Old 05-31-2016, 04:23 PM   #589
steve99
Originally Posted by Felix7007 View Post
My FR-S will soon have the UEL OFH installed. I expect to plug in my OFT and flash with this new 93oct tune and go to the track on July 1st. What are the chances everything will go smoothly? I see people posting some problems here. Is this product more trouble than it's worth?
The new tune people are talking about here is designed specificly for an OFH UEL header on good quality 93 fuel. some people are trying the tune with different header and maybe fuel that's not top quality and they are having the odd problem.
If your running a OFH and good 93 fuel you should be fine.
The OFT will likely come preloaded with the less aggressive "standard" UEL tune.
Teseo (06-02-2016)
Old 05-31-2016, 06:45 PM   #590
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by tdotBRZ View Post
OFH is exact same layout as Tomei UEL, just 2.5" instead of 2.38" piping from what I can recall, correct me if i'm wrong
I'm talking about not only the collector size but the runner diameter. Something like 1.75" OD vs 1.65" OD or something like that.
Intent > Content
Old 06-01-2016, 06:41 PM   #591
FrostedFlakes
Drives: 2013 Raven FRS
I just plugged in my OFT out of curiosity.
Seems like my Advance Multiplier is below 1. Cold start it was at 0.68, then after a short drive it was 0.72 and then after a highway cruise back home it was about 0.78.
I am using *supposedly 94 octane. I knew our Cheveron 94 Octane was crap here in Vancouver, Canada, but didn't realize it was that bad.
I am sure this isn't really ideal for this aggressive tune, but not sure if there is anything to be concerned about at this moment....
FrostedFlakes is offline   Reply With Quote
Old 06-01-2016, 09:52 PM   #592
RedFRS4me
RedFRS4me's Avatar
Drives: Firestorm '13
At .80 IAM I dont feel comfortable. I ended up going back to the regular stage 2 uel.
'13 Firestorm
RedFRS4me is offline   Reply With Quote
The Following User Says Thank You to RedFRS4me For This Useful Post:
FrostedFlakes (06-02-2016)
Old 06-02-2016, 01:49 AM   #593
Michael
Lovin' the Low Life
Michael's Avatar
Drives: 2014 Scion FR-S
I'm good with having the standard UEL tune. What are the benefits to the more aggressive tune?
2014 Scion FRS: Bagged & Wide
INSTAGRAM: @frsmichael
BUILD THREAD: Click Here
Michael is offline   Reply With Quote
Old 06-02-2016, 01:56 AM   #594
steve99
The updated ofh tune was specifly for ofh and good fuels if you can run it with minimal knock then it should produce a fewcmore hp. If you getting knock and your iam is dropping below 1 regularly then your better off with the standard uel tune thats less agressive timing and fueling wise.
Old 06-02-2016, 02:00 AM   #595
Michael
Lovin' the Low Life
Michael's Avatar
Good to know. I only run Shell 93 VPower which is, from my understanding, top tier fuel. I need to learn how to read the datalogs once I get a OFT to know what to look for on knocks.
Old 06-02-2016, 02:14 AM   #596
FrostedFlakes
I have been running this tune since it was released and driven mostly in city traffic. Thought I would be safe, but turns out I was wrong. I will revert back to the standard UEL tune for now until I can figure out a way to boost the octane of our local piss water premium fuel.
Old 06-02-2016, 03:21 AM   #597
steve99
think i remember someone said Husky fuel was good ?
Old 06-02-2016, 10:06 AM   #598
FrostedFlakes
We used to have Husky 94 but they got rid of it and I think the highest now is 91.
However we have one E85 gas station a little bit out of Vancouver. I may go and mix 10% E85 with the local 94 and see what happens.
Old 06-02-2016, 02:14 PM   #599
BurnetRhoades
BurnetRhoades's Avatar
Drives: 2013 "Hot Lava"
JDL UEL also have 1.75" OD on primary runners, which is surprisingly larger than even the ACE 4-2-1 at 1.68"
2013 Hot Lava FRS :: OFT Stage 2+ :: JDL UEL Catless :: JDL Over-Frontpipe :: GReddy Evolution RS Catback :: Enkei "Tarmac Black" RPF1 :: Tein Flex-Z Coilovers :: 245/35r18 Conti DW :: RS*R R-LCA :: Racer-X Fab R-Toe Arms :: Mishimoto Intake Tube :: Mishimoto Oil Catch Can :: JDL FSTB :: Raceseng "Slammer" + RLO :: Diode Dynamics HID + Tail-as-Turn + DRL :: 5:AD Spoiler ::
BurnetRhoades is offline   Reply With Quote
Old 06-02-2016, 05:15 PM   #600
G-awesome
Drives: 2015 Firestorm Scion FRS
Sweet..another Vancouver native that I can compare results with. I didn't know that our Chevron 94 was that bad here until I started tuning/testing/data logging recently.
Which header do you have? I had knock issues in the high rpm range using chevron 94 using both the OFH & OFT tunes during WOTs. My IAM starts at one and kept dropping to 0.5 after a couple of pulls. The car is mainly a DD so my IAM stays at 1 with very little knock when you're stuck in traffic and driving normally most of the time.
The header is a catted JDL UEL header which is most likely too aggressive to start with. I have a feeling that the high flow cat is more restrictive than I thought. Paired with crappy Chevron 94 gas...it's sucks and kinda wish I never went with a catted header to start with.
I'm in the process of testing with Shell 91 and back to a stage 1 tune for the time being. Been learning and testing with different timing maps to perfect a tune for a catted header.
G-awesome is offline   Reply With Quote
Old 06-02-2016, 09:42 PM   #601
FrostedFlakes
I am running OFH and full catless exhaust. *update - I mixed 10% E85 today, but the fuel still remained at 0.82 after a long drive. It was not until after I drove about 76km that the IAM started to peak all the way up to 0.98.. lets see if it will hit 1. My IAM dropped to 0.46 at one point today before filling a bit of E85, leads me to believe it either is a really bad batch, or the fuel is just shit in general.
PM me on how the the Shell 91 turns out for you.
The Following User Says Thank You to FrostedFlakes For This Useful Post:
G-awesome (06-03-2016)
Old 06-02-2016, 10:07 PM   #602
solidONE
solidONE's Avatar
Not surprising really. Though you're comparing apple (UEL 4into1) to peach (long tube 4-2-1 EL).
Intent > Content
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 11:56 AM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 01:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
