Old 09-07-2016, 01:37 AM   #603
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
I dunno, but take comfort in knowing that it will eventually quit on its own. Mine did anyway after 9 months or so, IIRC.
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Old 09-07-2016, 03:11 AM   #604
Maverick986
Drives: 2014 Subaru BRZ
Originally Posted by lugao View Post
Hey guys, I just complained about my rear deck popping sound on my 2015 BRZ to the dealership near me and I told them that there is a TSB for this (12-140-12), The said that the TSB only applies to 2012 BRZs. Is this true? Thanks in advance!
Not sure what TSB it was, however, when I had my '15 in the dealer recently and complained of a clicking noise from the back seat they noted a TSB for the rear seat latches. After they replaced them I have yet to have the noise again.
Sent from my SM-G925V using Tapatalk
Maverick986 is offline   Reply With Quote
Old 10-07-2016, 09:25 AM   #605
yonel
Drives: BRZ'12
I just bought a 2012 BRZ and I immediately notice this annoying noise.
I would have described it as a "plastic tapping metal" noise coming from the trunk.
I followed the 1st part of the Subaru TSB, and it is completely done!
Thanks a lot for this very useful information!
yonel is offline   Reply With Quote
The Following User Says Thank You to yonel For This Useful Post:
Tcoat (10-07-2016)
Old 11-15-2016, 09:52 AM   #606
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
Tried to do the fix myself with WD-40 twice and has not fixed it. I checked everything on the rear deck and also took off the receiver box. Anyone have tips to how i should go forward with this?
I took it to Subaru but they said my 2013 BRZ wasnt covered in the TSB after both my attempt's failed.
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
rjgough95 is offline   Reply With Quote
Old 11-15-2016, 10:19 AM   #607
Did you show them that the TSB says 13 MY right on it?
http://www.ft86club.com/forums/attac...1&d=1352827748
Old 11-15-2016, 01:04 PM   #608
rjgough95
rjgough95's Avatar
Yes I did it was printed out in the car for them since the receptionist had no idea what a TSB was. She had told me my VIN did not match up.
The Following User Says Thank You to rjgough95 For This Useful Post:
Tcoat (11-15-2016)
Old 11-15-2016, 01:13 PM   #609
sato
sato's Avatar
Drives: Dodge Patitas
A receptionist? That is our problem right there. Probably security personnel had the answer to your troubles. :mad:
Sent from my A1P using Tapatalk
Old 11-15-2016, 01:13 PM   #610
Ahhh I see. Well that sucks.
Old 11-15-2016, 02:07 PM   #611
sato
sato's Avatar
If I understand correctly, the dealer essentially stating that the correction or fix is already applied?
What should be our next steps? Should we confirm repair, and eventually start up looking at other possible sources for the noise?
I just get so "ticked" at dealers not being very helpful or at least interested on helping get some resolve.
The Following User Says Thank You to sato For This Useful Post:
Tcoat (11-15-2016)
Old 12-20-2016, 07:34 AM   #612
yonel
Drives: BRZ'12
After more weeks of driving, I started to notify again a noise coming from the trunk. But, this time it was a bit different, very less loud. I would described it, as already written here, as scratching plastic bottles.
So, it seems the 1st part of the TSB resolves the loud ticking noise, and the 2nd part of the TSB probably solves the quiter plastic bottle noise.
I mean probably, because this time I will no try it. It looks too complicated, and that noise is not that noticeable when driving, because I usually listen to music.
Old 04-20-2017, 04:05 PM   #613
Tor
Tor's Avatar
Drives: Toyota GT86
This is driving me nuts. Any ideas where it could come from? I tried the DIY with greasing it all up to no avail.
[ame="https://www.youtube.com/watch?v=olyEqjoNhIw"]Popping noise from rear deck - YouTube[/ame]
Tor is offline   Reply With Quote
Old 04-20-2017, 05:44 PM   #614
SPEEDGOD
I don't lie.
SPEEDGOD's Avatar
Drives: AE86 Successor
Vasoline fixes it
Yes it's the trunk latch (to put the seat down), either you tweak the alignment with a screw driver or I just added Vaseline (inside, outside) which you may need to apply from time to time.
I'll get a Mustang for way less if I wanted more power.
SPEEDGOD is offline   Reply With Quote
The Following User Says Thank You to SPEEDGOD For This Useful Post:
Tor (04-20-2017)
Old 04-20-2017, 06:17 PM   #615
Tor
Tor's Avatar
Drives: Toyota GT86
Excuse me for the stupid question: Where is it??
My car is a European spec GT86 and I can't see a latch anywhere.
(P.S. the rear seat is removed. The car is completely empty from the front seats and back).
Old 04-25-2017, 06:43 AM   #616
velocityorange
Drives: 86 GTS in velocity orange
Originally Posted by tonytduc View Post
Try this, pull the headliner down in the rear like you did and you will see near the side airbag 3 10mm bolts. Tighten them down alittle bit more and the ticking noise should go away. 6 bolts total 3 on each side. Had the same problem and now FIXED!
This absolutely worked for me after I had tried every other other single thing suggested on this forum. My big mistake was thinking the sound was in the parcel shelf or trunk (boot) area. It was my son riding in the back who said it was coming from the roof. Thanks tonytduc!
I undid the 3 bolts each side that secure the roof crossbeam to the C pillar internal metal supports, hit them with a spot of lithium grease, slightly prised apart the join with out deforming it to get a bit of grease in there too, then replaced the bolts and did them up tight. The annoying constant tick ticking sound has vanished. It drove me so crazy I thought I could still hear it after it had gone, but it has definitely gone. Ah, the serenity!
velocityorange is offline   Reply With Quote
The Following 2 Users Say Thank You to velocityorange For This Useful Post:
dhuang (11-05-2017), sato (04-26-2017)
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 01:28 AM
NEW Volk Racing TE37SL "Black Edition" Different finish, same low price! Speed Element Wheels and Tires 19 07-19-2012 03:27 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 06:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 04:58 AM
