Old 07-19-2016, 06:32 PM   #603
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Kris86 View Post
My car does not have cruise control, so how will I be able to set and adjust my launch control?
Is it possible to use my hand lever to engage the launch control once I have it pulled up?(e.x once the hand brake light is on)
Launch control engagement is not dependent on CC. It would activate the same as any other MT version. You can still use the defog and accelerator to adjust the RPM too.
*Edit: Zach beat me to it....
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-19-2016, 06:54 PM   #604
Kris86
Kris86's Avatar
Drives: RHD Gt86
Man, customer service is in here on another level
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 07-21-2016, 12:20 PM   #605
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Another F&G done here at JDL
JDLAutoDesign is offline   Reply With Quote
Old 08-08-2016, 07:55 AM   #606
VABeachBRZ
I ordered the Delicious Flex Kit, Map sensor and the JRSC/injector scaling and FF tune!
I'll be running the c38 kit with 700cc injectors, 300cc pump and the FF Kit (e85). I can't wait to try the tune out and see what kind of power it puts down on the dyno
VABeachBRZ is offline   Reply With Quote
Old 08-09-2016, 01:05 PM   #607
Amputechture
Drives: 2014 BRZ
I was just told that the MAF should be completely unplugged or a block off plate should be used...I always just assumed that the MAF readings would be ignored...is this true?
8/10 Edit: I was just informed that the MAF is being used to determine temperature.
Amputechture is offline   Reply With Quote
Old 08-12-2016, 09:16 PM   #608
jainish007
Drives: 2014 Monogram Scion FRS Whiteout
My car just got jackson racing supercharger with delicious tune. And my car currently is stalling when I press clutch in from gear to go to neutral for either red light ir traffic.
jainish007 is offline   Reply With Quote
Old 08-12-2016, 09:57 PM   #609
ft86me
ft86me's Avatar
Drives: 2013 FRS
Contact delicious tuning direct if you are having issues. They can help you troubleshoot.
ft86me is offline   Reply With Quote
Old 08-26-2016, 12:37 PM   #610
Amputechture
Drives: 2014 BRZ
sales@delicioustuning.com, would converting from open wastegate to recirculating require a re-tune? The dumptube life is not for me....
Old 08-27-2016, 01:27 AM   #611
Flashfire88
Flashfire88's Avatar
Drives: Limited Silver
Speed density (assuming you're on it) isn't treated like maf readings so most of the headwork is done by the map sensor, the maf is basically used to measure temps & I think you mean the blow off valve not the wastegate.
-Avo @ 10.5psi-
Flashfire88 is offline   Reply With Quote
Old 08-27-2016, 04:40 PM   #612
Amputechture
Drives: 2014 BRZ
No I am referring to switching from open dump tube to recirculating into the downpipe.
Old 08-30-2016, 01:15 PM   #613
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
The only thing that I see potentially changing is that we may have to adjust duty cycles a tad to hold the same boost levels. You can complete the change, then just send over some WOT logs when you get the chance to be extra sure.
-Zach
Old 08-30-2016, 08:53 PM   #614
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
OKAY REVIEW TIEM!!!!
Last week my turbo kit arrived. Second hand Sydney Motorsport Engineering Borg Warner EFR 6758 kit.
I worked 3am to 11am all week and after each shift, I worked on installing the kit (myself, with poor instructions). Took me three afternoons. I finished Friday afternoon/night. Flashed the car, did some quick logs for Zach and went to bed to start at 3am Saturday morning. Time difference meant 3am my time was the start of the day at Delicious Tuning
From the ABSOLUTE GET GO, the car did exactly that. It went. And it went hard. I could not believe that with a single flash tune, it could go that good.
Did some logs and reviews Saturday morning with no changes needed what so ever (on my old sprintex kit there were a few adjustments needed so I am quite surprised none are needed)
I then proceeded to drive 3 hours up the road with no worries at all. On the way back, I got curious to see how much boost we were making so I connected the OBDII up and we were making like, 8 PSI. I couldn't believe how AMAZING the car runs on just 8 PSI. That's amazing stuff!!
All in all, very very much loving the Flash & Go tune and how it just simply works immediately!!! Very very satisfying
COO86L is offline   Reply With Quote
Old 09-07-2016, 02:58 PM   #615
kevin.nguyen
Drives: Ultramarine FRS
Is there a flash and go tune for the Jackson racing c38 kit with high boost pulley?
kevin.nguyen is offline   Reply With Quote
Old 09-07-2016, 07:56 PM   #616
dp1
driving smoother faster
Drives: Sold
I currently use Delicious FNG tune with C38 and standard pulley and I've been told that, since it's a speed density tune, it will adjust to HBP as is. In a few weeks I will have HBP on C38 with a built engine (designed for >400whp and >10k rpm) and running 93oct and with extensive cooling mods.
I wouldn't use HBP on a c38 with a stock engine even with ethanol and big cooling mods but experts will keep me honest if that's ok.
dp1 is offline   Reply With Quote
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! P&L Motorsports Forced Induction 9 03-26-2017 01:27 PM
Most *fun* forced induction bfrank1972 Forced Induction 45 12-22-2016 11:36 AM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 12:38 PM
February Sale. All Delicious Tuning e-tunes are 10% off!!! Infamous Performance Announcements, Contests, Giveaways 19 02-28-2014 12:37 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 11:36 AM
