table defs... i love brzedit as an editor, logger, log analysis tool... but the defs are so far behind now and you cannot save to un-encrypted format so there is no way to continue using brzedit if you need access to tables the "open" deff tools allow access too.
Old 11-29-2013, 02:16 PM   #622
mad_sb
Hey, thanks for getting those 3D cranking pulse width tables defined for me... I can confirm they work as of this AM..... E85 - E95 cold start tuning just got WAY easier
Shiv, you need to add the new cranking pulse width tables from Rom Raider to the next xdf. They are in the Za1ja00c git hub deff's. Hit me up if you need them.
Old 11-29-2013, 05:46 PM   #623
ztan
Drives: Toyota 86
I can suggest a potential fix - raising the overrun fueling RPM thresholds 100-200 RPMs higher - in other words, having the injectors kick back on from overrun fueling a tad earlier. Otherwise the idle stability tables can be used.
I don't think these are defined for the OFT yet, but they are in the Romraider definitions I put together:
The switch on is already quite high stock (1300 RPM, compared to an STI for example at 900), but worth a try.
Otherwise, I can take you through the idle stability tables.
Addresses for A01G ROM:
Code:
    <table name="Overrun Fueling RPM Resume Threshold" storageaddress="10E308">
      <table type="X Axis" storageaddress="10CEB4" />
    </table>
    <table name="Overrun Enrich RPM Delta Activation" storageaddress="10C47C" />
    <table name="Overrun initial injector enrichment (pulsewidth)" storageaddress="10C480" />
    <table name="Overrun Fueling Cut Counter RPM Threshold" storageaddress="10C504" />
ztan is offline   Reply With Quote
Old 11-30-2013, 01:56 AM   #624
YMAA
Maximum puntential
YMAA's Avatar
Drives: 2013 DGM BRZ 6MT LTD
@shiv@vishnu
I'm currently using the Stage 1 1.34B map on my otherwise stock car. Working great. However, I'm tempted to pick up a Perrin CAI (not the 3" Big MAF edition that just came out, just the regular one) with all these Black Friday sales going on. Unfortunately I don't have access to a dyno where I live and I assume the Stage 2 map would be too aggressive given I'm still on the stock headers.
What would be the best route to take for now, just stick with the OTS Stage 1?
Perrin CAI + intake tube || Tomei UEL || OFT Stage 2 tune
YMAA is offline   Reply With Quote
Old 11-30-2013, 05:33 AM   #625
no chrome
She said member
Drives: fr-s firestorm
Originally Posted by YMAA View Post
@shiv@vishnu
If you can't resist spending some money on a great deal, catless header and stage 2 is the way to go
no chrome is offline   Reply With Quote
Old 11-30-2013, 09:25 AM   #626
YMAA
Maximum puntential
YMAA's Avatar
And I'm sure I'll get the Vishnu headers down the road, but I was able to get the Perrin CAI plus the intake hose from RallySport Direct for $345, which is just a little over what JUST the CAI costs by itself normally. The sale was too good to pass up.
Old 11-30-2013, 10:07 AM   #627
Malt
Drives: 2015 WRX
Had massive issues getting started this morning on E85. Low of 29 last night and took over 20 attempts to get started. I did fill the tank up the second time the day before so I should have full E85 in there instead of a slight mix of 93 (1-2 gallons) and E85. Might either swap back to 93 until the winter is over or just drive the other car to work when its below 35 degrees outside since the car started just fine the other day when it was warmer.
Malt is offline   Reply With Quote
Old 11-30-2013, 10:49 AM   #628
Ross
Drives: 85 corolla gts
Malt you need to adjust your cold start fueling for e85 to get it to start easily.
Ross is offline   Reply With Quote
Old 11-30-2013, 05:59 PM   #629
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Wow just installed stg1 and what a differenc!!! Thanks shiv!!!
Old 11-30-2013, 08:03 PM   #630
Malt
Drives: 2015 WRX
You'll have to excuse my ignorance on the subject but is there anywhere I can read up on what to change and by how much to resolve this issue?
Our do you have any tips on where to start at?
I just left the house an hour ago and had to attempt to crank three times before I got it started and it's only 45 degrees out atm. If I can't get this resolved I'm just going to put the BRZ in the garage and drive my other car on days I have to work because I can't risk not being able to start the car in the morning when it's time to goto work.
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
