Old 08-23-2013, 08:55 AM   #6105
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Originally Posted by xjohnx View Post
It replaced the MPG gauge with AFR readout, however it only updated at the same rate as the MPG gauge did (once every 1-2 secs or so), so it wasn't terribly useful IMO.
Too bad there isn't a way to up the polling/sample rate on that to refresh faster. I'd totally sacrifice my gas gauge for that.
Nightbringer is offline
Old 08-23-2013, 08:57 AM   #6106
Visconti
Drives: 05 STi
Yeah , to make it work there was some cleaver math done and tricking some things.. Oh well
Visconti is offline
Old 08-23-2013, 08:58 AM   #6107
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
Well that sums it up then..didn't miss out on much I guess. Thanks for the fast reply!!
I only recently turned on the gear indicator in the dash (not ecutek related) and its a nice feature in general but the little "^^" that tells you when to upshift is ridiculous. I tried shifting when it tells me to..it resulted in 2,000 RPM shifts and being in 6th gear at 40MPH.
Any other hidden Easter eggs we haven't mentioned?
Sent from my iPhone using Tapatalk - now Free
chadstyle is offline
Old 08-23-2013, 09:03 AM   #6108
Nightbringer
Drives: Scion FR-S
0-60 and 1/4 times in the same MPG spot. I think that was a while ago tho.
Thought it was neat, but I didn't really care about the upload progress on the tach thing---until it got me "ooooh"ed by a WRX chick last night at the E85 station. Moral of the story: gimmicks get you laid.
The Following User Says Thank You to Nightbringer For This Useful Post:
chadstyle (08-23-2013)
Old 08-23-2013, 09:30 AM   #6109
xjohnx
Grip>Slip
xjohnx's Avatar
did they?
xjohnx is offline
Old 08-23-2013, 09:31 AM   #6110
Visconti
Drives: 05 STi
Yeah that was a clever idea for sure ! Super useful when your letting a car flash and reviewing the Dyno sheet outside the car.. Just peak on the window to monitor the flash progress
John
Visconti is offline
The Following User Says Thank You to Visconti For This Useful Post:
Nightbringer (08-23-2013)
Old 08-23-2013, 09:36 AM   #6111
Nightbringer
Drives: Scion FR-S
did they?
No. No they didn't. /sob
They got me a conversation though. She wasn't buying any of my 'Because Racecar' sweet talk. Very sad. When EcuTEK releases an update that 'seals the deal' for me too, I'll be a happy customer.
On topic: it was mentioned in the other EcuTEK thread, but any possibility of getting the knock alarm/blinker like the GT-R guys?
Old 08-23-2013, 10:23 AM   #6112
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
@Visconti, why we only got Launch Control on map 2 or is it only me?
Would LC and flat foot shifting not work together?
Ryan86 is offline
Old 08-23-2013, 10:57 AM   #6113
Visconti
Drives: 05 STi
Not to thread jack further but...
Yes, I agree. I always double clutch my downshifts. Something I picked up young. When racing shifter karts and dirt bikes they use a constant mesh trans and sequential shift only so I would blip on downshifts to keep it smooth. I've found when I'm hard on the brakes in the BRZ that my feet (size 13) are too big to heel/toe efficiently so I've been interested in the auto blip feature. Apparently, triggering the sequence when not intending to can be a scary experience. From what I understand, and John can correct me if I'm wrong, that you need cut throttle and immediately brake while pressing in clutch to initiate the sequence. In a perfect world that sounds fine but I've heard of people panicking in emergency situation and stabbing both clutch and brake to the floor momentarily and then releasing the clutch in time for the car to lunge forward. I can see how that would be scary in traffic.
My curiosity still has the better of me so I'm going to load it on one map only and see if I can learn how to use it efficiently or decide that it's impossible and ditch the feature.
I'm surprised there aren't more threads about auto blip RR feature and people's experience using it.
This isn't a thread jack..
Although it should, throttle position doesn't effect autoblip working or not.
For autoblip to work:
1. Must be above speed threshold (my tunes are 40MPH)
2. Must be above RPM Threshold (default is 2900RPM)
3. Must Engage the clutch while braking
John
Make a ticket
It's on the list of things to do.. if i had to take a guess it won't happen for a while
John
Visconti is offline
Old 08-23-2013, 08:46 PM   #6114
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
What I find with auto blip is that it'll basically work down to 2nd gear. Seems like 3000rpms is the threshold on my car. Once I figured it out, I learned to use it. However, the blip seemed inconsistent. Sometimes blip too high, sometimes too low.
Question on the tune (stage 2 here), is it normal for the engine to sound like its starting to gurgle when you get very close to redline (when you are getting on it)?
JimmyMac is offline
Old 08-27-2013, 02:56 PM   #6115
rx3
I was thinking about installing aftermarket seats. Unfortunately the passenger seat has a sensor which apparently cannot be fooled/bypassed easily (not with a resistor anyway). http://www.ft86club.com/forums/showthread.php?t=15425
ProECU apparently contains a tool to clear DTCs on the Occupant Detection System (ODS) module: http://www.ecutek.com/news/newslette...ewsletter.html
Does anybody know whether the ODS sensor could therefore be disabled with an adapted tune?
And if so may John offer this option?
rx3 is offline
Old 08-27-2013, 05:21 PM   #6116
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Possibly helpful comment below:
I had an issue with my visconti tune where after driving the car for 1-2 miles, it would struggle to crank back up (so it struggled with luke-warm starts). Visconti said it had nothing to do with the tune. It wasn't a big deal and I figured it was the crank position sensor issue as addressed in a TSB.
I've since switched to a new tuner and have not experienced this in about two weeks. I used to see it every time I put the car through the aforementioned circumstances.
Just posting in case it helps anyone else out. Not shitting on anybody here, for all I know it's just a fluke that it hasn't happened on my new tune.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline
The Following User Says Thank You to Laika For This Useful Post:
Sportsguy83 (08-27-2013)
Old 08-27-2013, 07:18 PM   #6117
Carwhisperer
Drives: A lot of supercars.
my cams wont flip on his latest tune with a revised map. It takes the engine to warm up then multiple restarts for them to finally kick on. Stock it feels like its turbod compared to his tune. And im tired of the closing of the tickets when my other issues are not resolved. About done with this guy.
Carwhisperer is offline
Old 08-27-2013, 07:28 PM   #6118
cuddefred
Drives: Black 86 GT
I know it seems fashionable to beat up Visconti at the moment and I haven't been his biggest fan at times due to his slow replies and perceived attitude but I love the latest tune and can't fault it at all. I flashed back to stock and hated the way the car felt when I did it - the difference between stock and his tune is like night and day for me. Just trying to keep things in balance.
cuddefred is offline
The Following User Says Thank You to cuddefred For This Useful Post:
SkAsphalt (08-28-2013)
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 10:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) -- General Topics 130 09-01-2011 01:42 PM
