Koji_Online
Old 05-17-2015, 01:18 AM   #589
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by Atticus808 View Post
I tried to do the clutch adjustment but the 12mm was so damn tight I couldn't loosen it. anyone else have that issue?
The Following 3 Users Say Thank You to Andrew025 For This Useful Post:
Atticus808 (05-17-2015), chaoskaze (05-17-2015), Ultramaroon (05-17-2015)
Old 05-17-2015, 01:26 AM   #590
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by Celadrielas View Post
My paperwork came back with the folowing note: "There is no clutch adjustment for this vehicle. While slightly lower than other FRS on the lot, there appears to be nothing out of alignment or harmful with the vehicle."
--- I guess, to me, that means if it WAS aggressively low, it could be damaging to the vehicle, in theory. Or the toyota mechanic was a complete idiot. But you know... which ever
Mechanic was an idiot. As long as the master piston is able to extend completely, that's all that matters.
Celadrielas (06-10-2015)
Old 05-17-2015, 01:50 AM   #591
Atticus808
Atticus808's Avatar
Drives: Splash Mountain
I felt like if I kept going it would break something. that little piece that wobbles I felt like I was gonna snap lol
Atticus808 is offline   Reply With Quote
Old 05-17-2015, 01:51 AM   #592
Atticus808
Atticus808's Avatar
@Ultramaroon
would you recommend this mod? I remember you said something about it but I don't feel like going back 20 something pages lol
Old 05-17-2015, 02:24 AM   #593
Andrew025
Andrew025's Avatar
I remember it was pretty stiff the first time I did it but didn't really have much issue with it. Try a longer wrench?
The Following User Says Thank You to Andrew025 For This Useful Post:
Old 05-17-2015, 02:30 AM   #594
Ultramaroon
not playing cards
@Ultramaroon
***I recommend removal of the assist spring before lowering the clutch pedal. This is to guarantee the master piston is allowed to fully extend.***
Edit: On studying the mechanism more closely, I've realized my above statement is incorrect. It is impossible to adjust the clutch pedal so low the assist spring interferes with pedal return. Leave it in or remove it - totally optional. I corrected a similar statement in another thread but forgot about this post. /edit
Then the most important step is to swap out the slave cylinder. Best 40 bucks you could spend. Save the old one in case you absolutely hate it but I doubt it. Makes the clutch as nice and crisp as the rest of the car.
BTW, props to @Andrew025 for convincing me to yank the spring. I came to understand the mechanism a little bass ackwards but got there nonetheless.
Andrew025 (05-17-2015), Atticus808 (05-17-2015)
Old 05-21-2015, 03:22 AM   #595
awhatzable
Drives: GTS86
What I don't understand is what is actually closing the gap where the pin is. Is it from holding down on the sensor or lifting the clutch up ?
If it's both then what does holding on to the sensor do & what happen if I don't hold on to it ? I was expecting it to be some sort of button or switch but its just flat plastic.
Also, I don't have a 12mm nut and a rod on top of the gas peddles like where the video shows... My 12mm nut and rod is where the clutch is.. Is my car different ? (2013 GTS 86)
awhatzable is offline   Reply With Quote
Old 05-22-2015, 06:39 PM   #596
turbice
Drives: nil
The parts shown in the video are on the opposite side for us in Australia.
but they will look similar
turbice is offline   Reply With Quote
Old 06-04-2015, 12:29 AM   #597
Joyride86
Joyride86's Avatar
Drives: 15 FR-S Firestorm MT
Just finished doing this and have the clutch slightly higher than the brake pedal. Shifts have gotten a little smoother, but still gonna pull the spring eventually.
I wasn't able to get the white cap back on, but the pin clip is secure. Does the white cap affect anything?
Joyride86 is offline   Reply With Quote
Old 06-11-2015, 12:22 AM   #598
Ultramaroon
not playing cards
Corrected a couple previous posts. See #594 and #586.
Old 06-15-2015, 12:03 PM   #599
LostSalad
Drives: Toyota 86 - Charcoal Grey
So I just got this done and found that the recommended height of just below the brake pedal was too short for my tastes. At the end of the day I got it sitting square with the brake pedal.
Something that I noticed is that the pedal feels slightly softer. There is less resistance from the spring. Is this because the spring compresses less with less travel distance or what?
The full range of travel is also obviously shorter, but the combined effect of shorter travel and softer spring makes it feel like I'm pushing the pedal down and it won't come up again. It's a bit unnerving really.
LostSalad is offline   Reply With Quote
Old 06-28-2015, 02:14 PM   #600
Cal3000
Drives: Panda FR-S
I couldn't for the life of me get that rod to turn, yet I see people complete this in 5 mins
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following User Says Thank You to Cal3000 For This Useful Post:
SlammedSilly (04-13-2016)
Old 06-28-2015, 02:54 PM   #601
LostSalad
Take your other hand and depress the clutch slightly (just enough to loosen tension on the rod) and wiggle the rod both ways (not just the way you want to turn). However it is a bit slippery (at least mine was) which can make it hard to get a good grip for turning.
You sure you properly loosened the nut on the rod?
The Following User Says Thank You to LostSalad For This Useful Post:
Cal3000 (06-28-2015)
Old 06-28-2015, 04:51 PM   #602
Cal3000
Drives: Panda FR-S
Got it. Just took a bit of wiggling. Thanks
LostSalad (06-29-2015)
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 04:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 11:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 03:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 02:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 04:48 PM
