Old 04-14-2015, 04:59 PM   #6259
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
Originally Posted by vaderbloke View Post
Gates got back to me really quickly - they suggested the K061010HD:
Amazon.com: Gates K061010HD Micro-V Belt: Automotive
Any specific reason they suggested that belt over the others?
I just replaced my old belt (it was making a squeaking noise) with another K061015, and it seem to fit fine. This is with 70mm pulley.
CarzCarzCarz is offline   Reply With Quote
Old 04-14-2015, 05:02 PM   #6260
CarzCarzCarz
Originally Posted by SpeedWi View Post
I have not adjusted mine, but I do experience what you are describing. To me it seemed more like the traction control causing it for me most of the time.
It's not traction control, I can tell you that. I also experience the same thing as y'all, but it happens with or without the TC on, and doesn't depend on surface condition either.
The Following User Says Thank You to CarzCarzCarz For This Useful Post:
Chrisbrz14 (04-19-2015)
Old 04-14-2015, 06:03 PM   #6261
vaderbloke
Drives: 2014 Subaru BRZ
The K061015 is recommended for pulleys > 72mm. The K061010 is 12mm (1/2") shorter so that the tensioner is not so likely to bottom out. This is more of a problem with auto-blip and light flywheels. I ran the K061015 with a 69mm for about 2k miles. It broke shortly after upgrading the clutch/flywheel.
vaderbloke is offline   Reply With Quote
The Following User Says Thank You to vaderbloke For This Useful Post:
brzaapi (04-14-2015)
Old 04-14-2015, 06:10 PM   #6262
vaderbloke
Originally Posted by R3NIK View Post
I wonder how the HD compares to the Blue belts I've heard about.
I think the HD is midway in quality between the standard and the RB (blue). You can get K061015 in RB, but not the K061010.
R3NIK (04-14-2015)
Old 04-14-2015, 06:32 PM   #6263
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
I unfortunately have a lightweight flywheel on my car and I believe it contributes to the belts slipping off/failing. I have a hard time not stalling/bogging the car and also can't shift fast enough while WOT between 1-3rd gears. Fuck lightweight flywheels basically.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
The Following User Says Thank You to CK_Bladesmith For This Useful Post:
stockysnail (04-14-2015)
Old 04-14-2015, 07:03 PM   #6264
brianhj
Drives: 2017 Camaro 1SS
Originally Posted by xxscaxx View Post
O rings are meant for one time use (not saying you can't reuse them, but you really shouldn't)...And taking off bolts over and over again will wear them out, they aren't indestructible lol, not to mention you are unbolting steel bolts from an aluminum engine block so anti seize is a must (which should be done regardless).
You can waste your time however you want. I'm just here to remind you of it. It can be done either way, but like I said, it's completely unnecessary. Why disconnect fuel lines over and over again, multiple bolts, clamps, etc. if you can't see how many more risk factors there are pulling off the entire manifold then I don't know what to tell you.
Ok ok good lord. Take off the elbow, it's easier.
brianhj is offline   Reply With Quote
Old 04-14-2015, 07:05 PM   #6265
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
Who's using an aftermarket clutch? Need to hold around 300whp/ 250 tq. Had my car on the dyno this morning and the stock clutch just was not holding. As soon as the torque picked up everything fell off and my numbers were way short.
Innovate powered- Corn fed- FBM tuned
poorsche is offline   Reply With Quote
Old 04-16-2015, 10:17 AM   #6266
vaderbloke
I just installed the ACT clutch kit:
http://www.advancedclutch.com/sb8-hdss
I chose the Street flywheel as I didn't want too much gear rattle. Here are my initial impressions, bearing in mind it still has < 200 miles:
Installation was as straightforward as any clutch.
Pedal pressure is just a bit harder than the stock - very good feel.
Engagement is very smooth.
Bite point was a bit lower than the stock clutch. I will adjust after the break in period.
There is some gear rattle when hot on overrrun and in neutral.
No sign of slip with E-85 and 69mm pulley. The stock clutch would start slipping on anything but pump gas with 75mm.
Stock clutch still looked good after 20k miles - just not man enough for the job
The Following 2 Users Say Thank You to vaderbloke For This Useful Post:
Chad86 (04-18-2015), poorsche (04-16-2015)
Old 04-16-2015, 10:20 AM   #6267
vaderbloke
Originally Posted by sales@delicioustuning.com View Post
Unfortunately not, Custom Map P is an EcuTek custom map and can only be read through there. Torque only measures OEM variables.
Sincerely,
Zach
Is there an "idiot's guide" reading this and other parameters?
Old 04-16-2015, 01:45 PM   #6268
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Act as though you're doing a normal EcuTek log with all the basic parameters that EcuTek already has open in live logging. Below all of these, you'll see an "All Parameters" box which you can expand. Within that list, you'll see "Custom Map P Interim" and "Custom Map P Result". Check those boxes and Custom Map P will give you ethanol content.
Sincerely,
Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
vaderbloke (04-16-2015)
Old 04-19-2015, 08:28 PM   #6269
Chrisbrz14
Chrisbrz14's Avatar
Drives: Subaru Brz
Yeah its not traction control i am glad to hear its not just me.
Chrisbrz14 is offline   Reply With Quote
Old 04-20-2015, 09:13 AM   #6270
Harro
Drives: 2014 Toyota 86
Hello all,
I'm pretty new around here, I've been enjoying the past few hundreds of pages in this thread on the I/C Sprintex S/C. I've had mine on the car for the last 1500km, and love it - its brilliant paired up with lower ratio Final drive 4.556. Just trying to get the low down on this bad boy and any issues that I may come across....
Thank you to those that have had the time to post up issues and their fixes.
Originally Posted by Chrisbrz14 View Post
Has anyone adjusted the vacuum actuator (whatever its called) on the back of the supercharger? Maybe it is just the nature of the supercharger but when starting from a stop up to about 2200 rpms the car is a little jerky. I seem to get a twitch of power after 2200-2300 rpms. Does this sound normal?
Do you get a bunny hop sort of power delivery? Like you're pulsing the accelerator pedal up and down slightly?
Mine has developed this recently - at first I thought it was diff or final drive related, but maybe not...
Harro is offline   Reply With Quote
Old 04-20-2015, 10:27 AM   #6271
brianhj
Yes, it seems the worst around 2k rpm
Old 04-20-2015, 10:33 AM   #6272
CK_Bladesmith
Drives: Raven FR-S
Originally Posted by Harro View Post
Hello all,
Does it do this normally while the car is cold or still once warmed up...?
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
